Some nebula pictures from last weekend
31 replies to this topic
#1 MikeGS
MikeGS
  • Loc: Terrassa (Barcelona)
Posted 08 July 2019 - 07:06 AM
Hi all,
just wanted to share my work from last weekend.
Equipment used: Skywatcher 300p Flextube Goto Dobson, asi294, baader uhc filter.
Captures: all of them taken with Sharpcap, 3s subframes at 570 gain (60s total time), with darks. No post procesing, just played with histogram.
Comments wellcome.
  • highfnum, S1mas, saguaro and 8 others like this
#2 MikeGS
MikeGS
Posted 08 July 2019 - 07:08 AM
M16
  • Starman27, roelb, mikenoname and 3 others like this
#3 MikeGS
MikeGS
Posted 08 July 2019 - 07:09 AM
M 8
  • S1mas, happylimpet, roelb and 4 others like this
#4 MikeGS
MikeGS
M 17
  • S1mas, saguaro, happylimpet and 7 others like this
#5 MikeGS
MikeGS
Posted 08 July 2019 - 07:10 AM
M 20
  • S1mas, happylimpet, roelb and 5 others like this
#6 MikeGS
MikeGS
Posted 08 July 2019 - 07:11 AM
NGC 6888
  • happylimpet, roelb, mikenoname and 2 others like this
#7 Hubert
Hubert
  • Loc: Belgium
Posted 08 July 2019 - 08:31 AM
#8 happylimpet
happylimpet
  • Loc: Southampton, UK
Posted 08 July 2019 - 08:35 AM
Lovely images.
Recently I've enjoyed the images on the EAA forum more than the 'CCD/CMOS' ones etc, as they actually look like the objects in question and havent had the ###### processed out of them to the point of being unrecognizable.
  • bdyer22 and descott12 like this
#9 descott12
descott12
    Vendor - Solar Live View
  • Loc: Charlotte, NC
Posted 08 July 2019 - 09:25 AM
Hi all,
Comments wellcome.
Great shots Mike, I captured an almost identical set in the last few days.
Question: 570 gain?   I have the same camera and think the gain maxes out at something like 515 or 550 and I would never use anything higher than about 270 or 300.  Was that a typo?
Attached is my Eagle Nebula - Evo 8 + Hyperstar + 294 MC + IDAS LPS P2.  5x10 seconds, gain 250
Edited by descott12, 08 July 2019 - 09:27 AM.
  • Hubert and roelb like this
#10 Gyroman
Gyroman
  • Loc: Spokane, WA
Posted 08 July 2019 - 12:24 PM
Lovely images.
I would agree with that. It might be my own incompetence with photoshop but I'm a big fan of EAA as of now.
The ability to see significantly more than fuzzies in my Bortle 5 backyard yet not deal with the complexity (and expense) of true high quality Astrophotography works for me.
  • Roger Corbett and lids344 like this
#11 davidparks
davidparks
  • Loc: Battle Creek, MI - USA
Posted 08 July 2019 - 01:37 PM
The gain for 294 will go to 570 in Sharpcap.  Once of the great things about the 294 is it's HCG Mode that kicks in at 120 (and higher) keeping the read noise fairly flat.  Higher gain will lose some dynamic range, but there is no reason you can't use higher gains... and stacking and dithering go a long way to improve the SNR.
Great results MikeGS!  Especially like your M27!
#12 descott12
descott12
Posted 08 July 2019 - 01:41 PM
I wasn't sure how high it went.Yes, I always keep it above 120 but things get real noisy for me above about 350 or so (and that is with the cooler on).
#13 MikeGS
MikeGS
Posted 09 July 2019 - 01:51 AM
Hi guys, thanks for your comments.
Yes, I know 570 gain sounds like too much. But the asi294 seems to handle it fairly well. I tend to use the maximum gain I can in order to shorten the subframes time and thus the total exposure time. Going beyond the 60s will usually produce noticebale field rotation, so that's why I push the camera to its limits.
