http://apm-telescope...em/333631363631
For those for whom a 150/152 is too long and heavy, this 140 seems the answer. Impressive focuser, sliding dewshield, portable.
Has anyone got one of these scopes yet, what is it like to use?
Posted 26 June 2019 - 11:06 PM
Posted 26 June 2019 - 11:22 PM
Edited by SeattleScott, 26 June 2019 - 11:23 PM.
Posted 26 June 2019 - 11:26 PM
Choosing this scope or the 150 f8 basically comes down to what mount you have. I am sure people are very happy with both products for that reason specifically.
Edited by Tyson M, 26 June 2019 - 11:26 PM.
Posted 27 June 2019 - 02:44 AM
Posted 27 June 2019 - 04:04 AM
I have the APM 130, which uses the same tube and 3.7" focuser. While I can't comment about the optics, the mechanics are pretty good. The 3.7" focuser is as smooth as the feathertouch, and could hold my 4kg (9lbs) imaging load without slipping.
140 F7 ED would make for a great rich field scope. Does your 130 show any CA?
Posted 27 June 2019 - 04:17 AM
Isn’t the 140 using the 152 tube?
do you think all the 5 and up use the same tube?
Posted 27 June 2019 - 04:18 AM
I think hydro has a triplet
Posted 27 June 2019 - 05:03 AM
I'm not sure if the others use the same tube, but yes the 130, 140 and 152 use the same tube. The 130 also has the option of using the CNC LW and Matthias Wirth tubes, but those cost quite a bit more.
So yes, the tube diameter is grossly oversized for the 130 (the dew shield somewhere around 7" or 7.5"), but at least it's short.
Posted 27 June 2019 - 05:06 AM
As ris242 has mentioned above, the 130 is a triplet, so there's undetectable CA even in imaging. I have looked through the APM152 which uses FPL-51, and visually I can't see any CA in-focus. The 140 should do even better with FPL-53+Lanthanum, so I don't think CA would be an issue.
Posted 27 June 2019 - 05:47 AM
See I was under the impression the 130 was a lot shorter thinking the tube diameter is smaller.
Since the tube is a big diameter it makes them look stocky. Really they are only just short of a 130 f7 which in turn is just shorter than the 140 f7 which is just short of the 152mm 6.7 ok and the 152mm f8 is a lot longer again at 1200mm.
Posted 27 June 2019 - 10:49 AM
looks like the 130 is a LZOS. Completely different animal...
Posted 27 June 2019 - 11:14 AM
Yes, that's why I clearly stated I was referring to the mechanics only, not the optics.
Posted 27 June 2019 - 12:54 PM
Posted 27 June 2019 - 07:24 PM
Got one to maximize the potential of my Stellarvue M2C mount. I was previously using an AT115 on the same mount, but thought it could handle more scope (especially with the APM's Losmandy plate). So far so good on the decision. Need more time to judge the views, but this is literally the largest refractor I could ever use for a "grab and go". I can just barely make it out my standard sized back door in one trip. It does require a "three point parking turn" to make it through, mostly d/t the scope length and M2 mount legs.
Posted 28 June 2019 - 02:47 AM
Posted 28 June 2019 - 11:26 AM
Posted 30 June 2019 - 01:36 PM
Encouraging. One in my future, I hope. The final upsize.
I would need to sell some of my others first, hard decision....
Posted 30 June 2019 - 01:59 PM
When I got out of imaging, I moved from a Televue 127is to the APM 140, and I have zero regrets.
Posted 30 June 2019 - 07:35 PM
Sounds very encouraging. Tell us more about the benefits you've found from the move.
Posted 30 June 2019 - 07:50 PM
They are mostly minor.
The TV127is was a fantastic scope, but it was geared toward imaging which I had quit. Even for visual, the 127is is geared toward wide fields views, which I was not doing (planetary/globs/doubles). The main motivation behind the move was that I could sell the 127is on the second hand market, buy the APM 140 f/7, and still have money left over.
This will sound stereotypical, but on the first night with the APM 140, I had the best view of Mars I have ever had. While I'm certain that seeing was the main reason, it was enough for me to conclude that the scope is just fine for what I am trying to do.
Posted 30 July 2019 - 05:08 PM
What mount do you use for your 140, any alt az suggestions?
Posted 31 July 2019 - 09:37 AM
I've been using the 140/980 Doublet since it was presented to the market. (Owner of #0006, Celestron CGEM DX mount).
I love it and my Meade 12" LX 200 is resting the most time in my living room. I love star gazing and do only little fotografy. But as well as for fotografic interest, as for visual meetings this teleskope gives pleasure every time.
Well done thermic equibalance ist necessary of course!
Posted 31 July 2019 - 10:24 AM
The reports I've read from release indicate buy with confidence. I was debating between this and the new 150 doublets out, in the end it was just too close to my FS-128 so I went larger.
Posted 31 July 2019 - 10:53 AM
So far I’m very impressed with my APM 140, though I’ve only managed to get it out a handful of times, thanks to the lousy weather here this year. I’ve had some beautiful views of Jupiter and Saturn, as well as some limited deep sky objects.
FWIW, I use mine on an AYO Digi II and a Berlebach Planet tripod and I can’t imagine a better combination. Not exactly grab and go though, more like grunt and go. Fortunately, I only have to carry it a few feet.
Posted 16 August 2019 - 04:30 PM
First Light Curse is alive and well..........
A beautiful sunny afternoon was followed by complete cloud cover horizon to horizon
and the cause of this I can only attribute to the fact that I wanted to test out my new APM140 scope, the first Non-Takahashi I have bought in years...
Astrophotography and Sketching →
DSLR & Digital Camera Astro Imaging & Processing →
Filter drawers for 2" LP filtersStarted by marinaldi , Yesterday, 02:17 AM ![]() |
CN Feedback and Vendor Announcements →
Vendor and Group Announcements →
Tele Vue Blog:Started by Stars4jon , 13 Dec 2019 ![]() |
Equipment Discussions →
Refractors →
SharpStar 61EDPH/WO Redcat 51 vs 4/300 (nikon AF-s)?Started by GTom , 12 Dec 2019 ![]() |
Refractors →
Interesting ResultStarted by Steve Allison , 11 Dec 2019 ![]() |
Refractors →
Need Help Identifying a RefractorStarted by Brisby2 , 10 Dec 2019 ![]() |
![]() Cloudy Nights LLC Cloudy Nights Sponsor: Astronomics |
