TS-Optics 61EDPH - 5-Element Flatfield Apo 61 mm Aperture F/4.5
52 replies to this topic
#1 aneeg
aneeg
  • Loc: Nesodden, Norway
Posted 24 June 2019 - 09:20 AM
https://www.teleskop...ging-apo.kl.jpg
This one looks interesting and a perfect match with a CEM 40.
Arne
#2 HydrogenAlpha
HydrogenAlpha
  • Loc: Singapore
Posted 24 June 2019 - 09:50 AM
This is a nice scope indeed, and a nice alternative to the redcat. Don't exactly see how it is a "perfect match" for the CEM40 though.
#3 aneeg
aneeg
Posted 24 June 2019 - 11:04 AM
Portability! A very good travel combination.
Arne
#4 junomike
junomike
  • Loc: Ontario
Posted 24 June 2019 - 01:43 PM
Would make a nice Binoscope!
  • psandelle and aneeg like this
#5 aneeg
aneeg
Posted 25 June 2019 - 11:02 AM
And with a 2.5» RP focuser this Red Cat is definitely a step up re the other Red Cat.
Arne
#6 GlenM
GlenM
  • Loc: Lancashire England
Posted 26 June 2019 - 09:50 AM
Made by SharpStar. Got one on order without the flattener/reducer. Just different badging.
Glen.
Edited by GlenM, 26 June 2019 - 09:54 AM.
#7 25585
25585
Posted 28 June 2019 - 08:32 AM
Arne
Maine Coon version?
  • aneeg likes this
#8 F.Meiresonne
F.Meiresonne
  • Loc: Eeklo,Belgium
Posted 26 December 2019 - 07:15 AM
https://www.365astro...-flattener.html
Seems the same scope
but a huuuuge price difference.
Also the TS version seems to miss 2" and 1.25" reducer
Sure throws up questions..
#9 F.Meiresonne
F.Meiresonne
Posted 26 December 2019 - 07:17 AM
Still I am worried about CA. I don't see it in my F/7 (FPL53), this Sharpstar seems also to have a FPL53 doublet but it is at F/5.5...
#10 GlenM
GlenM
Posted 26 December 2019 - 08:36 AM
I don't see much CA in mine. You really have to look for it.
Glen.
#11 GTom
GTom
Posted 26 December 2019 - 01:29 PM
I am no optics guru, but maybe the additional elements in the reducer keep the CA at bay? It's designed specifically for this scope.
#12 F.Meiresonne
F.Meiresonne
Posted 26 December 2019 - 01:42 PM
I doubt this, as the reducer helps :
1 for a flat field in this case
2 reduce the F
actually it is a focal reduces and field flattener in one piece.
then again i am not a specialist either ...so ...i might be wrong
Better is to see what the experiences are from owners.
It looks for AP tempting, it is fast , so easier to deal with if you don't guide...because of the fast F
but it remains a doublet, FPL 53 yes  but at this focal ratio, some slight color may appear..
#13 Benach
Benach
Posted 26 December 2019 - 05:24 PM
Here someone with the optical knowledge. A reducer/flattener can be designed to reduce CA. However, it then only works for a particular set of glass types in the objective. This explains why the Massimo Riccardi reducers/flatteners work primarily on the APM/LZOS objectives and the telescopes with the same objective but different tube such as some models of Officina Stellare. They will not work, at least not by default, on the TEC apochromats.
  • F.Meiresonne and psandelle like this
#14 Ballyhoo
Ballyhoo
  • Loc: San Diego
Posted 26 December 2019 - 08:08 PM
Are we talking about a doublet or quadruplet astrograph?. I for one am quite interested in a widefield astrograph -- not a finderscope looking item likethe Redcat, but that 61mm, or, .
This here:
https://www.primaluc...quadruplet.html
Edited by Ballyhoo, 26 December 2019 - 08:08 PM.
#15 GTom
GTom
Posted 27 December 2019 - 02:44 AM
Quadruplet means the flattener is integrated, nothing more.
