cant get focus on X5 Barlow GSO
2 replies to this topic
#1 karimooo
karimooo
Posted 16 June 2019 - 06:25 AM
I tried to use the GSO x5 Barlow on the 200mm F4 astrograph reflector but I could not get focus neither with a DSLR or IMX224 camera
any way I can get focus with the X5 barlow to photograph the planets.
#2 sg6
sg6
  • Loc: Norfolk, UK.
Posted 16 June 2019 - 09:27 AM
Is the problem insufficent focuser movement, or, the image gets better then gets worse and the "best" point is not sharp?
Actually would not expect a 5x barlow to produce a good image, especially as the scope is fast and all you are doing is making it slow, not something it was designed for or to do. Theory says a 5x barlow will produce an image equal to a 4000mm scope. However reality is that the result will be garbage. Optically most barlows are not great.
You might manage better with a 2x or 2.5x TV powermate.
As the barlow sits inside the focal plane it is acting as a negative lens so should push the image out from the usual position, so very likely you need extra travel outwards on the focuser.
#3 karimooo
karimooo
Posted 17 June 2019 - 04:50 AM
that what I was expecting that I get 4000mm F20 from 8" telescope being it slow it does not matter as I want to photograph the planets so F20 is find but the issue is will I reach to focus and where should I keep the extender between the camera and the barlow or the barlow and focuser?
