ZWOASI 071 pro not connecting in APT?
4 replies to this topic
#1 scadvice
scadvice
  • Loc: Lodi, California
Posted 15 July 2019 - 11:53 PM
I setup my new 071 and connected it to SharpCap first and everything worked fine. Now I'm trying to learn APT and set the camera up there. When I click on 'Connect' ASCOM Camera Chooser comes up and the only option other than the two simulators is 'ASCOM Driver for Nebulosity' . I check properties and it says " nothing to do here." so I hit ok. Connect...message log says "Cannot connect to Camera. Exception occurred."
I'm sure it's me that has missed something but I not sure how to correct it.
Any ideas?
BTW-I don't have Nebulosity.
#2 santafe retiree
santafe retiree
Posted 15 July 2019 - 11:59 PM
Not to be too obvious but you did install the ZWO ASCOM drivers -- ???
https://astronomy-im...oftware-drivers
  • tomwall likes this
#3 scadvice
scadvice
Posted 16 July 2019 - 12:30 AM
Yes I did. But maybe I should re-install them again. I just assumed because it work fine in SharpCap that there should'nt be a problem in that area. However with it tagging ASCOM Driver for Nebulosity I'm wondering....scratchhead2.gif
#4 scadvice
scadvice
Posted 16 July 2019 - 01:18 PM
OK...Reloading the Drivers and got it now connecting.  I suspect SharpCap to be different. Thks.  I'm not sure where the Nebulosity driver came from . I guess it is either part of the driver downloads or left over from when I was playing around with the Nebulosity program earlier this year.
Now I can hopefully move forward to learning the rest of APT. I'm coming from BackyardEOS using a DSLR background going into APT and  the cooled 071.
#5 tomwall
tomwall
  • Loc: Arizona, USA
Posted 01 September 2019 - 11:59 AM
Thank You santafe retiree!!!
Problem solved!!! :-)
I scrolled down on the drivers page and installed,
"ASI Cameras ASI Cameras ASCOM driver to support our cameras."
under the
"ASCOM Drivers (optional)"
heading.
It works like a charm now. I'll append this to your July post.
Tom Wall,
Tucson, AZ