  • F.Meiresonne likes this
#16 F.Meiresonne
F.Meiresonne
Posted 27 December 2019 - 03:38 AM
This here:
Doublet (FPL53) for the lens + 3 lenses for focal reducer/flattener unit
So 5 lenses, that makes a pentadruplet or something..how should i call it
They have also a 76 mm version , that one has six lenses 3 for the front lenses + again 3 lenses for the reducer/flattener.
http://www.sharpstar...n/edph/274.html
Gorgious things...
Edited by F.Meiresonne, 27 December 2019 - 03:49 AM.
#17 F.Meiresonne
F.Meiresonne
Posted 27 December 2019 - 03:41 AM
Interesting!
The reducer/flattener in this unit is develloped for those scopes, i don't think they are usable in something different
Here is a link to their website to download  a jpg  (zipped)
http://www.sharpstar...n/download.html
It explains how to screw in filters, but you can see that the reducer/flattener for both kind of telescopes is different
(chinese name jpg file, open it, and thank God it is in English)
Edited by F.Meiresonne, 27 December 2019 - 03:46 AM.
#18 F.Meiresonne
F.Meiresonne
Posted 27 December 2019 - 03:50 AM
correct!
#19 HydrogenAlpha
HydrogenAlpha
  • Loc: Singapore
Posted 27 December 2019 - 07:08 AM
Yes it's a doublet, but at these small apertures CA is likely very well managed even at f/4.5.
Calling it a quintuplet, while not technically wrong, is misleading imo. With all the 3 to 4 element reducer/flatteners these days, it doesn't really mean anything when considered in that context.
#20 HydrogenAlpha
HydrogenAlpha
  • Loc: Singapore
Posted 27 December 2019 - 07:12 AM
Conceptually you're right of course.
However, the Riccardi reducers are marketed as a universal reducer. There is a whole range of LZOS objectives available at a wide range of apertures and focal lengths. The only difference is the optimal backfocus for each model. They are also marketed to work with the TEC apos with appropriate threading adapters, but no modifications to the optical design.
I don't think the Riccardi reducers were designed to reduce CA in any telescope. The LZOS objectives are all triplets and already have fantastic colour correction.
#21 GTom
GTom
Posted 28 December 2019 - 07:43 AM
That's correct. If it did, it would actually introduce CA in case of many triplets it is usually paired with.
#22 F.Meiresonne
F.Meiresonne
Posted 28 December 2019 - 10:46 AM
This scope is a FPL53 doublet.
They have a bigger brother, that , is a triplet, comes also with a reducer/FF
I ordered anyway.
I has to come from the UK, the supplier there offers temporarly 10 % discount, together with shipping cost and an adapter for my eos camera thisis way way lower then any other here in Europe, for the moment
Only it will take time to get it, they are out of reducers, shipment should come in within 10 days but guess in practice it might take weeks even months..but i can wait...
  • GlenM likes this
#23 F.Meiresonne
F.Meiresonne
Posted 28 December 2019 - 10:49 AM
I thought so too. Any lens impose CA, only thisones are close to the focal plane , and maybe therefore the impact is limited.Or wrong guess?
#24 GlenM
GlenM
Posted 29 December 2019 - 06:56 AM
I ordered anyway.
Did you buy from 365astronomy Freddy?
Glen.
#25 F.Meiresonne
F.Meiresonne
Posted 29 December 2019 - 07:11 AM
Yes Glen
Price for the momen for that scope a very low, it is on sale 10% off until 1 st of Januari, so i went for it. But they run out of reducers so i will have to wait until those come in.
My wife is a bit mad grin.gif  as i said i did not need anything else anymore but why buy   six months later and pay 100-120 more then,it just does not make any sense..
I have a nice little F/6 70 mm scope that is really good visual but for AP the blue halo's around stars is not nice..not nice at all, that disturbs me more then in visual mode.
The sharpstar is a doublet ut it is FPL53,hope that will remedy it sufficient. My TS F/7 102 mm shows no color at all.
Edited by F.Meiresonne, 29 December 2019 - 07:17 AM.
