Best Ranked Eyepiece of the Best Eyepiece Series
54 replies to this topic
#51 Starman1
Starman1
    Vendor (EyepiecesEtc.com)
  • Loc: Los Angeles
Posted 18 September 2019 - 11:43 AM
I am pretty sure the 25ES100 has different optical prescription (lense count, surface radii) than the others in the 2" *ES100 line.
Well, this is also true of the TeleVue Ethos line, with lens counts from 8 to 10, and the Pentax XW line with lens counts from 6 to 8.
But we still consider them part of a line because they were designed to have similar optical characteristics.
In the case of the 25, many of its parameters (like eye relief) and aberrations are simply an extrapolation of the shorter focal lengths.
Even its weight is a simple extension of the 20mm.
That makes it a part of the family rather than a stand-alone design like the 9mm 120°.
#52 rkelley8493
rkelley8493
  • Loc: Troy, Alabama
Posted 22 September 2019 - 03:43 PM
How bout the Ethos-SX 110º.. Is it technically another series of Ethos, similar to the different Nagler Types? And is the 3.7 every bit as good as the 4.7? I was this close [ ] to getting the 3.7, but I went with the 10 because I could use it in both of my scopes. Funny thing is, it hasn't gotten as much use as I thought it would. That could change though as Deep Sky Season is right around the corner.
#53 Starman1
Starman1
  • Loc: Los Angeles
Posted 22 September 2019 - 06:25 PM
The Ethos SX eyepieces are different internally to other focal lengths.
I guess the SX on the end differentiates them.
#54 j.gardavsky
j.gardavsky
  • Loc: Germany
Posted 23 September 2019 - 08:08 AM
Low magnifications (f=25mm - 32mm), small AFOV:
Leica  L Plan 32mm
Leica HC Plan S 25mm
Medium magnifications (f=22mm - 11mm), wide (ultrawide) AFOV:
Leica B WW and B Televid series (discontinued)
Zeiss B WW Diascope series
Pentax SMC O-18 (discontinued)
Carl Zeiss Jena 16-O export version (discontinued)
DOCTER 12.5 mm
High magnifications, wide AFOV:
Pentax SMC XW 10
Pentax SMC XW 7
High magnifications (f=9mm - 6mm), small AFOV:
Pentax SMC O-9 (discontinued)
Pentax SMC O-7 (discontinued)
Pentax SMC O-6 (discontinued)
Maximum magnifications and beyond:
Pentax SMC XW 3.5
Pentax SMC XO 2.5 (discontinued)
Zooms:
Leica 25x - 50x WW Asp., eventually on the Baader VIP Barlow
Tele Vue Nagler Zoom 3mm - 6mm
Half of them might be enough, but I can't part with some,
JG
  • StarDust1, 25585 and rkelley8493 like this
#55 russell23
russell23
  • Loc: Upstate NY
Posted 06 October 2019 - 10:02 AM
Out of all the great eyepiece series currently in the market [Ethos, Pentax XW, Delos, ES 100°, etc], which eyepiece ranks #1 out of each series?
For Explore Sci 100° - I rank the 14mm as the best
Explore Sci 92° - 12mm
Delos - 8mm
Pentax XW - Tied between the 7mm & 10mm
Ethos - I don't know, haven't tried them all, but I really like the 4.7- SX
What are some of the other great series' standouts? Which do you rank #1 out of those mentioned?
Forcing myself to pick just one from each line:
ES100: 9mm
TV DeLite:  18.2mm
TV Delos:  14mm
Pentax XW:  7mm
Nikon NAV SW:  10mm
TV Panoptic:  35mm
ES68:  28mm
ES62: 32mm
ES52: 6.5mm
Baader Morpheus:  This one is very tough between the 9mm and the 6.5mm ... picking one ... Uhhhhh .... okaaay .... 6.5mm
Meade UWA:  5.5mm
ES82:  6.7mm
Brandon: 24mm
Olivon 70: 22mm
Edited by russell23, 06 October 2019 - 10:04 AM.
  • 25585 and rkelley8493 like this
