A few shots from 6/11/2019
20 replies to this topic
#1 rigel123
rigel123
  • Loc: SW Ohio
Posted 12 June 2019 - 03:15 PM
Got behind. Actually did an animation but with passing clouds I decided it really wasn't worth posting! So full disk shot, Lunt LS60T DS, Atlas EQ-G, Skyris 236M, ScopeStuff .5 reducer Best 150 frames from 500. Click on image for larger view
Edited by rigel123, 12 June 2019 - 04:45 PM.
  • PhotonJohn, jwestervelt, RickV and 2 others like this
#2 rigel123
rigel123
  • Loc: SW Ohio
Posted 12 June 2019 - 03:16 PM
A very faint prom and an inverted close up of the surface:
  • Dagobert, torsinadoc, RickV and 3 others like this
#3 descott12
descott12
  • Loc: Charlotte, NC
Posted 12 June 2019 - 03:25 PM
What scope did you use for the third image of the nice closeup? That wasn't with your Lunt 60 was it?
#4 rigel123
rigel123
  • Loc: SW Ohio
Posted 12 June 2019 - 04:33 PM
Yes, that was with my Lunt 60 and a Meade 2x telenegative.  Thanks!
Edited by rigel123, 12 June 2019 - 04:37 PM.
#5 descott12
descott12
Posted 12 June 2019 - 05:01 PM
That is fantastic. I thought you would need more aperture for that level of detail.
#6 jwestervelt
jwestervelt
  • Loc: Phoenix, Arizona
Posted 12 June 2019 - 05:06 PM
Yeah, it is pretty impressive.  I haven't tried a barlow or anything because, well... i don't have one.  :(  I have a really nice Televue 2X Powermate with a really nice 2" barrel that won't fit into my really nice LS50THa.... bawling.gif  I might trade it out for something else... but I'm kinda worried about focus issues with these scopes.
#7 rigel123
rigel123
  • Loc: SW Ohio
Posted 12 June 2019 - 08:14 PM
It is amazing what you can get when seeing is good.  I have shots from previous years that show amazing details that I haven’t seen for quite a while!
#8 rigel123
rigel123
  • Loc: SW Ohio
Posted 12 June 2019 - 08:16 PM
Yeah, it is pretty impressive.  I haven't tried a barlow or anything because, well... i don't have one.  frown.gif  I have a really nice Televue 2X Powermate with a really nice 2" barrel that won't fit into my really nice LS50THa.... bawling.gif  I might trade it out for something else... but I'm kinda worried about focus issues with these scopes.
Is the focus issue due to the focuser itself?
#9 jwestervelt
jwestervelt
Posted 12 June 2019 - 09:30 PM
Well, yes?  The focusers for the scope, even aftermarket, don't have much travel on them.  I have EPs that won't come into focus, for lack of in focus or out focus, and i'm not sure how a barlow or other focal manipulator will play with my setup.
#10 RickV
RickV
  • Loc: Ottawa, ON, Canada
Posted 12 June 2019 - 10:33 PM
Well Done Warren!
Best,
Rick
  • rigel123 likes this
#11 rigel123
rigel123
  • Loc: SW Ohio
Posted 13 June 2019 - 06:22 AM
Does the 50 have the draw tube on the blocking filter like the 60 does?  I have to pull it out about 1 1/2” to use eyepieces and then push it in further to use with my camera to come to focus.
#12 PhotonJohn
PhotonJohn
  • Loc: Viera Florida
Posted 14 June 2019 - 11:23 AM
Great close-up detail. I have yet to get that close with my Lunt 60, but I'm working on it. Did you change your ROI on the close-up? If so, what scale did you use?
#13 rigel123
rigel123
  • Loc: SW Ohio
Posted 14 June 2019 - 11:47 AM
Thanks! Yes, I change the ROI to 1064 X 768, my Skryis has a max ROI of 1920 X 1200, and I use a 2X Telenegative. I can get 90 fps at the lower ROI
#14 jwestervelt
jwestervelt
Posted 14 June 2019 - 08:32 PM
Warren, my EPs that fail to focus are all due to lack of in focus, so backing out the diagonal will not help.
#15 rigel123
rigel123
  • Loc: SW Ohio
Posted 14 June 2019 - 08:40 PM
Ah, that’s a tougher one to solve for sure!!
#16 RickV
RickV
Posted 15 June 2019 - 07:03 AM
Lack of in focus with the Lunt LS50THa.
I suggest changing to a Borg focuser #7842 available from Hutech.
https://www.sciencec...org/focuser.htm
I had changed to the #7840 (M42 Helical Focuser S - M42P1 S) but it appears to be no longer available... that's OK, it had only 5mm of focus adjustment (not enough); you want some thing like 10mm of focus adjustment with the shortest possible overall length.
To use these 42mm focusers, you will need a couple of step up rings 35mm to 37mm and 37mm to 42mm.
Best,
Rick
#17 MAURITS
MAURITS
  • Loc: Belgium
Posted 17 June 2019 - 09:38 AM
Well done Warren.
#18 rigel123
rigel123
  • Loc: SW Ohio
Posted 17 June 2019 - 12:13 PM
Thanks Maurits!
#19 jwestervelt
jwestervelt
Posted 17 June 2019 - 01:14 PM
I can knock about 10mm of of the optical path if I got rid of that nosepiece on the diagonal.  It has a built-in spacer which kinda wrecks the ability to move the focus inwards.  I'm looking at replacing it with a low profile substitute at the moment, but I won't buy or make anything until I get my hands on a barlow and find out if it is necessary.
#20 sushi1128
sushi1128
Posted 17 June 2019 - 01:27 PM
very nice set ! Warren
#21 rigel123
rigel123
  • Loc: SW Ohio
Posted 17 June 2019 - 08:35 PM
Thanks Mike!
