Illford SFX 200
8 replies to this topic
#1 TxStars
TxStars
  • Loc: Lost In Space
Posted 11 June 2019 - 12:20 AM
So anyone tried it yet?
https://www.freestyl...ed-Sensitivity)
#2 nof
nof
  • Loc: Israel
Posted 11 June 2019 - 01:54 AM
Hello, I used to use it years ago for landscape work, where it had an almost infrared look to it, darkening blue skies and lightening foliage. But I preferred other films for wide field astro photographs with long exposures.
#3 Todd N
Todd N
Posted 11 June 2019 - 05:07 AM
Yes, in the past and even recently I bought a roll to test and it has extreme reciprocity, so bad I didn't care to scan the results. It also doesn't respond to hypering.
#4 TxStars
TxStars
Posted 11 June 2019 - 11:24 PM
Guess I'll have to keep looking for a B&W with smallish grain that can get into or past 650 nm  ...
Perhaps I get a roll of Rollei RPX 100 and see if it can live up to it's speck sheet..
Edited by TxStars, 11 June 2019 - 11:26 PM.
#5 Giorgos
Giorgos
  • Loc: Athens, Greece
Posted 12 June 2019 - 06:21 AM
It has been tried on astrophotography with disappointing results (too much reciprocity failure). Look here.
#6 Todd N
Todd N
I've already tested(hypered) Rollei RPX 100  to no benefit and extreme reciprocity. The last couple of years I have pretty much surveyed and tested most films with extended red sensitivity and the only ones that significantly respond to H2 are Fomapan 400 and Bergger Panchro 400 which I haven't fully tested since it isn't available in 35mm anymore. Below is a list of red sensitive films I have tested. Otherwise noted they either didn't respond to H2 or the benefit was insignificant:
Ilford SFX 200,
Berger Panchro 400
Fomapan 200
Fomapan 400(Very positive to H2)
JCH Streetpan 400
Rollei Retro 80
Rollei Retro 400s
Rollei RPX 100
Rollei RPX 400
Ars-Imago 320
Extended red films I haven't tried and are unlikely to since they are suspect rebranded films or from a line of films, namely Rollei/Agfa Aphiphot that have poor performance in general:
Foma Retropan 320(Ars-Imago 320?)
Adox HR-50 Speedbosst(Agfa Aviphot)
Most of Film Washi line
CatLab films IS0 80 & 320
Todd
Edited by Todd N, 12 June 2019 - 10:26 AM.
  • Giorgos likes this
#7 Giorgos
Giorgos
Posted 12 June 2019 - 02:11 PM
Another technique worth trying would be chilling film in a cold camera... I suspect more films will respond to chilling than to H2 hypering.
#8 Todd N
Todd N
Posted 12 June 2019 - 05:32 PM
One technique is to use color film with a red filter and then convert it to B&W after being scanned. My recollection is there are some color films(namely Kodak) that are H-alpha sensitive and even higher ISO color films are less grainy to their B&W counterparts. I believe Kodak Ektar 100 has already been tried and not performed well.
Todd
Edited by Todd N, 12 June 2019 - 05:34 PM.
#9 Nightfly
Nightfly
  • Loc: Dark Skies, Maine
Posted 12 June 2019 - 07:48 PM
For color work I suggest Fujifilm Superia 100, also called CN 100.  Not to be confused with the discontinued Reala 100.  Best color negative film ever made.  And it's still available.   Thought I would mention it since it escapes most conversations.  Only available in 135 unfortunately.
It is now called Fujicolor 100 Industrial.
https://www.casualph...ial-100-review/
