APM 140 - Switch 2.5" for 3.7" Focuser
8 replies to this topic
#1 troy6666
troy6666
  • Loc: Washington DC and Virginia
Posted 23 June 2019 - 11:41 AM
Hello all:
I want to switch my 2.5" for the 3.7" focuser.  I wanted to order it from APM, but I was told the baffles were different so they can't be switched.  This really doesn't make much sense to me since the telescope is available with either focuser, and I doubt there is any difference between the OTAs.
Does anyone know if this is a direct switch, or is a different adapter needed to make the connection to the OTA?
Thanks much
#2 aa6ww
aa6ww
  • Loc: Sacramento, Calif.
Posted 24 June 2019 - 02:47 AM
I seriously doubt there is a baffle difference. I have the APM 152ED with the big focuser and its rock solid. It even holds my 9mm 120 deg ES Eyepiece very steady, and thats a beast of an eyepiece.
...Ralph
#3 ris242
ris242
  • Loc: Wellington, New Zealand
Posted 24 June 2019 - 01:02 PM
...Ralph
#4 Artimus183
Artimus183
  • Loc: Atlanta, Ga
Posted 07 November 2019 - 09:40 PM
Noob question perhaps, but I assume the 3.7" can actually take it (its a 3" barrel) with the proper adapter while the 2.5" couldn't?
#5 junomike
junomike
  • Loc: Ontario
Posted 08 November 2019 - 08:05 AM
Technically that is correct however I'm not sure the 3.7" will fully illuminate the light cone.  Most likely it would.
  • Artimus183 likes this
#6 junomike
junomike
  • Loc: Ontario
Posted 08 November 2019 - 01:22 PM
Just received a PM from Markus.
Turns out the OTA's are different lengths with the 3.7" OTA being shorter so adding a 3.7" Focuser to an OTA originally shipped with a 2.7" will shorten the back-focus.
Also, the baffles are different so the 2.7" OTA has a smaller fully illuminated FOV (as I was worried about).
  • eros312 and Artimus183 like this
#7 Artimus183
Artimus183
  • Loc: Atlanta, Ga
Posted 09 November 2019 - 12:44 AM
Thanks for letting me know. Hadn't considered the light cone..
Asking because I'm planning going for the 140 w/ 3.7" even though I plan to do Visual. Just sounds like a better, overall more flexible part (at a cost obv.). Would you agree, or are there negatives about a bigger focuser?
Art
Edited by Artimus183, 09 November 2019 - 02:34 AM.
  • SteveG likes this
#8 junomike
junomike
  • Loc: Ontario
Posted 09 November 2019 - 09:21 AM
Art
I'd go the 3.7" version even if some consider it overkill.  I hate being limited and if you ever consider using EP's with larger field stops then 46mm, you'll be ready.
Also, IME the large the focuser the less stress it has  when lifting the same weight as a smaller (equally made) focuser.
#9 dscarpa
dscarpa
  • Loc: San Diego Ca.
Posted 09 November 2019 - 03:41 PM
  I recently got a Vixen130ED SS with a Moonlite that's heavy duty and might fit your scope if the 2.5" R&P doesn't work out. I suspect the 2.5" R&P on my CM 90 III is similar to the APM and I've been very happy with it so far.  As a 66 year old visual observer and one who carries all his scopes around on their mounts I prefer the lighter weight of a 2.5" on my refractors. I've never had a problem with them  or the Crayfords on my SCTs handling the 20 ES100 and 31 ES82 which are my heaviest eyepieces. David
