Eyepieces and Accessories
Just about every lens and barrel was either taken off or put with the wrong assembly.
Therefore, as much as I like to take photos as found, I just had to match up every item to acess what I had.
I was relieved that the finder's objective remained intact, plus it's eyepiece and all of the adjusters were accounted for.
The finder's tube is resting on the mount's Alt-Az slow motion collar to show a flattened spot.
It's already been fixed and tested. It has no cross hairs but it works.
Why the threads inside don't start at the edge is puzzling, since they barely catch the ones of the eyepiece.
Everything was backwards with these. The 6mm lens was under the 10-20mm cap and on the wrong barrel.
The 10-20mm convertible is missing a lens so I'm not sure I have the right combination to make either one of the versions work?
The Goto's diagonal had the Porro's shorter black barrel fitted over it's chrome barrel which was cross threaded on.
Both barrels on the spare diagonal were removed. The black plastic one was threaded into the Porro.
The Goto's reveal where the black barrel threads on is chipped a bit, but thankfully it doesn't interfere with it threading on correctly. I suppose it was due to sloppy handling while someone was forcing it on.
It's likely that the spare diagonal is a Diamond Z (Tanzutsu Optical), since two Diamond Z eyepieces and a Barlow were included.
The Porro Prism now with the correct black barrel fitted.
Included spare eyepieces.
Again, the 20mm cap was on the 6mm EP and the 20mm's inner works was extremely cross threaded.
They must be older Diamond Z's, since the caps are metal.
The Unitron 7mm is a nice bonus, since I didn't have that size.
As is the SR 5mm which will help make my Manon complete.
The tall one in the back is a SR 4mm is likely a recent one of Chinese origins.
Mostly Junk Barlows. The middle one might have come from a Mayflower or Manon.
I believe it's the type they used, so once again another part for my Manon's kit.
The bottom one is empty.
Original silca packs are a nice final touch.
Now all of this stuff can be be disassembled and cleaned.
Edited by Kasmos, 24 June 2019 - 02:44 AM.
