AT80mm F/7 coming
127 replies to this topic
#26 JIMZ7
JIMZ7
  • Loc: NE flight path of DTW
Posted 15 June 2019 - 08:34 PM
Orion ED80 used a 100mm tube though. Which makes it a little bulkier.
I had the Orion 100mm f/6 scope. Yes it did use the same tube & weight about the same as Orion's 80mm f/7.5 ED. But the AT80 f/7 still sounds promising. I wonder if any AT88 or AT90 in the future using the same kind of glass?
  • Mark9473 and Jond105 like this
#27 Jaimo!
Jaimo!
  • Loc: Exit 135 / 40° North
Posted 15 June 2019 - 10:52 PM
Jaimo!
  • jmclaugh2001 likes this
#28 Astronomics
Astronomics
    Vendor: Astronomics
  • Loc: Right Here
Posted 15 June 2019 - 11:48 PM
There won’t be one in between as it would just get things to confused size wise.
#29 JIMZ7
JIMZ7
Posted 15 June 2019 - 11:52 PM
That's true Michael.
#30 Astronomics
Astronomics
    Vendor: Astronomics
  • Loc: Right Here
Posted 16 June 2019 - 12:38 AM
The thought is solid, but it is too small a step. I do however appreciate the input.
  • Jon Isaacs likes this
#31 CHASLX200
CHASLX200
  • Loc: Tampa area Florida
Posted 16 June 2019 - 05:50 AM
So would i need a 80 AT if i already have a 90mm W/O F6.2?
#32 Auburn80
Auburn80
Posted 16 June 2019 - 08:42 AM
Probably not unless you find the WO to be "chunkier" than you'd like. Is the WO a triplet? If so, it might acclimate a little slower but in your area that's probably not an issue.
#33 CHASLX200
CHASLX200
Posted 16 June 2019 - 08:43 AM
It is a 2 element lens. It is heavy, but a LX70 holds it fine and i already a 72mm SW ED. But i like trying new stuff for kicks.
#34 Auburn80
Auburn80
Posted 16 June 2019 - 08:58 AM
Me too. I do see this 80 as a solution to a desire for a good gng for not too much $. I want to keep my Oracle pristine and my 102A while very nice on my SP mount, is not quite as maneuverable as this 80 would be on a small alt-az.
#35 gene 4181
gene 4181
  • Loc: n.e. ohio
Posted 16 June 2019 - 09:18 AM
  • Lewis Cason and Agatha like this
#36 kksmith
kksmith
  • Loc: Montana
Posted 16 June 2019 - 11:53 PM
Is the length with lens shade extended and retracted know yet? This sounds like a very attractive acquisition.
Edited by kksmith, 16 June 2019 - 11:54 PM.
#37 jmclaugh2001
jmclaugh2001
  • Loc: Ohio
Posted 19 June 2019 - 09:27 AM
Do I need to put a deposit down?
John
#38 russell23
russell23
  • Loc: Upstate NY
Posted 19 June 2019 - 09:34 AM
I imagine the SV Access is a good guide on that.  The 80 Access is 18” retracted and 20.5” extended.
#39 Astronomics
Astronomics
    Vendor: Astronomics
  • Loc: Right Here
Posted 19 June 2019 - 09:37 AM
John
If you order online the computer will authorize the full amount, not much we can do about that as it is a function of the credit card company.  If you call in an order we don't charge until the scopes have cleared customs.
#40 Auburn80
Auburn80
Posted 19 June 2019 - 09:40 AM
Hmmm, that sounds like an awfully short dew shield. When retracted, is the front of the shield just ahead of the objective?
#41 russell23
russell23
  • Loc: Upstate NY
Posted 19 June 2019 - 10:03 AM
Just a little.  I will check later.
  • Auburn80 likes this
#42 Auburn80
Auburn80
Posted 19 June 2019 - 10:09 AM
Those are definitely the specs SV gives. Just curious . . .
I wonder what those specs are for the AT 80ED.
#43 russell23
russell23
  • Loc: Upstate NY
Posted 19 June 2019 - 10:32 AM
My guess is that the OTA will be essentially the same but the AT version is using FK-61 whereas the SV version uses FCD100.
#44 Spacefreak1974
Spacefreak1974
  • Loc: Indianapolis, IN
Posted 19 June 2019 - 11:06 AM
I wonder if the AT 80ED F/7 will be similar to the Lunt 80ED. My understanding is that the Lunt uses FK-61 glass as well? The Lunt comes with a case, but the Astro-Tech comes with a nice diagonal and better tube rings and dovetail. THe focuser appears different, but both appear to be made by Kunming. The AT will be $50 less and have nicer mechanicals as well
Edited by Spacefreak1974, 19 June 2019 - 11:07 AM.
#45 NYJohn S
NYJohn S
  • Loc: Northport, NY
Posted 19 June 2019 - 11:30 AM
I suspect it will be very similar to the SV80A as far as build goes. I would have jumped on one of these if I knew they were coming out but I just picked up a SV80A. Comparing it to my AT102ED it seems the focuser, tube rings and quality of the fit and finish is the same. One is matte finish the other is glossy. That makes the AT 80ED quite a bargain if you ask me. Here's a side by side photo of the 2.
The SV80A has a 5-1/8" dew shield but only overhangs the front objective by 3-1/4". The size with the dew shield retracted is actually 18-5/8" with the 1/1/4" adapter installed but no diagonal. 21-1/4" with the dew shield extended.
I didn't see anything in the AT80ED description that mentions it coming with a diagonal. The AT102ED didn't. I don't know what kind of focuser is on the Lunt but the one on my AT102ED very smooth and precise. For $399 this is a fantastic deal.
SV80 & AT102ED
  • russell23, KevH and Auburn80 like this
#46 belgrade
belgrade
  • Loc: Far North SA, TX
Posted 19 June 2019 - 09:24 PM
#47 belgrade
belgrade
Posted 19 June 2019 - 09:25 PM
The AT80ED doesn’t come with a diagonal.
#48 Spacefreak1974
Spacefreak1974
Posted 20 June 2019 - 07:37 AM
Ah I think they edited the description. I could have sworn that it said it came with one the other day
It says...
An optional Astro-Tech 2" dielectric star diagonal #AT2D will give you the same 99% reflectivity performance with 2" eyepieces.
#49 jcj380
jcj380
  • Loc: 42N 88W
Posted 20 June 2019 - 07:58 AM
I am suddenly thinking this would make a GREAT birthday present! I might have to start dropping some major hints to my husband...
I'm told (repeatedly) that hints don't work on males.  Tell him straight up.  wink.gif
  • mrsjeff likes this
#50 russell23
russell23
  • Loc: Upstate NY
Posted 20 June 2019 - 08:09 AM
My wife and I raised 4 daughters so I've managed to attain what for men would be the equivalent of a PhD in hint reading.   Unfortunately, by the standards women have for hint reading that amounts to the equivalent of a 6th grade education.  :)
  • Phil Cowell, jcj380 and Celerondon like this
