Just joined AAVSO - asked for a CCD Mentor
9 replies to this topic
#1 sink45ny
sink45ny
  • Loc: Pennsyltucky
Posted 07 July 2019 - 12:07 PM
Generally are they responsive?
I have almost read (almost) all the CCDPhotometryGuide.PDF and know how to take pretty pictures.
I have a Lum B & V in my filter wheel.
Next step will be to image a variable star (in the big dipper)?
I have a 140mm APO refractor on an EQ mount with ZWO 1600mm camera and Lum, B & V in the filter wheel.
Any assistance or suggestions how to proceed are appreciated.
thanks!!
p.s.
I use TSX pro and SGP with PHD2. Post process with pixInsight.
Edited by sink45ny, 08 July 2019 - 09:04 AM.
  • Enkidu likes this
#2 Gipht
Gipht
  • Loc: Prescott Valley, AZ.
Posted 07 July 2019 - 02:42 PM
Sorry I can't help with your question.  Last night, I was imaging the Crescent Nebula, and in the very corner  of the picture was the eruptive variable star with the intriguing name,  Revenant of the Swan.  This could easily have been edge of field effects, but residue around the star seemed very interesting.
Just trying to suggest a target.  Like I said, this could be just poor correction on my image.
Edited by Gipht, 07 July 2019 - 02:57 PM.
#3 S.Boerner
S.Boerner
  • Loc: Chesterfield, MO
Posted 07 July 2019 - 04:27 PM
The Target Tool at https://filtergraph....on&settype=true  is a good place to pick some targets.  Trying to pick targets using the VSX can be really intimidating.
A very important question to ask is what software will you be using to do calibration, stacking and photometry?  Since you are an AAVSO member you have access to VPhot.  I use MaximDL for the first two and VPhot.
If you haven't done so yet, get an observers code and register for the site https://www.aavso.org/apps/register/
You might be interested in a CHOICE courses coming up:
September 9 - October 11 (note that this course is 5-weeks long)        Photometry Using VPhot  Instructor: Ken Menzies  $30 for members
One big change you'll notice from doing DSOs is that the exposure times are really going to be short to keep saturation down!
  • Jamey L Jenkins and sink45ny like this
#4 sink45ny
sink45ny
  • Loc: Pennsyltucky
Posted 07 July 2019 - 05:20 PM
Thank you very much!!
#5 Jamey L Jenkins
Jamey L Jenkins
Posted 07 July 2019 - 07:58 PM
Oldie to observing, but newbie to photometry, that's me. Could be it's just the long holiday weekend that is holding up a reply from the AAVSO.
What I did when I knew I wanted to explore variable star photometry was watch this forum and follow the posts for a number of months. I found out who was in the know about the subject then made a point to contact that individual myself asking for "mentor" help. It worked out and by chance my helper has taught AAVSO classes and is a contributor to the AAVSO CCD Handbook. This has been just since Spring and I've received a ton-o-advice.
The first thing I did was perform a linearity test on my camera (Atik 314L+) and determine the ADU count where the CCD saturates. This is a must have bit of information. If you haven't found that out yet start there. Next, and which is where I am in the learning curve, is through testing on standard star fields find the optimum exposure time for your system (telescope-filter-camera) on various magnitudes at differing elevations (different air masses) so you can achieve best signal to noise ratio without saturating your target and comparison stars. Lot of prep work before actually beginning photometry I've discovered.
I'm using AstroImageJ software to calibrate and inspect my science images. For photometry I intend to use AAVSO's Vphot online software. For that purpose I too have just joined the AAVSO this last week.
Good luck, hope to hear more from you on your experience!!
  • sink45ny likes this
#6 sink45ny
sink45ny
  • Loc: Pennsyltucky
Posted 07 July 2019 - 08:09 PM
Thank you too Jamey!!
  • Jamey L Jenkins likes this
#7 S.Boerner
S.Boerner
Posted 07 July 2019 - 08:24 PM
One of the really nice things about VPhot is that after a plate solve it knows your field.  That means it knows/shows you the location of the various variables and comp stars in the field with needed data.  With my old version of MaximDL I had to manually find them all and enter the AUIDs and magnitudes.
I remember that AstroImageJ seemed easier that MaximDL AND the last half of the Exoplanet Observing Guide is devoted to it (https://www.aavso.or...serving-manuals)
There's also a VPhot Forum that's available to AAVSO members.  You'll find lots of help and answers to questions there.
Once you are a member and your login info go to https://www.aavso.org/vphot  and enter it to get into VPhot.  Once in over in the top right corner you'll see "Support"  If you click there you can download a manual and also watch eight videos that show you how to get started using it.  You'll learn much more in the class (I took it) but there's enough to get started under "Support".
#8 Jamey L Jenkins
Jamey L Jenkins
Posted 07 July 2019 - 08:37 PM
Yes, the AIJ software besides being FREE has been a breeze for calibrating and finding FWHM, but was developed with exoplanet work in mind. It seems that some BAA observers use it for variable star photometry, but there is a compatibility issue with the AAVSO reporting. Nearly all tutorial material I've found for AIJ focus on exoplanets. So, I use it for prep work and intend to upload my calibrated science images to Vphot for photometry.
Edited by Jamey L Jenkins, 07 July 2019 - 08:38 PM.
#9 Ed Wiley
Ed Wiley
  • Loc: Texas, USA
Posted 07 July 2019 - 10:26 PM
I am a mentor and would be happy to help. I also teach CHOICE CCD1 when asked. I am mentoring one person now. Send me a message.
Ed Wiley
AAVSO: WEY
Note: So far as I know, PixInsight does not produce fits files, which the authors say are depreciated (no doubt a surprise to professional photometrists). I don't know if you can convert their format to the fits format. But there are free programs to post-process for photometry.
Note: I use a CCD camera, not a CMOS camera and am interested in how CMOS cameras perform, I assume yours is a mono.
Edited by Ed Wiley, 07 July 2019 - 10:34 PM.
  • Aquarellia likes this
#10 sink45ny
sink45ny
  • Loc: Pennsyltucky
Posted 07 July 2019 - 11:08 PM
Thanks Ed I will message you tomorrow, thank you very much. Yes my CMOS is mono.
I have several ZWO 174mm-cool, ZWO 1600mm-cool and ZWO 178mm.
Obscode-HSTG
Thanks!!
steve
