Stupid filter question
7 replies to this topic
#1 John Tucker
John Tucker
  • Loc: 94606
Posted 24 May 2019 - 09:08 PM
I have a LX200 8 inch SCT which I've used with both a standard 1.25 inch T adapter and with a wide bore adapter sold by Meade https://www.adorama....ource=adl-gbase,
I've ordered both 1.25 inch and 2 inch threaded adapters and they don't screw in anywhere in this optical train.
Dumbest question in the world: How do you fit the filter between the camera and the OTA?  Everything is threaded but the threads don't match up.
I asked Highpoint about this and they tried to sell me a filter that clips into the body of my Canon, but it seems crazy to me that with all these threaded parts I can't buy a simple threated filter that screws into the adapter or the back of the OTA.
Looking into narrowband now and since these filters are expensive I don't want to figure this out by trial and error.
Edited by John Tucker, 24 May 2019 - 09:12 PM.
#2 ngc7319_20
ngc7319_20
  • Loc: MD
Posted 24 May 2019 - 10:16 PM
Usually a 1.25" filter can be threaded on to a 1.25" / T adapter.  But maybe your adapter does not have threads?
  • John Tucker likes this
#3 RogeZ
RogeZ
  • Loc: Palm Beach Gardens, FL
Posted 24 May 2019 - 10:37 PM
Filters should never be load bearing unless design to be so like SCT body filters. All others should go on a filter drawer or wheel.
  • pgandy and John Tucker like this
#4 Stelios
Stelios
  • Loc: West Hills, CA
Posted 24 May 2019 - 10:52 PM
Do you have a 2" filter? Does it not thread to the inside of your T-adapter?
Typically solutions for DSLR's (which, judging by the Meade T-adapter you show, is what you need) will accommodate light-pollution filters, but are usually not designed for narrowband filters. Buying 2" narrowband filters to use with a DSLR doesn't make financial sense--the 2" filters will cost significantly more than the DSLR...
#5 44maurer
44maurer
  • Loc: Los Angeles, CA
Posted 25 May 2019 - 02:14 AM
+++1
#6 John Tucker
John Tucker
  • Loc: 94606
Posted 25 May 2019 - 10:21 AM
So here is the 1.25 filter screwed into the end of the nose piece for my little $100 planetary camera.  No problem here.  But you're saying I can't do this with a narrowband filter?
For the DSLR adapter, the 1.25 inch is far too small.  If I put the 2" filter on the end of the adapter that connects to the OTA, it protrudes too far radially and prevents attachement to the OTA
If I attach it to the other end, it screws right in but now it protrudes too far axially and the adapter cannot be screwed into the camera
I just bought a PowerNewt and a very inexpensive used astrophotography camera (Meade DSI, 0.25 megapixels) with the idea of picking up a lower priced Ha filter and trying this out.  I also picked up this filter drawer.
https://www.teleskop...ngth-15-mm.html
Did I screw up?
#7 ngc7319_20
ngc7319_20
  • Loc: MD
Posted 25 May 2019 - 12:40 PM
Besides 1.25" and 2" filters, they also make SCT back filters.   I guess this is why they make them -- to solve this exact problem.  However I see them less and less these days.
The other way out of this, is to get a 2" back for your SCT, get a T-2" adapter for the camera, and then put your 2" filter on the 2" adapter.
Baader makes lots of adapters.  Here one scheme with a 2" filter mounted on the back of an SCT...
https://www.baader-p...extension).html
Borg / Hutech / IDAS also make lots of adapters. They make a 48mm/2"  light pollution filter that will screw on to the back of your SCT and then has a male SCT thread you just attach your normal SCT stuff on to:
https://www.firstlig...daptor-set.html
https://www.sciencec...ters/fltsct.htm
But you can also buy it without the filter.  The you could just use your existing 2" / 48mm filters on the SCT.  You would need Borg parts 7424 and 7502
https://www.sciencec...s/html/7424.htm
https://www.sciencec...s/html/7502.htm
Edited by ngc7319_20, 25 May 2019 - 12:55 PM.
#8 John Tucker
John Tucker
  • Loc: 94606
Posted 25 May 2019 - 12:57 PM
Cool, thanks!  I don't understand why those things would be made with such similar but non-identical threads or how you look up online what piece has what thread, but it looks like you've set me up for now.
  • ngc7319_20 likes this
