Various magnifications replicates what visual "distance" from the moon?
15 replies to this topic
#1 miniqtone
miniqtone
  • Loc: Central NC
Posted 12 June 2019 - 10:58 AM
If I were to view the moon at 200x, what distance from the moon would that simulate via the naked eye?
For example imagine being on Apollo 11 flying to the moon and you are 50,000 miles from the moon. How much magnification via an Earthbound scope would be needed to replicate that view?
Is there any sort of chart that shows these simulated distances relative to magnification?
  • ww321q likes this
#2 Michael Covington
Michael Covington
    Author
  • Loc: Athens, Georgia, USA
Posted 12 June 2019 - 11:03 AM
At 200x, it would seem to be 1/200 as far away as it really is.
It is 240,000 miles away.   So at 200x it would seem to be 12,000 miles away.
You don't need a chart.  All you need is division.
  • Greyhaven, Jon Isaacs, happylimpet and 4 others like this
#3 miniqtone
miniqtone
  • Loc: Central NC
Posted 12 June 2019 - 11:09 AM
Why, of course. Thanks for encouraging me to put my minute thinking-cap on this morning! :)
  • Jon Isaacs, happylimpet, Michael Covington and 2 others like this
#4 miniqtone
miniqtone
  • Loc: Central NC
Posted 12 June 2019 - 03:43 PM
OK here's another question.
Back to Apollo 11; when they were 12,000 miles from the moon, from there how long did it take them to achieve lunar orbit?
#5 jks2000
jks2000
Posted 14 June 2019 - 02:31 PM
I think 200x means 200 times bigger, not 200 times closer. The trigonometry means moving to 1/200 the distance increases the apparent size by less than 200x. No I can't remember the formulas! But there is an online calculator at https://planetcalc.com/1897/ that lets you play with calculating different apparent sizes from different distances and physical sizes etc. Assuming their math checks out anyway.
#6 Michael Covington
Michael Covington
    Author
Posted 14 June 2019 - 02:38 PM
The relation is exact at the center of the field. You will find a tiny difference over appreciable fields because we're actually dealing with tan(theta) rather than theta.  But the difference is tiny.
For a field 1 degree in diameter (0.5 degree in semidiameter), the angle itself and its tangent in radians differ by a factor of 0.99997.
Most telescope fields are much smaller than that.
Designers of wide-angle lenses, on the other hand, have to think about this.
#7 jks2000
jks2000
Posted 14 June 2019 - 03:08 PM
Makes sense. Like i said, I remember about the math but not exactly how to do it. :)
But at 200x the moon way exceeds the eyepiece tfov you're talking about. I dropped some rough ballpark figures for distance and size into that calculator tool, and it spit out something like 1/200th distance enlarges the apparent size of the image about 170x. Does that check out?
#8 Michael Covington
Michael Covington
    Author
Posted 14 June 2019 - 04:10 PM
Makes sense. Like i said, I remember about the math but not exactly how to do it. smile.gif
Not at all.  What assumptions is that calculator making?  And what do we mean by image?  I assume we're talking about the image as seen in the telescope vs. an equal apparent area of sky without a telescope.
#9 jks2000
jks2000
Posted 14 June 2019 - 05:05 PM
Interesting. I asked it for the angular size of an object 2200 miles in diameter at a distance of 250,000 miles. It gave 30 minutes 15 sec, which is about right. Then I changed the distance to 1250 miles (1/200) and it gave an angular size of 82 deg and change. (165x the original size).I think we were just approaching the OP question differently, I was picturing looking out the window of an orbiting spacecraft at 1/200 the distance, not just magnifying what was in the eyepiece. I agree completely with you that if you're just looking at whatever fits in the eyepiece, the relationship is essentially linear. Sorry if I made a hash of what I was saying. All that being said, hopefully the math that calculator tool is using wasn't sending me on a snipe hunt. :)
#10 Michael Covington
Michael Covington
    Author
Posted 14 June 2019 - 05:14 PM
Yes, you are looking at the angular size of a large object.  At 82 degrees angular size, the tangent is *appreciably* different from the angle itself.  I was thinking about what is actually seen in the telescope -- the craters look as though they are 200 times closer.   Compare a 200x telescope to a 1x telescope 200 times closer to the surface, but with the same field of view.
When you consider an object filling an appreciable part of the sky, trigonometry and perspective do get involved.
  • Asbytec and BFaucett like this
#11 cpsTN
cpsTN
  • Loc: Rutherford Co, TN
Posted 13 July 2019 - 01:18 PM
Why can't any discussion on here be simple? If you are at a power of 200x, wouldn't the Moon, or anything else, appear as though you were 200 times closer to it, which from what I am figuring should be 1,200 miles, not 12,000 miles. If I view something 50 feet away through 7x binos, won't I see the same view as if I were only about 7 feet away?
  • Steve Cox likes this
#12 Tom Glenn
Tom Glenn
  • Loc: San Diego, CA
Posted 13 July 2019 - 01:23 PM
You are correct.  There was a math error made earlier in this post and the quoted result is incorrect by an order of magnitude.  At 200x power, the moon will appear 200x closer, or 1/200 the distance.  So if it is 240,000 miles away, it will appear 1200 miles away.
Edited by Tom Glenn, 13 July 2019 - 01:23 PM.
#13 cpsTN
cpsTN
Posted 13 July 2019 - 01:30 PM
Yea, I win!   lol.gif  I figured there was a problem there. Thank You.
#14 Michael Covington
Michael Covington
    Author
Posted 13 July 2019 - 03:41 PM
Exactly, until you get close enough for the perspective to be different.  For example, if you could view the moon at 240,000 power, you would still see it in flat perspective, as if seen from very far away, not from the perspective that you would have from 1 mile above the lunar surface.
But that isn't significant until we get to magnifications much higher than our telescopes give.
#15 Keith Rivich
Keith Rivich
  • Loc: Cypress, Tx
Posted 04 August 2019 - 11:08 AM
For a simple description of image scale you are correct.
In reality though the moon, or any DSO, and its surroundings, is a two dimensional "picture" as seen from earth. In your analogy the resolution on the moon would increase with magnification (magnification equals physically closer). But it doesn't. Resolution is locked in by your equipment and actual distance to the object. Magnification makes the moon appear bigger but not closer. The two views are not the same.
That's why when viewing M31 at 1000x you don't see M32 behind you.
  • Heywood likes this
#16 Michael Covington
Michael Covington
    Author
Posted 04 August 2019 - 11:44 AM
So really we have 3 things going on when you move closer to an object in space:
(1) It looks bigger
(2) The perspective changes, e.g., very close to a planet you don't see its whole earthward face
(3) You see more fine detail
Changing the magnification of a telescope only replicates (1).  But the ratio of apparent distance is exactly the same as the magnification, which was the original question.  Changing the magnification of a telescope doesn't do (2) and it doesn't do (3) once you go above a certain magnification.
