Saturn 24th June- Great seeing
17 replies to this topic
#1 wargrafix
wargrafix
  • Loc: Trinidad
Posted 26 June 2019 - 11:26 AM
Hey everyone. I had a spell of great seeing and after a good Jupiter session, I turned my attention to Saturn. My tracking was good. so  i decided to experiment.
I shot with the C 9.25 @ f27
3X barlow and ZWO ADC
ASI 224MC
Stacked in Autostakkert, derotated in Winjupos
First image I shot with my traditional 100FPS high gain. 20 minutes derotated.
After I tried with 28 fps with a much lower gain.
What do you all think?
Edited by wargrafix, 26 June 2019 - 11:31 AM.
  • Sunspot, Jeffrey C., yock1960 and 18 others like this
#2 Dynan
Dynan
  • Loc: NOLA
Posted 26 June 2019 - 11:33 AM
Great Shot! You can even see the hexagonal pole formation!
  • wargrafix likes this
#3 clusterbuster
clusterbuster
  • Loc: Tampa Bay, Fl.
Posted 26 June 2019 - 11:47 AM
Very Nice !
 Mark
#4 descott12
descott12
  • Loc: Charlotte, NC
Posted 26 June 2019 - 12:50 PM
Beautiful shots
Question - why derotate? I understand using winjupos on Jupiter but Saturn doesn't really have any longitudinal variation to derotate.  Or am I missing something?
#5 aeroman4907
aeroman4907
  • Loc: Castle Rock, Colorado
Posted 26 June 2019 - 12:52 PM
Beautiful shots
Likely for keeping clarity of the polar hex and any micro-storms that may be present.  Also to reduce noise by incorporating the results of more frames.
Edited by aeroman4907, 26 June 2019 - 12:59 PM.
  • Dynan likes this
#6 descott12
descott12
Posted 26 June 2019 - 01:05 PM
Ah yes. I forgot about the polar hex
#7 wargrafix
wargrafix
  • Loc: Trinidad
Posted 26 June 2019 - 01:06 PM
which one looks better though?
#8 aeroman4907
aeroman4907
Posted 26 June 2019 - 01:17 PM
The derotated image has less noise that I can see, so that would be my vote for the better image.
Nice captures by the way - very resolute!
#9 wargrafix
wargrafix
  • Loc: Trinidad
Posted 26 June 2019 - 01:57 PM
Oh, they are both derotated. One was 100fps high gain, the other was 28fps lower gain
#10 aeroman4907
aeroman4907
Posted 26 June 2019 - 02:07 PM
Sorry, I didn't understand that.  My answer still goes to the first with higher gain.  That begs a question though - how many frames did you use in each image?  I would imagine that you must have significantly more frames in the higher gain image that is apparently enough to produce less noise than the low gain capture.
#11 wargrafix
wargrafix
  • Loc: Trinidad
Posted 26 June 2019 - 02:11 PM
I don't have hard numbers right now. I can get those for you.
What I know is both were 20 mins. of capture time. The 28fps would have yielded less frames. The 100fps would be about 130k. So about 70% of that. Same with the 28fps.
#12 mic1970
mic1970
  • Loc: St. Louis Metro Area
Posted 26 June 2019 - 02:17 PM
Love it.  How many frames was in the final stack.
ASI 224MC
What do you all th
#13 wargrafix
wargrafix
  • Loc: Trinidad
Posted 26 June 2019 - 02:28 PM
the 100fps one? About 100K in the stack
#14 aeroman4907
aeroman4907
Posted 26 June 2019 - 02:30 PM
Since you are asking for some level of critique, I would add that the magenta hues are a bit too strong, plus I observed both magenta and cyan hues in the rings, which should be pretty close to colorless.
#15 Billytk
Billytk
  • Loc: Geneva, Fl.
Posted 26 June 2019 - 04:16 PM
I like the lower frame one. I can see the polar hex better.
#16 wargrafix
wargrafix
  • Loc: Trinidad
Posted 26 June 2019 - 04:36 PM
Agreed. However, the seeing requirements for the lower fps makes it a real challenge
#17 KiwiRay
KiwiRay
  • Loc: Seattle, USA
Posted 26 June 2019 - 06:44 PM
I like the upper one - less noisy, and provides some evidence that I'm also doing the right thing in using high gain to increase frame rates for Saturn.
The planet itself looks nicely detailed in your images, but the rings seem overprocessed.  Have you tried processing the rings separately?  They tend to need less sharpening and far less colour saturation than the planet.  Sharpening both to the same degree leads to the too-wide Cassini division seen in your images, and less sharpening will reduce some of those artifacts in the rings.
Anyway, congratulations on capturing such high-quality data.  The details in your C9.25 images are comparable to some recent images from larger scopes.
#18 wargrafix
wargrafix
  • Loc: Trinidad
Posted 26 June 2019 - 07:34 PM
I have to run the denoise function. That should deal with the rings.
The spacing is ok. I ran one by mr. Peach
