DIY parallelogram mount designs?
binoculars DIY mount
19 replies to this topic
#1 jxk
jxk
Posted 26 June 2019 - 03:18 PM
I'm looking to build my own parallelogram mount for a tripod I have (Benro KH26NL). Does anyone have any suggestions on designs, how to go about doing this, etc.? The maximum weight on the Benro is 11 lbs., is it reasonable to build a p-gram within that weight? I came across these plans, which is generally what I'm looking for, though I'm open to ideas.
  • ryderc1 likes this
#2 photoracer18
photoracer18
  • Loc: Martinsburg, WV
Posted 26 June 2019 - 03:31 PM
The parallelogram puts most of its weight off the side of the tripod so the load rating of tripod shrinks a lot under that (even when a counterweight rod is added). Based on the companies who made those things that we used to sell I am thinking that tripod is way too light. Most of my tripods are Bogen 3021/3221W which have a 13# weight limit and I consider those too light for my heavy Vixen 11x80 binos.
#3 clearwaterdave
clearwaterdave
  • Loc: Western Maine
Posted 26 June 2019 - 05:50 PM
Here's mine.,easy to put together..with a little inginuity.,inexpensive.,a one hand carry.,fun to use.,cheers.,
  • paulsky, Goodchild, Edward Swaim and 5 others like this
#4 Rich V.
Rich V.
Posted 26 June 2019 - 06:39 PM
That's a very light tripod for a parallelogram.  Just a p-gram and its counterweight will be pushing its capacity even before you've added the binoculars.  You'd have to have a very light setup indeed.
Weight adds up fast with a p-gram + CW; it will substantially exceed the weight of the binocular.  I strongly suggest a higher capacity tripod if you're going to the trouble.
#5 Mike G.
Mike G.
  • Loc: Oberlin, Ohio
Posted 27 June 2019 - 09:13 AM
I use my p-gram mount with Vixen 20x80's on an old CG5 tripod - the ones with 2" stainless steel tubular legs.  stable as a rock.
#6 Myk Rian
Myk Rian
  • Loc: Hartland, Michigan
Posted 27 June 2019 - 09:59 PM
I use a surveyors Tpod. With my P-gram, 20x80 Oberwerks, and 15 lbs of counter weight, it holds the approx 25-30 lbs very well.
Myk
  • Cali likes this
#7 Xeroid
Xeroid
  • Loc: USA
Posted 28 June 2019 - 02:16 PM
Here's some info on a home brew Parallelogram that's easy to do:
- Oak 1" x 2"  (3 or 4 6 foot lengths)
- Two Upper LONG bars are 38" long
- Two Lower Short Bars are 18" long
- Pivot Vertical post is 12" long & made from two 1"x 2" pieces
- Bino Vertical post is 8.5" long & made from two 1"x 2" pieces
- 1/2" Nylon Spacers between long/short bars and vertical post
- 1/4" x 4.5" bolts with LOCK Nuts adjusted to allow movement without slipping + fender washers.
- Kmart 5 lbs. Barbell, postion and type can be customized.
-Bino wood hinge allows left/rigth & up/down movement of bino with adjustable friction to limit movement.
- The bino's.are 10x42 and are not too heavy.
The Parallelogram works very well and the Oak makes it very strong.
  • plyscope, Goodchild, clearwaterdave and 3 others like this
#8 Saturnalia
Saturnalia
  • Loc: England
Posted 12 August 2019 - 04:26 PM
That's a good looking P-mount in oak Xeroid - do you have a better pic of the bino head end for clarity...?
#9 S.Boerner
S.Boerner
  • Loc: Chesterfield, MO
Posted 12 August 2019 - 05:35 PM
Mine looks like this:
  • Xeroid, clearwaterdave, wrvond and 2 others like this
#10 Saturnalia
Saturnalia
  • Loc: England
Posted 15 August 2019 - 11:15 AM
Very useful thanks.
