Orion 8" f/8 RC Astrograph - disappointing results
32 replies to this topic
#1 nikivan
nikivan
Posted 12 June 2019 - 06:39 PM
I recently bought a brand new Orion 8" RC astrograph and I've been struggling to get any good images out if it. The scope was collimated by a very experienced person, so this is not the issue. The problem is that the stars look quite bloated. When carefully adjusting the focus it looks like the stars are about to get into focus, but then they turn into blobs again. Here is a snapshot taken directly from PixInsight work window with scale 1:1. This shows absolutely the best focus I am able to achieve. I am using ZWO ASI071MC Pro. There is also quite a variation from the center of the filed to the corners (will upload samples in the next posts). Is this is normal, or I've got a lemon? Please share your thoughts.
#2 nikivan
nikivan
Posted 12 June 2019 - 06:59 PM
#3 nikivan
nikivan
Posted 12 June 2019 - 07:02 PM
#4 nikivan
nikivan
Posted 12 June 2019 - 07:04 PM
#5 nikivan
nikivan
Posted 12 June 2019 - 07:05 PM
#6 TinySpeck
TinySpeck
  • Loc: Seattle area
Posted 12 June 2019 - 07:15 PM
Do you have any telecompressor or other devices in your optical chain?
#7 Jim Waters
Jim Waters
  • Loc: Phoenix, AZ USA
Posted 12 June 2019 - 07:39 PM
Are you using a FF?
#8 nikivan
nikivan
Posted 12 June 2019 - 07:41 PM
No, I don't. I have the telescope, two extension rings, the stock focuser and the camera train.
#9 Jim Waters
Jim Waters
Posted 12 June 2019 - 07:45 PM
Does Orion make a FF?
I would call Orion Tech Support about the focus issues.  The center should be in focus.
Edited by Jim Waters, 12 June 2019 - 07:46 PM.
#10 starhunter50
starhunter50
  • Loc: Tilbury,Ontario 42N , 82W
Posted 12 June 2019 - 07:46 PM
There is coma there for sure but im more concerned about the focus being way out.
are you using your Mask? (Bahtinov)
#11 starhunter50
starhunter50
Posted 12 June 2019 - 07:51 PM
Next time out , slew to Vega defocus in both direction and grab a shot of the star at center both in/out racked in/out .
defocus quite a bit. then post here.
  • nikivan likes this
#12 Jim Waters
Jim Waters
Posted 12 June 2019 - 08:10 PM
Excellent recommendation.
nikivan - Is there a UV/IR Block filter on the ASI071MC Pro?  If not try to get one and test 'with' and 'without' the filter.  This may be some of the problem causing the star bloat.  It will not fix the coma in the corners.
  • starhunter50 likes this
#13 TinySpeck
TinySpeck
  • Loc: Seattle area
Posted 12 June 2019 - 08:41 PM
It looks to me like the mirror adjustment isn't right somehow, since the appearance in each corner is so different.  Collimating RC scopes can be very tricky I hear (even though I haven't had to on mine).  You need to adjust mirror tilt, spacing, and co-axiality, and the adjustments interact.
Can you tell us a little more about the procedure?  Has the guy done RCs before?  What kind of equipment did he use?
#14 futuneral
futuneral
  • Loc: Phoenix, AZ
Posted 12 June 2019 - 09:35 PM
http://www.deepskyin...ure_Ver_1.0.pdf
Read staring at around page 11. Looks very much like what you're seeing.
#15 Bowlerhat
Bowlerhat
  • Loc: Melbourne
Posted 13 June 2019 - 08:37 AM
Isn't if it's focused properly you won't be able to see any donuts shape? since that's just an OOF shape.
#16 starhunter50
starhunter50
Posted 13 June 2019 - 12:12 PM
Which is why  i mentioned the Bahtinov mask at the outset.
  • Bowlerhat likes this
#17 starhunter50
starhunter50
Posted 13 June 2019 - 12:15 PM
please send me an Email in order for me to send you an  RC collimation instruction that make sense..
rcfmitch at gmail dot com
#18 nikivan
nikivan
Posted 13 June 2019 - 01:01 PM
Here is the first snapshot. The 500KB size restriction does not allow me to post the entire field.
Yes, I have UV/IR filter. It is 2" Baader UV/IR-Cut/L. Are you suggesting the issues may be related to it?
The collimation was done during the day, on an artificial star. I was shown the out of focus rings not being symmetrical before the procedure, and quite symmetrical after it. Only the secondary mirror was adjusted. I am not sure if adjusting the primary is even possible on this scope.
#19 nikivan
nikivan
Posted 13 June 2019 - 01:10 PM
Out.
#20 Jim Waters
Jim Waters
Posted 13 June 2019 - 01:55 PM
No, but without you will likely get bloating.
Could the ASI017MC Pro be tilted?
#21 nikivan
nikivan
Posted 13 June 2019 - 02:40 PM
I can't tell if the camera is tilted. The extension rings are tightened very well and there is absolutely no play in the camera train. But even if it was a little bit of camera tilt, that will not explain the reason for inability to achieve sharp focus in the middle of the field.
#22 starhunter50
starhunter50
Posted 13 June 2019 - 02:41 PM
Nikivan, i need you to defocus Vega Even more ....and lower the exposure. let me show you.
if you can use Sharpcap 3.2
the bottom image is what you want.  yes the primary can be adjusted.
https://drive.google...iew?usp=sharing
#23 Jim Waters
Jim Waters
Posted 13 June 2019 - 03:21 PM
You are correct about the focus problem.  You may have more than 1 issue.  The ASI071MC Pro has tilt adjustment screws. I was referring to that.
Edited by Jim Waters, 13 June 2019 - 03:22 PM.
#24 starhunter50
starhunter50
Posted 13 June 2019 - 03:57 PM
Collimating RC s is NOT for the faint at heart...
Here is what it looks like , looking down a Cheshire EP after perfect collimation.
All the circles are concentric and the spider vanes line up.
took 4-5 hours but was worth it.
Edited by starhunter50, 13 June 2019 - 04:03 PM.
#25 Stephen Kennedy
Stephen Kennedy
  • Loc: California
Posted Yesterday, 07:53 AM
Here is a 30" unguided defocused image of Vega taken with my TPO RC6 on a Vixen Super Polaris GEM with the OTA   right out of the box with no collimation done by me.
All of these RCs and CCs whether sold by Orion, TPO or AT are all made by GSO at their factory in Taiwan,
