Most informative write up, and attached photos. Bravo.
Hutech Hinode Solar Guider First Light 6/1/2019
#26
Posted 11 June 2020 - 12:16 PM
- rigel123 likes this
#27
Posted 12 June 2020 - 02:32 AM
Would this Hinode Sun Guider work with Alt-Az scopes?
#28
Posted 12 June 2020 - 05:33 AM
I honestly don’t know. I suppose if the mount has a guide port it is possible but I haven’t heard of anyone guiding with an alt/az mount unless it is set up on a wedge.
#29
Posted 12 June 2020 - 08:11 AM
From my understanding, It would have to be in EQ mode. Like Warren said, on a wedge.
#30
Posted 12 June 2020 - 09:23 AM
Alternatively I guess you can take an AZ-GTI with Eq-wedge and use the hinode. I’m using my hinode on AVX or EQ6R-Pro. It’s great.
#31
Posted 31 October 2020 - 05:55 PM
Is this a new feature as the Hutech description seems to say it hunts for the sun when it is covered with clouds?
#32
Posted 31 October 2020 - 05:56 PM
#33
Posted 31 October 2020 - 08:15 PM
From reading John O’Neal’s article in the Summer 2020 issue of Amateur Astronomy magazine, he mentions that the Hinode can continue guiding through clouds as it “remembered how frequently it was making adjustments and continued to make them while the sun wasn’t visible.”
No, it can’t continue guiding when clouds obscure the sun. It makes this sad “beu-eep” sound and after moving the scope around looking for the sun it stops. However if the sun comes back out and it is still on the sensor of the guider it will attempt to bring it back to where it was when it started guiding.
#34
Posted 20 June 2021 - 04:46 AM
Thanks Warren, I was looking for a solar guiding solution and your review just closed the deal for me.
- rigel123 and fiston like this
#35
Posted 20 June 2021 - 05:34 AM
Enjoy! Of course you are dooming yourself to a stretch of cloudy weather when you get it!
#36
Posted 20 June 2021 - 06:04 AM
Of course... I already used to the clouds rolling in whenever I take out my solar rig...
Maybe a negative and a negative will result in a positive, but my expectations for this are low
- rigel123 and astro rocketeer like this
#37
Posted 21 June 2021 - 09:24 AM
Same here. I ordered it after reading the review; I've been super happy with it.
#38
Posted 23 June 2021 - 04:11 AM
Looks like an awesome product. I can see myself buying one some day, to do long style animations of interesting regions with the Solaxmax 90 III. Got to get a camera first.
#39
Posted 03 September 2023 - 02:58 PM
Hello, does anyone know of something like the Hinode astro Hutech but must less expensive? Maybe a guide scope with camera with a solar film on the guide scope and software to control the mount?
Maybe Firecapture?
Thanks all
Christopher
#40
Posted 03 September 2023 - 09:39 PM
Maybe Firecapture?
Thanks all
Christopher
Some folks do use tracking features in both Firecapture and SharpCap so hopefully some of them may respond. One of the features I really like about the Hinode is that it also reports out (utilizing the software for guiding) the intensity of the light so that I can be alerted of any interfering high clouds that I might not be able to detect visually.
#42
Posted 16 March 2024 - 12:01 PM
I am struggiling with this Hinode also.
Too many problems !
Cusrtoimer support is non existant and the last update of this crappy SW was in 2014 (!)
I have a ZWO AM5, runing Sharpcap and a Lunt 80 MT
I am connected via mini PC.
I cannot get the Hinode to control the AM5 at all.
I tried using the USB port on the Hinode. I tried using the ST4. Calibration fails 99% of the time with "No movement" or "No Dec movement", or other non sensical error.
I even tried the manual control with no sucess.
Can someone here tell me if they have had sucess with this setup and HOW (detailed sequence of connectiosn and SW runing) they did it ?
#43
Posted 17 March 2024 - 07:48 AM
Too many problems !
I haven’t had to contact them since the time I fried mine by putting the guide cable into the auxiliary port on my CEM25P which they repaired for no charge a few years ago so sorry to hear you are having issues. My Hinode is connected directly to my laptop so I can’t offer any thoughts on your issue working through a mini PC. I will offer one ridiculous suggestion that worked for me when I found the Hinode would only move the scope on one axis and not the other. The solution makes no sense but it worked for me. I simply reversed the ends of the cable connecting to the mount and the one connecting to the Hinode and everything worked fine. I know it should not make any difference but it did for me so I marked that end of the cable going to the Hinode so it always is hooked up that way and I have had no issues with mine since I wrote this review.
Have you emailed Ted at Hutech? He was always great at getting back to me.
ted@hutech.com
ishikawa@hutech.com
Not sure which one is correct or if he is still with them.
