Reducer for Tak Mewlon 180
9 replies to this topic
#1 bdg
bdg
Posted 19 June 2019 - 12:40 AM
I am planning to use Mewlon 180 for NV (visual) - need a reducer faster than Takahashi’s Mewlon compatible  0.8x reducer. Any idea if Celestron 0.6x reducer or something generic works.
#2 chemisted
chemisted
Posted 19 June 2019 - 06:19 AM
Have you considered the Astro-Physics CCDT67?
#3 bobhen
bobhen
Posted 19 June 2019 - 06:44 AM
I use an Antares .7 2" reducer ($89) with my NVD Micro and Mewlon 210. Don't get the 2" .5 there is too much edge distortion. Got my from Scopestuff.
HERE is a link.
Bob
  • bdg likes this
#4 bdg
bdg
Posted 19 June 2019 - 08:42 AM
I looked at it but didn’t know if it works for visual.
#5 chemisted
chemisted
Posted 19 June 2019 - 03:20 PM
It should work just fine.  It's only requirement is to have a heathy focal ratio.  I have used mine visually with my f/9.3 OGS RC-10 and NVD Micro and it worked great with pinpoint stars throughout the FOV.
#6 Gavster
Gavster
Posted 19 June 2019 - 04:47 PM
Will you also be using your c11 edge with the nv monoculars? My c11 edge with the 0.7x edge reducer is one of my favourite nv scopes.
#7 bdg
bdg
Posted 19 June 2019 - 07:22 PM
Thanks, I think its inexpensive enough to give a try, figuring out the spacing could be challenging.
Not sure due to portability issues. I don’t have edge 11 reducer either.
Edited by bdg, 19 June 2019 - 07:23 PM.
#8 chemisted
chemisted
Posted 19 June 2019 - 08:09 PM
I don't have the Tak so I cannot comment exactly but I wouldn't worry about the spacing very much.  The key thing with these reducers and NV is will they come to focus.  I have fixed mirrors on my RC-10 and, while the backfocus of the instrument is quite good, these NV devices suck up a lot of backfocus and are troublesome in that regard sometimes.  My configuration was to screw the CCDT67 onto my Baader BBHS silver T-2 diagonal with a 2" to T-2 thin adapter and then use a T-2 to C-mount adapter for the NVD Micro connection.  This worked well as far as coming to focus is concerned.  I may not have achieved the full .67X reduction but I think I came pretty close.
  • bdg likes this
#9 bdg
bdg
Posted 21 June 2019 - 02:45 PM
just ordered CCDT67, is there any difference where the reducer is inserted in the optical train i.e. before or after diagonal .
#10 chemisted
chemisted
Posted 21 June 2019 - 04:59 PM
Before the diagonal (close to the NV device) will give a smaller reduction.  The arrangement that I described will probably get pretty close to 0.67X.  I also have the GSO 0.75X reducer claimed to be for RCs but I have used it very successfully with my two refractors when used in afocal mode with the TV 55mm Plossl.
Edited by chemisted, 21 June 2019 - 07:06 PM.
