M27 Dumbbell Nebula
astrophotography
5 replies to this topic
#1 Mr. C.
Mr. C.
  • Loc: Oak Grove, MO USA
Posted 25 June 2019 - 04:59 PM
Finally got a clear night for imaging. This is my 1st time at imaging M27.
Skywatcher 100ED Pro with ASI1600MM cooled camera.
120 x 30s Lum, 30 x 60s each RGB - all at gain 70 offset 20
Processed with DSS and StarTools
I am fairly new to AP, so I have not figured out yet how to tame bright stars (like the one at right center). C&C welcomed.
Clear skies
Steve
  • rustynpp, edif300, Scott Mitchell and 8 others like this
#2 petert913
petert913
  • Loc: Portland, OR
Posted 25 June 2019 - 05:07 PM
Nice colors.  Good guiding.  You may be able to coax a little more illumination out of the dumbell in processing.  Brighten it up and extend it a bit.
But I'm no AP master by any means.  I like it !
  • Mr. C. likes this
#3 stargazer60
stargazer60
  • Loc: South Texas
Posted 25 June 2019 - 05:28 PM
Nice image, what mount did you use?
#4 Mr. C.
Mr. C.
Posted 25 June 2019 - 07:58 PM
Thanks. I was using a Celestron AVX.
#5 chongo228
chongo228
  • Loc: Raleigh, NC
Posted 25 June 2019 - 09:26 PM
Very nice.
I'm not an expert on processing but a star make protecting the stars when you pull the histo on the nebula would help. I pull the entire image until the brightest object reaches what I want (in this case that star). Then I protect it and the other stars with a mask and keep pulling the nebula.
PI has a great easy tool that will build a star mask for you.....not sure about Startools but i'm sure it can be done.
#6 Mr. C.
Mr. C.
Posted 25 June 2019 - 10:33 PM
Very nice.
StarTools does have a way to create star masks. I am assuming you "pulling the histo" is the image stretching. Not sure if I can use star masks in the module that does the image stretching, but I will certainly look into it. Thanks for the suggestion.
Also tagged with one or more of these keywords: astrophotography
