comparing a 3 min sub *(M81-82) bw a 3.5" and 5" triplet.
5 replies to this topic
#1 Ballyhoo
Ballyhoo
  • Loc: San Diego
Posted 27 May 2019 - 01:01 AM
I wanted to share the different views I got with the same target 6 weeks apart, but one with the 85mm Orion Eon, and the other with a 127mm ES ED triplet.  same camera. No reducer or filter.    I think once you get comfortable imaging with different scopes, then it raises the question, "which one is going to be my main imaging scope.?" I love them both. But,...
  • zjc26138 and elmiko like this
#2 mistateo  Happy Birthday!
mistateo
  • Loc: San Diego, CA
Posted 27 May 2019 - 01:26 AM
The answer is........ BOTH!  Use the Eon 85mm for wider field targets (like heart nebula, soul nebula, rosette nebula, andromeda, etc) and your ES127 for smaller targets.  But do yourself a favor and get a field flattener (or reducer/flattener) for that Eon 85mm.
Here is how I choose which scope I shoot with:
Does the target fit in the FOV with my Edge HD, and is the seeing decent?  If yes, shoot it with Edge HD.  If no:
Does the target fit in the FOV of my 120mm refractor? If yes, shoot it with 120mm refractor.  If no:
Does the target fit in the FOV of my 80mm refractor? If yes, shoot it with 80mm refractor.  If no: consider mosaic or camera lenses.
Did you ever play with a FOV simulator (like the one built into Stellarium, or on this website)?  It will help you choose which scope to use for your camera and a given target.
  • zjc26138 and Ballyhoo like this
#3 Ballyhoo
Ballyhoo
  • Loc: San Diego
Posted 27 May 2019 - 01:35 AM
Never. Nor have I ever wondered about using my 8"SCT for imaging.
#4 Ballyhoo
Ballyhoo
  • Loc: San Diego
Posted 27 May 2019 - 01:40 AM
I have processed the integrations and I am more please with the final integration on the EON. Processes both w PI but for some reason the 5" image is being processed too dark and I am not sure why (bottom)
edit, for those of you who know PI, with the bottom image it went south when I applied HRDM multiscale transform. Normally when I apply that process I get an improvement, but in this case it made it crazy wild, unrecognizable. So I had to bypass that process.  actually the trouble started after color calibration. It left me with an overly dark image.
Edited by Ballyhoo, 27 May 2019 - 01:44 AM.
#5 Ballyhoo
Ballyhoo
  • Loc: San Diego
Posted 27 May 2019 - 01:52 AM
before
and after color calibration.  ???
#6 2ghouls
2ghouls
Posted 27 May 2019 - 03:23 AM
before
Assuming you haven’t stretched the data yet, just turn the autostretch off and back on and it will look normal (not so dark). There are a number of processes that will look weird if you do them with the autostretch on. Cycling it (off and on) has always fixed the issue for me.
