How to raise a DOB off the ground?
16 replies to this topic
#1 pmch
pmch
Posted 12 June 2019 - 10:41 AM
Last night I was looking at Jupiter with my 12" Dob, which was very low in the sky, on my observing chair set to about 6" off the ground and I was having quite a problem getting low enough to look through the eyepiece. Has anyone built a platform to put a Dob on to raise it higher? Any links or pictures? I didn't find anything when I did a search. Any recommended products that have been made for this? I think I am getting to old to get this low. I even bought a Celestron Evolution 9.25 for most of my observing for this problem. Thanks for any information.
#2 JGass
JGass
  • Loc: MD
Posted 12 June 2019 - 10:45 AM
https://10minuteastr...nian-telescope/
  • ArizonaScott, Augustus and pmch like this
#3 S.Boerner
S.Boerner
  • Loc: Chesterfield, MO
Posted 12 June 2019 - 11:07 AM
Orion has a Dob Pod for scopes up to 10" so  you'd need to beef it up:
https://www.telescop...es/p/102785.uts
This DIY would be another option:
https://www.youtube....h?v=6PRPRUwcnag
  • pmch likes this
#4 pmch
pmch
Posted 12 June 2019 - 11:18 AM
Thank you for the info. This helps to get me started.
#5 Pogo007
Pogo007
Posted 12 June 2019 - 12:50 PM
If money isn't a barrier
http://www.jimsmobil....htm#Dobsonians
#6 pmch
pmch
Posted 12 June 2019 - 01:52 PM
Pogo007, thanks for the link for the wheeled dollies but I need something that is as high as possible that is still stable. So far I prefer something like the youtube DIY posted by S.Boerner but still open to suggestions.
#7 Dale Eason
Dale Eason
  • Loc: Roseville,Mn.
Posted 12 June 2019 - 03:10 PM
Here is what I did.  I made two option.  A tripod to use when standing and a triangular base to use while sitting.
  • pmch likes this
#8 Pogo007
Pogo007
Posted 12 June 2019 - 05:10 PM
Sputnik - here is a pic and the sketch for a stand I made.   You'd have to make some changes in order to raise your scope higher but that wouldn't be too difficult.  The screw down feet are for leveling
Dob stand plan
completed stand for dob
I've since added lockable caster wheels at the three corners slightly behind the screw down levelers.
Edited by Pogo007, 12 June 2019 - 05:14 PM.
  • pmch likes this
#9 Pinbout
Pinbout
  • Loc: Montclair, NJ
Posted 12 June 2019 - 05:33 PM
I have a piece of truss for my 8in f3.5
  • kfiscus likes this
#10 kfiscus
kfiscus
    Baltic Birch Dob Bases
  • Loc: Albert Lea, MN, USA
Posted 12 June 2019 - 08:20 PM
The best thing to put under a dob is an EQ platform but it only adds 4-6 inches.
  • Jim Nelson likes this
#11 dave brock
dave brock
  • Loc: Hamilton, New Zealand
Posted 12 June 2019 - 11:23 PM
My solution.
  • epee, roscoe, Dale Eason and 4 others like this
#12 dave brock
dave brock
Posted 12 June 2019 - 11:26 PM
The join. Cuts are 30°.
  • Cometeer likes this
#13 Dick Jacobson
Dick Jacobson
  • Loc: Cottage Grove, Minnesota, USA
Posted 13 June 2019 - 07:22 AM
Three concrete blocks in a triangle would do the job, if you don't mind the weight. I've also used flower pots upside down.
Edited by Dick Jacobson, 13 June 2019 - 07:23 AM.
#14 epee
epee
  • Loc: Suh-van-nuh, Jaw-juh
Posted 13 June 2019 - 08:52 AM
"Milk Crate" storage containers do well; depending on the size of your scope. They also help haul the accessories outside.
#15 DeanS
DeanS
  • Loc: Central Kentucky
Posted 13 June 2019 - 09:04 AM
I made a 3 legged stool and attached it to the base feet with screws so it is somewhat permanent.  I was able to modify the wheelbarrow handles so they still work.  Makes it much easier to view at all elevations as this is a 12" F/4.
Also you can see that I can leave the wheels on now when observing since I reversed them.
Edited by DeanS, 13 June 2019 - 09:06 AM.
  • pmch likes this
#16 pmch
pmch
Posted 13 June 2019 - 09:13 AM
Thank you all for your suggestions. I am sure I will incorporate many of the ideas into my design.
#17 Joyouswonders
Joyouswonders
  • Loc: Hillsdale Michigan 49242
Posted Yesterday, 10:18 AM
I used 16" Hairpin Table Legs on my 6" dob.  They also come in 6" & 28".
I removed the ground board circle and attached 3 of the four legs to it.  I glued the hollow plastic spindle it rotates on, to the ground board so it wouldn't get lost as it was only held in place by being a snug fit.  I then had only 2 pieces and both were too large to loose.  The bottom being about 10 lb and the top about 45 lb.  Forty-five still sounds like more than I wanted so wheels were next.
