APM Fork Mount with AMT Encoder ans Nexus Controller for large Binoculars
new better prices due price reduction on nexus and large serial production of the mount , being now not longer made 1 by one, but in serial production by big machine shop
US $ 1,295.00 plus shipping from germany. We stock in Germany
https://www.apm-tele...tml?info=361688
APM Fork Mount with AMT Encoder and Nexus Controller for large Binoculars
The APM fork mount is the result of user feed back. Optimal tracking coupled with nearly no vibrations and at the same time a high load capacity are unsurpassed. Modern mounting with integrated encoders.
Therefore, the APM fork mount is the first choice for your binocular.
Fields of application
solid azimuth mount for Astronomy - suitable for our new APM ED 100mm and 120 mm Binocular
Features
Alt/azimuth Fork mount
Weight 12.3 lb
Tripod connection with 3/8" photo tripod thread
Panning area 360°, tilting from horizon to zenith
Accessory interface with a long hole and 3/8" screw
Adjustable friction in Altitude and Azimuth
integrated encoder
Nexus Controller
Tilting up to Zenith
Through the special fork design this mount enables you to tilt up to the zenith. So you can use it for astronomy and nature observing.
Technical details
The Pivot bearing (base) is made as ball bearing.
The distance of the fork-arms is 28 cm inside, and 36 cm outside. This fork-mount is suitable for our 100mm and 120 mm binoculars, and the 28x110 binocular. The fork mount is equipped with two capacitive AMT encoders. A digital readout unit and a suitable connection cable are required optional.
Delivery contents
Fork mount
3/8" Mounting screw
AMT Encoder
Cover for both Encoder
Nexus Controller
Cable (for example Nexus Hand controller)
Mounting plate for Nexus