#11 RRMichigan
RRMichigan
  • Loc: Wyoming, MI
Posted 16 August 2019 - 11:03 AM
Here is one I built over the course of a few evenings this past late June. (I had yet to stain the wood)
I had no specific plan to work from other than looking at what others have done and incorporating what I thought were the best design elements. The only error I made was to build the tripod legs too short. I later added about 8 more inches in height, to accommodate my using the device when standing and looking at the Zenith without bending at the knees. It still folds low enough to observe in a lawn chair as well. It works perfectly for me and I have already had several sessions this summer using it to view Jupiter, Saturn and M31 (later at night).
  • clearwaterdave, wrvond, Allanbarth1 and 1 other like this
#12 S.Boerner
S.Boerner
Posted 16 August 2019 - 11:45 AM
Move your long arm to the top and you should be able to get a bit more height.
#13 Napp
Napp
  • Loc: Florida, USA
Posted 16 August 2019 - 02:33 PM
Mine is very similar to yours.  I used a more metal.  Mine was based on the design and pictures at http://astro-tom.com...cular_mount.htm
Note the red dot finder.  Really helps find targets quickly.
#14 Subhematoma
Subhematoma
  • Loc: Smack Dab in the Middle of the Glove Michigan
Posted 04 September 2019 - 10:07 PM
That is so very pretty. What was the total length of the legs once you added the eight inches if I may ask?
still trying to see how you attached the column to the tripod.  I assume the column swivels on the tripod?
Edited by Subhematoma, 04 September 2019 - 10:09 PM.
#15 Sean Wood
Sean Wood
  • Loc: North Carolina
Posted 08 September 2019 - 02:45 PM
There's nothing really super hard about a P-mount. The most critical part is the hole spacing. If possible clamp together the mating parts like the uprights for each end of the parallelogram and the upper and lower arms or anything that will have the same hole spacing and drill through them all at the same time. You'll also want to put a plastic washer of some form between the joints that move against each other. I used Nylon fender washers that I had found at my local hardware store but if you wanted to go budget, discs cut from a milk jug would suffice as well.
A note on materials. If you make it from wood, no matter how well you seal it it will still be susceptible to expansion and contraction due to environmental humidity. If you make it from aluminum it will be susceptible to expansion and contraction due to temperature. neither of these materials expansion will be severe enough to make the mount unusable/inaccurate BUT it can make the joints tight or loose and change the amount of friction in the joint which will directly effect over all user experience. Putting hand knobs on the joints can make quick field tension adjustments much easier.
#16 RRMichigan
RRMichigan
  • Loc: Wyoming, MI
Posted 16 September 2019 - 03:47 PM
I will try to get the leg measurements for you.
Yes, there is an azimuth swivel between the tripod head and the top portion. It uses plastic sheet bearings and moves effortlessly. I actually incorporated a true, press-tight sealed bearing originally but had difficulty getting wood to hold it in place properly.
After I lengthened the legs I have no problem looking anywhere. I am 5'11" and someone well over 6 foot could use this without bending.
Note: This was all built from (good) scrap wood made from Swedish shipping crates. The counter weights are hydraulic motor geroters of different thicknesses, painted. The cost of all the hardware used was perhaps $15. I over-bought hardware last winter knowing I would build this when the weather was warmer and did not yet have an exact plan nailed down.
Edited by RRMichigan, 16 September 2019 - 03:52 PM.
#17 RRMichigan
RRMichigan
  • Loc: Wyoming, MI
Very nice work there.
#18 RRMichigan
RRMichigan
  • Loc: Wyoming, MI
Posted 16 September 2019 - 03:54 PM
Now you tell me. LOL. Actually, heightening the legs took care of the issue. But thanks.
#19 RRMichigan
RRMichigan
  • Loc: Wyoming, MI
Posted 17 September 2019 - 10:06 AM
I measure the tripod legs and they are 48 inches in length.
#20 LU1AR
LU1AR
Posted 07 March 2020 - 09:06 PM
There are 2 (Two) GC in the binos. Fore-Aft and Up-Down. Most supports I seen, don't considere the Up-Down GC.
Also tagged with one or more of these keywords: binoculars, DIY, mount
