This report is the fourth installment of a series of observational investigations I have made using an 8 inch f/5.9 reflecting telescope.
Check out this link for goals and methods used in this study:
https://www.cloudyni...-and-monoceros/
Bootes
BU 224 (14135+1234) mags 8.94/9.35; pa = 95°; sep = 0.65“, 2015 (last precise; not solid, opening)
345x: single star
460x: pointy but never resolved; well below resolution limit; magnitude data is from Hipparcos (1991, 515nm); needs a re-msre of delta mag and separation
STT 287 (14515+4456) mags 8.40/8.62; pa = 5°; sep = 0.575“, 2017 (last precise vs 0.659” orbital estimate for 2019.3; data incongruent)
345x: seen as elongated 30% of time
460x/averted vision/extended viewing: elongated only, never resolved; below resolution limit; needs a re-msre of separation
STF 1866 (14417+0932) mags 8.48/8.65; pa = 205°; sep = 0.733“, 2015.5 (Gaia DR2, solid data)
345x: on the border of resolved and split to two even magnitude light yellow stars; above resolution limit
STF 1863 (14380+5135) mags 7.71/7.80; pa = 60°; sep = 0.654“, 2017, (last precise, solid data)
460x/orange filter/averted vision/extended viewing: moves past elongated to resolved 20% of time
627x/orange filter: just resolved 50% of time; just a bit above resolution limit; important data point (equal mag pair) to set minimum value of rho
STF 1867 (14407+3117) mags 8.36/8.83; pa = 355°; sep =0.674“, 2017 (data needs confirmation)
460x: just split 50% of time to two white stars of slightly dissimilar magnitude; need re-msre of separation
A 148 (14220+5107) mags 8.32/8.96; pa = 190°; sep = 0.535“, 2019.3 (4th Int. Catalog estimate vs 0.58” last precise in 2015; data not solid)
627x: a bit elongated but never resolved; well below resolution limit; need re-msre of separation
KUI 66 (14148+1006) mags 5.44/8.43; pa = 111°; sep = 0.99“, (my own measure in 2017 with ASI 178MC camera; data tentatively considered solid as it is a match with 4th Int. Cat. estimate)
627x/orange filter: much smaller secondary seen as a resolved dot very near first diffraction ring 30% of time; just above resolution limit; important, large delta mag data point so re-msre with ASI 290MM camera needed. See image below.
AGC 6 (14339+2949) mags 9.81/10.30; pa = 133°; sep = 0.752“, 2015.5 (Gaia DR2, solid data)
345x/extended viewing: seen as elongated rod, never resolved; very faint and difficult; below resolution limit; important data point to set ‘faintness factor’
STT 298AB (15360+3948) mags 7.16/8.44; pa = 187°; sep = 1.208“, 2019.4 (orbital estimate, solid data)
345x: easily split to two small light yellow stars of similar magnitude; very pretty; above resolution limit
A 1110AB (14497+0759) mags 7.69/7.93; pa = 245°; sep = 0.692“, 2015.5 (Gaia DR2, solid data)
345x: oscillates between resolved and split; both stars are yellow with secondary seen as smaller and *delta mag is likely >0.24
460x: seen as split 100% of time with secondary possessing a hint of orange; above resolution limit; Gaia DR2 gives a delta mag of 0.67 which does not agree with Tycho value of 0.24—will attempt a measure of delta mag to rectify
Canes Venatici
STF 1606 (12108+3953) mags 7.44/7.93; pa = 145°; sep = 0.611“, 2019.3 (orbital estimate vs 0.627”, last precise in 2017; data not solid)
460x: elongated but never resolved
627x: moves past notched rod to resolved 20% of time; at or just above resolution limit; observation supports tighter value of rho [0.611”]; this is an important data point; will re-msre (possibly annually) to firm up value
STT 251 (12291+3123) mags 8.35/9.27; pa = 61°; sep = 0.781“, 2017 (last precise; data not solid)
345x: just resolved 30% of time with secondary much smaller
460x: just split 50% of time; a bit above resolution limit; faint secondary plays role in difficulty; re-msre of separation needed
STF 1768AB (13375+3618) mags 4.98/6.95; pa = 95°; sep = 1.656“, 2019.3 (orbital estimate; solid data)
345x: well split, primary is white and secondary is light yellow and considerably smaller—a fine sight! Above resolution limit
Coma Berenices
STF 1639AB (12244+2535) mags 6.74/7.83; pa = 324°; sep = 1.855“, 2019.3 (orbital estimate; solid data)
345x: well split, primary is white and secondary is light yellow; very pretty mag contrast pair; above resolution limit
STF 1687 (12533+2115) mags 5.15/7.08; pa = 200°; sep = 1.18“, 2018 (last precise; solid data)
345x: a bit past just split 100% time with secondary noticeably smaller; both stars are yellow; above resolution limit
COU 397 (12575+2457) mags 9.06/9.71; pa = 63°; sep = 0.70“, 2015 (last precise; solid data)
345x: single star; faint!
460x/averted vision: slightly elongated but never resolved; below resolution limit; important data point to establish ‘faintness factor’
A 567 (13328+2421) mags 6.21/9.71; pa = 256°; sep = 1.450“, 2015.5 (Gaia DR2, solid data)
345x: secondary seen as split 50% time and appears as very small, very faint dot a bit past first diffraction ring of primary; above resolution limit
Ursa Minor
STF 1989 (15396+7959) mags 7.32/8.15; pa = 23°; sep = 0.67“, 2013 (last precise vs 0.603”, orbital estimate for 2019.4; data not solid)
345x: moves past elongated to exhibit a snowman shape
460x: resolved about 40% time with secondary a bit smaller; above resolution limit (observation supports separation closer to 0.67” value; re-msre of separation needed)
BU 799AB (13048+7302) mags 6.60/8.45; pa = 265°; sep = 1.39“, 2017 (last precise; solid data)
345x: easily split; both stars are white and secondary is considerably smaller—very pretty; above resolution limit.
A 1136 (16135+7147) mags 9.22/9.47; pa = 9°; sep = 0.727“, 2007 (last precise, data is old)
345x: barely split; both stars are very small and white, and secondary is just a bit smaller; helps to establish ‘faintness factor’; above resolution limit; a re-msre of separation is needed
Virgo
BU 797AB (12345+0558) mags 9.10/9.39; pa = 146°; sep = 0.61“, 2010 (last precise, data is a bit old but considered solid)
345x/averted vision/extended viewing: slightly pointy
460x: elongated and on the border of resolved, but never did resolve despite an extended view
627x: moved past elongated to resolved about 5% of time; at or slightly below resolution limit; a very important data point that warranted 45 mins of study under very good seeing conditions
RST 4484 (11447-0431) mags 8.46/8.39; pa = 64°; sep = 0.738“, 2017 (last precise; data not solid)
345x: just split to two ~even magnitude yellowish-white stars—beautiful! Above resolution limit; re-msre of separation needed
BU 935AB (13459-1226) mags 5.66/8.47; pa = 304°; sep = 1.03“, 2001 (last precise; data is old)
460x: brightening of first diffraction ring sharpens to much smaller secondary 30% of time; both stars are yellow; above resolution limit; a new measure of separation is needed for this important mag contrast binary
**Have you observed or imaged any of these objects recently? Let me know. Do you have a suggestion for a double I should observe within one of these constellations? I would like to hear about it.**
Edited by Nucleophile, 03 July 2019 - 08:22 PM.
