Lightweight F4-F6 150mm/6" Newtonian OTA for Child
beginner observing outreach reflector
7 replies to this topic
#1 Spacefreak1974
Spacefreak1974
  • Loc: Indianapolis, IN
Posted 12 June 2019 - 07:02 AM
Hello
My 10yr old currently uses a 4.5" F/4 Newtonian on a GSO SKyview Deluxe ALt/Az mount. Its pretty much the perfect scope for a child given adjustable eyepiece height, lightweight, etc other than one thing and that is aperture. I'd like to get a lightweight 6" newtonian for him that'll still work well on the GSO Skyview Deluxe (similar to a Porta 2 from Vixen).
I'd also like to keep the costs down as well
Anyone have any recommendations?
#2 KerryR
KerryR
  • Loc: West Michigan
Posted 12 June 2019 - 07:43 AM
A 150mm f5 would push that mount a bit. It'd work for low and moderate powers, and there'd be tube/tripod interference.
A 130mm f5 would work nicely, but it's not much of an aperture gain. Detectable, but not a significant upgrade.
Honestly, if you want a 6", I'd move to an f8 Dob-- it'd be much better mounted, be a nice jump up in aperture, and behave optically very differently to the 4.5" f4.
#3 SeattleScott
SeattleScott
Posted 16 June 2019 - 11:22 AM
I am with Kerry. If you don’t care about vibrations you could stick a 6” F5 on there, but you are getting close to the capacity of the mount. Even if you could still get an AZ4 for $200 and a 6” F5 with 2” focuser for $220, that would still be $20 more than an 8” Dob. So if you want to go bigger you are looking at a 6” or 8” Dob.
Scott
#4 kfiscus
kfiscus
    Baltic Birch Dob Bases
  • Loc: Albert Lea, MN, USA
Posted 16 June 2019 - 05:55 PM
I'd recommend the Orion XT6 if you could accept an f/8 dob.  The 2 pieces are a combined 34 pounds.  They can be gotten used for $150, new they're $300.
Edited by kfiscus, 16 June 2019 - 06:01 PM.
#5 GoFish
GoFish
  • Loc: Kentucky / Colorado
Posted 16 June 2019 - 06:30 PM
I have a Celestron Omni XLT 150, 6” f/5 Newtonian that I like very much. I bought it used. You should be able to find one for $150 or less, plus shipping, here on CN or maybe AstroMart.
Based on a sample of one, this is a heckuva scope for the price. I can’t speak to whether your mount can support it effectively.
#6 tomykay12
tomykay12
  • Loc: San Diego
Posted 16 June 2019 - 06:40 PM
My 150 xlt rides pretty nicely on a CG-4; I really don't see it behaving nicely on a lesser mount.
#7 Sky Muse
Sky Muse
  • Loc: Mid-South, U.S.
Posted 16 June 2019 - 07:09 PM
Hello
There's actually one more aspect of that 114mm, it's an f/4, and more difficult to collimate, not to mention the difficulty in reaching the higher powers of which an 114mm aperture is capable.
I have the same mount as your own, older, and in white, but with a pier, and here with a 6" f/5 Newtonian mounted upon it...
The pier actually benefits a longer telescope, like a long-focus refractor or Newtonian...
...with that being a 114mm f/8 Newtonian.
I've had no trouble observing with the 6" f/5 on that mount, not at all. It performs much better as a matter of fact than when it was attached to its original mount...
A 6" f/5 OTA...
https://www.highpoin...ShoC4L0QAvD_BwE
If you go with a 6" f/8 "Dobsonian", I would suggest this one over the Orion...
https://www.astronom...ope-s11600.html
...although the eyepieces will be positioned a bit higher perhaps, depending.  It comes with a 1.25"/2" metal focusser.  That of the Orion 6" f/8 is a 1.25" only, and of plastic.  The Orion does have the better primary-cell, spring-loaded, but that of the Sky-Watcher can be far more easily renovated, with metal springs, than the plastic focusser of the Orion.
Edited by Sky Muse, 16 June 2019 - 07:09 PM.
#8 SeattleScott
SeattleScott
Posted 16 June 2019 - 09:32 PM
That looks like a better tripod than he has. Looks like the old Astrotech Voyager. Those were nice GNG mounts. I didn’t get one in time. The tripod reminds me of my HAL130. I’m sure it isn’t that stable, but the design looks similar. I would expect that mount to handle a 6” F5 based on my research. Not so sure about his mount, based on the picture I googled, and a buddies experience.
Scott
Also tagged with one or more of these keywords: beginner, observing, outreach, reflector
