Mods to your CAT ?
8 replies to this topic
#1 clusterbuster
clusterbuster
  • Loc: Tampa Bay, Fl.
Posted 09 July 2019 - 11:34 AM
Hi All,
 I am very interested in any Mods that you guys have done to your Cats. (they are so Versatile)
 My Celestar  8 has these Mods.
Custom 16" spreader tray with four 2" EP holes.
Meade ETX60 Finder with Rings
Laser pointer (green)
I LOVE THIS CELESTAR 8
Mark
  • wrvond, bbqediguana and rkelley8493 like this
#2 rkelley8493
rkelley8493
  • Loc: Southeast USA
Posted 09 July 2019 - 11:52 AM
Mods to LX90-10:
Visual back upgraded to Baader Click-Lock
Focuser upgraded to Feather-Touch Micro Focus
  • wrvond, bbqediguana and clusterbuster like this
#3 rkelley8493
rkelley8493
Posted 09 July 2019 - 11:55 AM
Mods to LX90-10:
OTA removed from Fork Mount
Losmandy Dovetail Kit for Meade 10" [Riser blocks & Mounting bracket]
Finder scope upgraded to Stellarvue 80mm [F080M3]
Edited by rkelley8493, 09 July 2019 - 12:03 PM.
  • wrvond and clusterbuster like this
#4 bbqediguana
bbqediguana
  • Loc: Canada
Posted 09 July 2019 - 12:31 PM
On my Meade 2080 LX6 Premier, I've done the following:
  • Peterson EZ Focus kit (adds roller bearings to focus knob innards)
  • ScopeStuff Fine Focus Knob (gives larger diameter surface to focus knob)
  • Customer helical focuser on my Meade 1.25" prism diagonal (allows that FINAL layer of fine focus similar to Baader Focusing eyepiece holder)
  • Telrad
  • Dew shield
Other than that, she's pretty stock. Obviously I put most of my effort into improving the focusing - which for me was a BIG help. I now get that same "SNAP"! focus that I get with my f/10 refractor.
My custom helical focuser on my diagonal:
Meade 1.25 inch Star Diagonal with Helical Focuser
#5 junomike
junomike
  • Loc: Ontario
Posted 09 July 2019 - 12:40 PM
Not really Mods per se but my NS11GPS has these additions/upgrades:
~ 2 Speed FT Focuser
~ Starizona Spreader/eyepiece tray
~ Starizona Landing Pad
~ JMI HC holder
~ Baader Click-Lock 3.25" - 2" VB
~ Losmandy Top Plate + bottom CW for mounting of various OTA's/Binoscope.
~ Home made Tripod Spreader/Brace
  • wrvond, bbqediguana, clusterbuster and 1 other like this
#6 wrvond
wrvond
  • Loc: West Virginia
Posted 09 July 2019 - 12:57 PM
Mods include:
ADM vixen dovetail bar on top
Pinty GLP on picatinny rail
StarSense - I also have an optical finder and NexStar + hand control in the case just in case. wink.gif
Feather Touch focuser
SkyFi (wifi)
SkySync GPS
Auxiliary Port Accessory Kit
2 inch William Optics diagonal with roto-lock
Gerd Neumann filter drawer system
Bob's Knobs
Dew Buster
Reflectix
I've changed all the flat 6P6C cables for coiled cables.
Other accessories include:
Anti vibration pads
Dew Shield
Focal reducer
IMG 1794
I started switching over from the WO 2" SCT diagonal to the WO 2" RotoLock this morning before work. This evening I'll take it apart and attach the filter drawer to the new diagonal.
Using the RotoLock set up will allow me to more easily re-orient the eyepiece (or camera) as the scope tracks across the sky.
IMG 1800
Got fully switched over to the Roto-Lock set up with Gerd Neumann filter drawer.
Here it is with the Celestron 0.65 focal reducer in place:
IMG 1802
And here it is without the focal reducer:
IMG 1804
Edited by wrvond, 09 July 2019 - 07:39 PM.
  • bbqediguana, clusterbuster and rkelley8493 like this
#7 desertlens
desertlens
  • Loc: 36°N 105°W
Posted 09 July 2019 - 04:28 PM
I'm an alt-az observer and use several side-saddle mounts. Here's a C6 in rings (GSO 176mm) so I can control the focuser position. The diagonal is a Baader prism with T2 components that gives me about 90mm of path behind the port. The FT microfocuser is a delight to use but a bit of overkill since the stock focuser wasn't all that bad. I have an AstroZap dew shield but seldom use it since I live in a very dry/dark location.  I'm currently working on a similar setup with a C8 mounted on a Losmandy AZ8 (waiting for Parallax rings).
Not visible in the photo are a flocked baffle tube (essential with the C6) and a set of Bob's Knobs for easier collimation (rarely necessary).
Edited by desertlens, 09 July 2019 - 04:38 PM.
#8 macdonjh
macdonjh
Posted 10 July 2019 - 08:07 AM
When I had my C11:
Losmandy dovetail and radius blocks
Bob's Knobs
Flocked the inside of the OTA
Installed internal dew heater
Installed fans
Added MoonLite Crayford focuser
While I had the scope disassembled for other modifications I cleaned and regreased the primary baffle and the stock focuser
Edited by macdonjh, 10 July 2019 - 08:09 AM.
  • clusterbuster likes this
#9 luxo II
luxo II
  • Loc: Sydney, Australia
Posted 11 July 2019 - 05:44 AM
Replaced the focusser on mine: https://www.cloudyni...rtouch-focuser/
... and a trivial modification to add adjustable drag to the Baader focusser...
https://www.cloudyni...track/?hl=+accu
I also have the motor drive kit but haven't fitted it.
Also using an APM diagonal with a roto-lock clamp but I don't consider that a mod...
Edited by luxo II, 11 July 2019 - 05:54 AM.