Keep in mind I use darks to minimize the noise and hot pixels. The baader UHC filter also requires high gain values, otherwise the result is too dark.
Mike.
  • davidparks likes this
#14 Hubert
Hubert
  • Loc: Belgium
Posted 09 July 2019 - 02:31 AM
Hi Mike, when do you make these darks? Every time Before you start your image session or do you use old ones?
#15 MikeGS
MikeGS
Posted 09 July 2019 - 02:53 AM
Hi Hubert!
Darks can't be recycled from session to session (well you can, but you shouldn't). Conditions are different each night: temperature, humidity, pollution, seeing, etc..
Taking darks is really really simple, especially for EAA where you don't need long exposure times. For me it's just 1 minute (same time as the total exposure I want for my captures).
I usually take the darks after 30 minutes or even more with the tube out and the camera connected, in order to stabilize both the mirror and the camera to the outside conditions. After that time, I cover the scope for 1 minute and take the darks. That easy :-)
Edited by MikeGS, 09 July 2019 - 02:57 AM.
#16 Hubert
Hubert
  • Loc: Belgium
Posted 09 July 2019 - 03:07 AM
And you do this all in Sharpcap?
#17 MikeGS
MikeGS
Posted 09 July 2019 - 03:15 AM
However, I think darks option is only available in the pro versión, which is about 14$/year (the one I paid for).
Edited by MikeGS, 09 July 2019 - 03:16 AM.
#18 Hubert
Hubert
  • Loc: Belgium
Posted 09 July 2019 - 04:30 AM
I also have the pro version but never tried the darks option.
#19 MikeGS
MikeGS
Posted 09 July 2019 - 06:57 AM
Then I recommend you using darks, since you have the pro versión. It's really easy to do and will help you improving your captures quality.
I can notice a lot the improvement because: 1) I use high gain values 2) I got the uncooled asi294 versión
Just remember taking the darks with the same exact values (gain, exp time) as you are going to capture your images.
#20 Hubert
Hubert
  • Loc: Belgium
Posted 09 July 2019 - 07:28 AM
I also have the Asi 294MC, not cooled. I use Sharpcap for solar and moon pictures with my Asi 290 mono. I'm intended to do EAA with the 294 in the near future. Thanks for the info about the darks.
#21 descott12
descott12
Posted 09 July 2019 - 09:00 AM
Hmmm, I thought you could create a library of darks? That is one  advantage of a cooled camera in that you can set the temp, create darks for the various settings you intend to use and save them for later use.
But maybe I have that wrong....I know flats generally need to be recreated each session but I thought darks were different.
#22 mikenoname
mikenoname
  • Loc: Death Valley Region (Bortle 2 - SQM 21.9+)
Posted 09 July 2019 - 10:17 AM
Correct. MikeGS's practice of taking darks for every session is overkill. As long as your camera settings (gain, exposure, etc.) are the same and the temperature is within a couple of degrees of a dark you already have in your library, it is usually fine to use.
I have a library of darks every 5 degrees and use them all the time. The only time I make new ones is when I hit a new temperature range or change a significant camera setting.
  • Lorenz0x7BC likes this
#23 MikeGS
MikeGS
Posted 09 July 2019 - 11:35 AM
That makes sense. I thought darks were more “sensitive” so you needed to create them every session. It’s good advice to have a dark library within a range of settings and use the most convinient set for the current session.
Will do that way from now on.
Thanks!!
  • mikenoname likes this
#24 Hubert
Hubert
  • Loc: Belgium
Posted 09 July 2019 - 12:37 PM
There are different opinions about the darks. Some say that you have to make them every session when the camera is not cooled. That you only can make a library when the camera is cooled.
#25 mikenoname
mikenoname
Posted 09 July 2019 - 01:05 PM
That is certainly not true.
