Spectrum of Campbell's hydrogen star with SA 100
beginner
11 replies to this topic
#1 mwr
mwr
  • Loc: Germany
Posted 06 July 2019 - 07:49 AM
Any suggestions for the element that causes the emmission line at approx. 6720 A (perhaps [SII] of the nebula)?
The other assigments I've made are based on data from: Grosdidier et al.  Astron. Astrophys. 364, 597-612 (2000)
Campbell's Hydrogen Star/ PK 64+ 5.1 / BD+30 3639
#2 descott12
descott12
  • Loc: Charlotte, NC
Posted 06 July 2019 - 09:07 AM
That is an awesome spectrum with so many sharp peaks.
A few questions:
1. What scope/camera did you capture it with?  I see it was a color camera.
2. I am assuming that that is a raw spectrum as it has a very flat baseline. Do you have  a version that is corrected for your instrument response?
3. How did you capture it? I am learning to use RSpec but I haven't tried stacking multiple captures. I see that you used 10 x 180 seconds.  How exactly did you do that?
Thanks in advance
#3 mwr
mwr
  • Loc: Germany
Posted 06 July 2019 - 10:06 AM
A few questions:
Thanks in advance
It is a rather poor spectrum with a low signal to noise ratio. All "sharp peaks" can be attributed to background noise. Only the broad peaks are real emmission lines from either the central Wolf-Rayet star or the surrounding nebula.
1. I used an old Canon EOS 450 Da and a cheap Vixen VMC 110L (Maksutov Cassegrain at f/9.4) with the Star Analyser 100 at a distance of 14 cm to the camera sensor.
2. The spectrum is indeed a raw spectrum without flat or dark correction.
3. I'm usually also using RSpec but in this case the signal to noise ratio was too low. I have stacked 10x 3 minute subframes" by hand" with Fitswork (Deep Sky Stacker couldn't handle the very noisy image files) and did a Gaussian denoising. Subsequently, I have extracted a pixel line of the spectrum (luminance channel) and imported the corresponding pixel map to Microsoft Excel. Calibration was done by linear regression using H alpha and H beta lines as reference points.
#4 robin_astro
robin_astro
Posted 06 July 2019 - 02:49 PM
Nice spectrum!
There are several possibilities for the line at ~6720A.  It could be a blend but mainly CIII. (6727-6773).  See
An atlas of optical spectrophotometry of Wolf-Rayet carbon and oxygen stars
Authors:
Torres, Ana V.; Massey, Philip
http://adsabs.harvar...ApJS...65..459T
Cheers
Robin
Edited by robin_astro, 06 July 2019 - 02:51 PM.
  • mwr likes this
#5 robin_astro
robin_astro
Posted 06 July 2019 - 03:20 PM
Don't forget you can capture and pre process your image (convert to mono, dark subtract, align, stack) outside RSpec using another capture/image processing software, just like normal astro-imaging and then pass the pre processed fits image back to RSpec (or use another specialist spectrum processing program) to do the rest of the reduction/calibration. (sky background subtraction, binning, wavelength calibration, instrument response/atmospheric extinction correction)
Cheers
Robin
#6 descott12
descott12
Posted 06 July 2019 - 03:24 PM
Cheers
Robin
Hey Robin,
Thanks for the tip. I use SharpCap for planetary stuff and EAA. I wonder how it would do with stacking a spectrum? I will give it a try...so few clear nights to do everything!
#7 The Ardent
The Ardent
  • Loc: Virginia
Posted 06 July 2019 - 03:45 PM
When observing this I have not seen any nebula with a higher surface brightness in H-alpha.
The central star disappears when filter is added- I’m guessing the star is poor emitter at red and longer wavelengths, and/or the nebula is not transparent in h-alpha.
#8 catalogman
catalogman
Posted 06 July 2019 - 04:14 PM
This article identifies [SII] at 6724 A:
http://articles.adsa...AJ....113.2147H
--catalogman
  • mwr likes this
#9 robin_astro
robin_astro
Posted 06 July 2019 - 05:33 PM
--catalogman
Possibly but this refers to the halo region. At this resolution and with the line broadening in the WR star spectrum we cannot fully resolve this region of the spectrum.  The spectrum is that of a late WR star ~WC8 superimposed on Balmer emission (and probably other lines) from the surrounding nebula. CIII from the WR star wind is already prominent at other wavelengths in the spectrum so will be present in this area too.  Here for example is the spectrum of a WC8 star from the Torres/Massey catalogue referenced above (fig10). The feature in question is clear in this spectrum and the spectral components are identified there. The detailed wavelengths are also listed in the paper (tables 3-6)
Cheers
Robin
Edited by robin_astro, 06 July 2019 - 05:34 PM.
#10 robin_astro
robin_astro
Posted 06 July 2019 - 05:48 PM
The central (Wolf Rayet) star is indeed extremely hot but we do not actually see the star surface itself, only the dense stellar wind excited by UV radiation from the star. The continuum spectrum of the wind is relatively flat in the optical and dominated by  broad emission lines, (C,He,O, though not Hydrogen as that has already  been used up or expelled into the surrounding region)
(Note the spectrum from the catalogue is a log scale plotted in magnitude for the Y scale so exaggerates the strength of the continuum.)
Robin
Edited by robin_astro, 06 July 2019 - 05:56 PM.
#11 mwr
mwr
  • Loc: Germany
Posted 07 July 2019 - 02:49 AM
Nice spectrum!
Authors:
Cheers
Robin
--catalogman
Many thanks for sharing these articles I wasn't aware of.
Planetary nebula with Wolf-Rayet type central stars are really highly interesting objects even for low resolution spectroscopy with the SA 100. I was able to get a spectrum of the central WR star and the surrounding nebula of NGC 40 (bow tie nubula):
NGC 40 Bow-Tie Nebula with central Wolf-Rayet carbon star
Has been somebody able to get a spectrum of the follwing planetary nebula with central WC stars ?
NGC 6751 (glowing eye nebula in Aquila)
NGC 1501 (camel's eye nebula in Camelopardalis)
Would it be worth to start a "spectroscopy challenge" on these objects?
#12 mwr
mwr
  • Loc: Germany
Posted 10 July 2019 - 11:30 AM
--catalogman
Finally I've found an excellent APLY 600 spectrum of this object on the following webpage:
http://www.krannich-...e/spekt_pn.html
In the reference list on this webpage a publication that contains the correct assignment can be found:
Auroral and nebular emission lines of SII in the optical spectra of planetary nebulae, 1996 MNRAS,281,1073
So I think it's indeed SII
Also tagged with one or more of these keywords: beginner
