Z103 First Light - Where's my dust? Iris Nebula
7 replies to this topic
#1 mewmartigan
mewmartigan
  • Loc: outside of Pittsburgh, PA
Posted 24 June 2019 - 09:22 AM
Hi All,
First time out with my Zenithstar 103. Great scope and the CEM25p handles it no problem. Over 2 nights I captured 4.5 hours of the Iris Nebula and lost some subs due to airplane streaks and clouds.
Here is my poor attempt at processing 4 hours of data in Photoshop. 83 subs, 3 minutes each (gain 50 offset 10) at -10deg.  30 each dark/flat/bias.
https://photos.app.g...mX1tvBECacLZtt6
I feel like I should see a lot more dust. I know I shouldn't compare but Trevor on AstroBackyard was able to pull out brown dust against the black background in a 44 minute stack using a similar scope and similar OSC camera in similar light pollution.
I tried a run with the "screen mask invert" technique but didn't have much success.
If anyone wants to give the data a try, here is the link to the stack out of DSS (with changes embedded but not applied):
https://drive.google...ew?usp=sharing
#2 Tapio
Tapio
  • Loc: Tampere, Finland
Posted 24 June 2019 - 09:34 AM
What did you do in DSS after stacking?
After DSS?
#3 einarin
einarin
Posted 24 June 2019 - 09:48 AM
A bit more stretch.
  • elmiko and artem2 like this
#4 mewmartigan
mewmartigan
Posted 24 June 2019 - 11:07 AM
After DSS?
Tapio, nothing else in DSS after stacking.
Photoshop was various levels, curves, Gradient Xterminator and some astro tools like star shrink, noise reduction and DSO enhancement.  The balanced sky background is RGB 30/30/30.
As mentioned, I tried the screen mask invert which I've seen used to bring out IFN (online tutorials) but it didn't seem to do much.
einarin, thanks it looks like you pulled out a bit more than me. Maybe I could stretch more, I was trying to avoid too much noise.    That amp glow on the right side seems to calibrate out if I do GradientXterminator early in the process but if I do it early it seems to mute the colors. If I do it too late, it won't calibrate out.
I thought it would calibrate out entirely with my darks/flats/bias. Maybe one of the default settings in DSS should be changed?
#5 RandallK
RandallK
  • Loc: Nanaimo, B. C. Canada
Posted 24 June 2019 - 11:27 AM
You'll love the Z103. I assume you got the focal reducer/flattener as well? Did you get the manual rotator? I've been getting round stars right out to the edges using the flattener.
I have mine mounted on my 11 year old SkyWatcher HEQ5-Pro mount and use PoleMaster to "tighten-up" the guiding.
BTW: I highly recommend Noel Carboni's Astro Flat Pro. I have Gradient XTerminator too, but  AstroFlat is almost a no brainer, 1-step process that does magic before your eyes! I think you can get a trial for 30 days. Very much worth the 50 bucks or so.  Here's my cropped Iris using my Z103 and ZWO ASI1600 Colour CMOS....taken last year under heavy forest fire smoke drifting in from Alberta.
Edited by RandallK, 24 June 2019 - 11:49 AM.
#6 terry59
terry59
  • Loc: Colorado, USA
Posted 24 June 2019 - 11:29 AM
Minimally processed in PI...Dynamic Crop, ABE, SCNR, MLT and HT stretch
Outside of the amp glow this looks pretty good to me. I'd want more integration time now to enhance the dust but some more careful processing could improve what you have
Edited by terry59, 24 June 2019 - 11:30 AM.
#7 JP50515
JP50515
Posted 24 June 2019 - 11:32 AM
#8 mewmartigan
mewmartigan
Posted 24 June 2019 - 11:42 AM
I am very happy with it so far. I do have the focal reducer/flattener. I am actually not sure I need it with the size of the 183 chip but it helps with back focus anyway.
I will look into Astro Flat Pro. I have Carboni's astro tools. Thanks for the recommendation.
Excellent choice!
Terry59, thank you for giving it a shot. The dust looks much better. I am really considering PixInsight but want to get a few more stacked images so I have several to work on during my 45 day trial.
