Attaching Field model to Dovetail
8 replies to this topic
#1 JimP
JimP
  • Loc: USA
Posted 19 June 2019 - 02:20 PM
I have purchased a Questar Field model and wonder if anyone has a quick solution to attaching the scope to a Losmandy or Vixen style mounting plate? AP 400 GOTO mount.
Edited by JimP, 19 June 2019 - 02:21 PM.
  • Matt Looby and agmoonsolns like this
#2 photoracer18
photoracer18
  • Loc: Martinsburg, WV
Posted 19 June 2019 - 03:11 PM
Assuming that the Field model has a block on the bottom with a 1/4-20 hole this should work:
https://www.telescop...c/38/p/7388.uts
#3 JimP
JimP
  • Loc: USA
Posted 19 June 2019 - 06:15 PM
Is that the standard Vixen style mount?
  • Matt Looby and NC Startrekker like this
#4 NC Startrekker
NC Startrekker
  • Loc: Sandhills of NC
Posted 19 June 2019 - 06:24 PM
Jim, yes it is. Alan
#5 JimP
JimP
  • Loc: USA
Posted 19 June 2019 - 06:46 PM
Excellent!!
Thank you very much!
Ordered.
#6 Gregory Gross
Gregory Gross
  • Loc: Pacific Northwest
Posted 19 June 2019 - 08:24 PM
Congratulations on getting a Questar! I know you mentioned in that thread on the Q7 Astro that you have been aspiring to own one. Let us know about it when you receive your field model.
#7 BillHarris
BillHarris
  • Loc: northwest Alabama
Posted 19 June 2019 - 08:27 PM
It would have a tendency to twist and you'd need to also to install a dowell or pin to keep it aligned.
#8 Kevin Barker
Kevin Barker
  • Loc: Auckland, NZ
Posted 19 June 2019 - 09:12 PM
I also have a field model which is now on a fork mount.
When first using it I attached it using the 1/4- 20 pin to a Zeiss dovetail. To prevent the twisting when tightening and prevent scratching/marring the bottom of the field scope I glued a short section of rubber from a bike inner tube to the dovetail.
It worked a treat. The dovetail I used was a Zeiss 08 dove, similar in size to a Vixen.
Edited by Kevin Barker, 19 June 2019 - 09:15 PM.
  • Matt Looby likes this
#9 JimP
JimP
  • Loc: USA
Posted 20 June 2019 - 05:47 AM
OK, I will definitely let you know when the scope arrives and will work on figuring out a way to stop twisting of the scope. Gluing a small piece of rubber from an inner tube or, perhaps a piece of leather from an old notebook just might work. Thanks!!
