Most Accurate current catalog for brighter than Mag6 stars
10 replies to this topic
#1 Anurag Shevade
Anurag Shevade
    Starfleet Astrosystems
Posted 22 June 2019 - 12:03 AM
Hi all!
Seeking info on which is the most accurate star catalog in terms of proper motion and epoch references to current?
I know GAIA is the latest and the most accurate one but it looks like it does not have entries for bright stars. Checked Sky Safari, there is no cross ref GAIA id for bright stars and CDC download options also mention no GAIA stars for bright HIP catalog stars. Is there any other modern catalog in currnet decade which has successfully measured bright stars?
Clear Skies!
Edited by Anurag Shevade, 22 June 2019 - 01:12 AM.
#2 han.k
han.k
    ASTAP Software
  • Loc: the Netherlands
Posted 22 June 2019 - 02:00 AM
Up to magnitude 6  best complete database is Tycho/Hip. This is second to Gaia but the only catalog complete in the bright end. The Epoch is 1991.25 so the date of observation but most program will use the proper motion to calculate the position for any epoch.
Up to magnitude 6 is very modest. Note there are "ready to use" Gaia & Tycho hybrid databases for Skychart/CDC, ASTAP and HNSKY. For compactness (a few hundred megabytes for up to magnitude 17), the epoch is fixed at 2022.
For Gaia star ID's are no longer practical. The catalog number changes with every Gaia data release. It is better to reference the stars using IAU designation based on the recorded RA, DEC position as hhmmss.s+ddmmss.
Han
Edited by han59, 22 June 2019 - 07:22 AM.
  • Jon Isaacs and Anurag Shevade like this
#3 Anurag Shevade
Anurag Shevade
Posted 22 June 2019 - 07:00 AM
Thanks for the info Han.
The hybrid database is indeed very compact for the magnitude coverage it does.
Nice that many software can use it.
Clear Skies!
#4 catalogman
catalogman
Posted 22 June 2019 - 01:17 PM
For Gaia star ID's are no longer practical. The catalog number changes with every Gaia data release. <snip>
Another problem with GAIA is that it is complete only from about G=12 to G=17; brighter stars blend together
due to over-saturation or are missing, so their distribution does not match the sky.
Up to magnitude 6  best complete database is Tycho/Hip. This is second to Gaia but the only catalog complete in the bright end. <snip>
Actually, some of the well-known catalogues (such as the UCAC4 and NOMAD) are complete at the bright end, but only because the brightest stars were added afterward:
https://irsa.ipac.ca...CAC4/ucac4.html
https://www.usno.nav...on/catalog-info
But extracting the brightest stars from these catalogues wouldn't satisfy the OP because there are no Bayer/Flamsteed labels.
Other than the YBS (from 1991), the only other catalogue that might satisfy the OP is the HYG:
http://www.astronexus.com/hyg
If Column N is sorted numerically, there are 8,827 stars brighter than mag 6.5.
--catalogman
  • Anurag Shevade likes this
#5 han.k
han.k
    ASTAP Software
Posted 22 June 2019 - 02:54 PM
Yes it is correct that still some stars are missing in Gaia DR2 but completeness  is as good or better as other catalogues. The Tycho-2 supplement linked in my previous mail makes it almost perfect.
The UCAC4 and YBS are build on Tycho/Hip data
#6 Anurag Shevade
Anurag Shevade
Posted 22 June 2019 - 04:20 PM
May be some other wavelength than optical band may provide accuracy for bright stars movement across the frame of reference by not saturating sensors.
Was looking for it for a very different purpose. We will soon get information about it 1st hand.
Clear Skies!
#7 Anurag Shevade
Anurag Shevade
Posted 22 June 2019 - 04:27 PM
--catalogman
Thanks for HYG reference Catalogman!
Edited by Anurag Shevade, 22 June 2019 - 04:30 PM.
#8 Patrick Chevalley
Patrick Chevalley
Posted 23 June 2019 - 04:50 AM
The default bright star catalog in CdC is the Extended Hipparcos Compilation (XHIP) available from http://cdsarc.u-stra...-bin/cat/V/137D
The main advantage over the standard Hipparcos catalog is the addition of radial velocity from other source that allow much more precise proper motion computation for long time range.
It also add more photometry and spectral class information.
#9 Anurag Shevade
Anurag Shevade
Posted 24 June 2019 - 05:00 AM
Dear Patrick
Thank you so much for XHIP capabilities info. With this reference, read one very interesting page about some of the aspects of how people made the data of original HIP more accurate.
http://sci.esa.int/h...cos-catalogues/
Also glad that its available in CdC as default. When right clicked on object, the context menu of CdC also provides all the info about object with nice selectable text neatly organized with all alternate catalog names in separate lines. This arrangement helps a lot and we were able to effortlessly extract into excel for further processing.
Thanks to you for the great work of creating this software and adding new capabilities in it with thorough consistency spanning decades! Have found that CdC is almost always the first planetarium software to incorporate any new catalog that becomes available. I like this capability in addition to many other things.
Regards
Anurag
Edited by Anurag Shevade, 24 June 2019 - 05:05 AM.
#10 catalogman
catalogman
Posted 23 August 2019 - 10:48 PM
For the OP, attached is a catalogue of 8,482 stars in XHIP that are mag V=6.5 or brighter (limit same as the YBS).
The data columns refer to the info from SIMBAD:
#MAIN_ID......main identifier
#RA_2000.0....ICRS RA (ep=J2000)
#DEC_2000.0...ICRS Dec (ep=J2000)
#PM(RA).......Proper motion in RA (mas/yr)
#PM(DEC)......Proper motion in Dec (mas/yr)
#RV...........Radial velocity (km/s)
#PAR..........Parallax (mas)
#B............B-magnitude
#V............V-magnitude
#OTYPE........Object type
#SPEC.........Spectrum type
Only 80 of the 8,482 stars are missing one column of information, so the catalogue
is more than 99% complete.
Bayer and Flamsteed labels from SIMBAD are also included.
--catalogman
Edited by catalogman, 24 August 2019 - 06:28 AM.
  • daw316 likes this
#11 Anurag Shevade
Anurag Shevade
Posted 27 August 2019 - 05:34 PM
Dear Catalogman
thanks a lot for catalog with all the info!
Regards
Anu
  • daw316 likes this
