Atlas Pro AZ/EQ-6 issue
2 replies to this topic
#1 zambonikane
zambonikane
  • Loc: West Chester PA
Posted 25 June 2019 - 11:42 PM
Hey everyone,
Any idea what is going on?  When slewing, it sometimes hangs up, changes its pitch, then continues on to somewhere near when it supposed to be (sort of).  I have attached a video showing the problem. Is this a balance issue, are my clutches too tight?
https://youtu.be/y-Tqul0wPQo
  • elmiko likes this
#2 PirateMike
PirateMike
  • Loc: A Green Dot On A Blue Sea
Posted 26 June 2019 - 01:20 AM
I would guess that the gear mesh is too tight or that the ring gear is dirty or damaged.
I'm wondering if the problem would go away if you loosen the mesh by one complete turn of the little "mesh adjustment  screws. If the problem goes away then you need to set the mesh again.
Hint: If you loosened the mesh screws by one full turn, tighten the mesh by up by 7/8 of a turn and check for the issue again
But then again, I had that happen to me and it ended up being that an ant had gotten in somehow and stalled the mount.
Miguel   8-)
  • zambonikane likes this
#3 elmiko
elmiko
  • Loc: Arizona
Posted 28 June 2019 - 08:30 PM
Watched your video. I have the same mount. Mine did the exact same thing when I was using an older battery. Once I plugged it into ac it was fine. Are you powered by a battery? I couldn't tell in the video. First thing to check.. then if that wasn't the problem, try the tight gear issue. These mounts like over 12 volts 12.3 or more.
My 2cents, Mike
Edited by elmiko, 28 June 2019 - 08:32 PM.
