TEC-itis!
506 replies to this topic
#501 slavicek
slavicek
  • Loc: Massachusetts
Posted 18 April 2025 - 08:48 PM
Very nice Jan! I'd say almost bit of a overkill. This is all custom so it can be make here in the US too, if one is willing to spend the $$$. Either way, Jan you got me thinking about my next project - cover for my pier with RST-300.
#502 gpom
gpom
Posted 19 April 2025 - 07:20 AM
Finally had the first night out with the TEC180. Spent the clear sky time fiddling with spacing and focus before clouds rolled in. I'm sure the moonlite focuser makes a huge difference, but I have to say the combination of the moonlite and the TEC is an absolute joy to work with. Once I got the back spacing figured out, I ran an autofocus with pretty much basic settings and the first run was just about perfect. The scope is a beast but overall wasn't too difficult to mount up. Next step is to build the observatory so I don't have to move it ever again lol.gif
Can't wait to get some full imaging runs in and dip my toes into the visual side as well. I can say that the pup Cosmo approves of the setup.
20250417 185103
  • zjc26138, 3 i Guy, Jeff B and 3 others like this
#503 Psion
Psion
  • Loc: Czech Republic, Prague
Posted 19 April 2025 - 08:29 AM
I am curious to compare my excellent TEC 140ED with the CFF 160 :)
  • Henricuda likes this
#504 slavicek
slavicek
Posted 19 April 2025 - 02:13 PM
Unless you want to visually challenge yourself with splitting some tight doubles you will have till fall to have the planets show up after midnight (best time to observe them). In the meanwhile, get yourselves some Ortho eyepieces!
I myself have been fiddling with my 180 for few years and finally last fall it all came together and so I had views of planets no pic can show/compare.
Just saying.
#505 CHASLX200
CHASLX200
  • Loc: Tampa area Florida
Posted 19 April 2025 - 02:28 PM
Jup is the real test. But it is too low now.
#506 Jan-S
Jan-S
  • Loc: Belgium
Posted 13 May 2025 - 02:29 AM
I would like to use a longer dovetail with the TEC tube rings and carry handle, for a 160 FL. The tube rings are attached to the current dovetail with two 1/4 screws per ring, i.e. four in total. The longer dovetail does not have hole pairs (i.e. near the edge of the dovetail) wide enough to match the twin 1/4 hole pairs in each of the TEC tube rings. It does have center holes. The TEC rings have center holes, also 1/4, too. These holes in the TEC rings are a bit less deep than the pairs - otherwise they protrude into the padding of the rings. Would two 1/4 screws, one at the center of each ring, be sufficient to hold down a 160 FL with accessories?
I thought to write TEC, but this way at least any info will be available for future reference.
Thanks a lot in advance.
Kind regards,
Jan
#507 Alan S
Alan S
  • Loc: Tucson, AZ
Posted 13 May 2025 - 06:55 AM
You can buy longer dovetails from TEC that will have holes that align (unless you are already using their longest).  I like the dovetails they provide, they are slightly lighter than some of the other ones on the market, if that matters to you.
  • Jan-S likes this
