How to safely remove paint - from Unitron paint, etal....
7 replies to this topic
#1 Bob Myler
Bob Myler
  • Loc: Davisville, MO
Posted 16 July 2019 - 01:43 PM
I recently picked up an early Unitron model 150 - likely built in the late 50's (block lettering) - and I have two questions regarding it.   I would include photos but I'm unable to do so
at this time.....
A.  The 10x42 viewfinder has what appears to be flat latex "china-white" wall paint spattered
onto sections of its (now after 60+ years, Ivory colored) tube.   How might that wall paint
be safely removed without damaging the underlying original paint?
B.   Its rack and pinion focuser is truly massive - with machined knobs - but I'm not sure it
is a true Super Focuser.   For starters, it has no focusing scale.   Its current adapters and
extension tubes only accommodate .965" and 1-1/4" accessories.   That alone would
seem to imply a Deluxe Focuser.    However, my 6" Fecker is equipped with an early (non-
focusing scale) unbranded Super Focuser.   It has an extension tube and adapter that can
thread directly to the 150's R&P main tube, that will in turn directly hold 2" accessories.
So my question(s) are simply this:
Can a Unitron garden-variety Deluxe Focuser be made to do that?   Or do I have an older
version of a Super Focuser that may be adaptable but was never specifically designed to
accommodate 2" components?
Folks, I know very little about Unitrons other than salivating about the larger ones for the past
half-century.   Any enlightenment you could provide me here would be MUCH appreciated!
  • Bomber Bob and shredder1656 like this
#2 J A VOLK
J A VOLK
  • Loc: So. Cal.
Posted 16 July 2019 - 02:09 PM
Not all SuperFocusers had a focusing scale, however it is the only Unitron focuser that can be adapted to 2" without vignetting, as was done on the Vernonscope 94mm and 125mm scopes with lenses by Roland Christen (late 80's). I don't remember the exact dimensions, but if the drawtube is a bit over 2" diameter it is a SuperFocuser.
#3 Thaeland
Thaeland
  • Loc: Cibolo, Texas
Posted 16 July 2019 - 03:07 PM
For latex paint soak it in Goo Gone Latex Paint Cleanup. It shouldn't bother the original paint.
Sent from my Moto Z (2) using Tapatalk
  • Bomber Bob and Ben Bajorek like this
#4 starman876
starman876
    Nihon Seiko
  • Loc: VA
Posted 16 July 2019 - 03:40 PM
The paint could be removed by using a plastic scraper so not to damage the paint under it.  Only the super focuser had the large diameter draw tube.   The regular focuser and the deluxe focuser did not have the very large drawtube which also would fit on the super unihex.
  • TOM KIEHL likes this
#5 Bob Myler
Bob Myler
Posted 16 July 2019 - 05:08 PM
Excellent suggestions - thank you all.
I do think that I may be asking the wrong questions regarding Unitron focusers.....
Anyone here know the exact O.D. of the main tube (not the draw tube) emanating out of a Super Focuser:
the largest tube - the very first one - the one with the attached helical rack?
And is it always different from the 'racked tube' originating out of a Unitron Deluxe Focuser?
Edited by Bob Myler, 16 July 2019 - 05:30 PM.
#6 sgorton99
sgorton99
  • Loc: Wisconsin
Posted 18 July 2019 - 07:11 AM
Here is a restoration thread I did on my early Unitron 150. I ended up having it powder coated. The original paint would flake off if you looked at it wrong.
https://www.cloudyni...age-fork-mount/
This is one of the few classics I have sold that I wish I would have kept (at times)...
Steve
Edited by sgorton99, 18 July 2019 - 07:15 AM.
  • Bomber Bob likes this
#7 Senex Bibax
Senex Bibax
  • Loc: Ottawa, ON
Posted 18 July 2019 - 07:23 AM
When powder coating, it is important to mask off all threads (including threaded holes) and other surfaces where you do not want the coating. Once the coating is baked on, it's like a thin layer of ceramic, and very hard to remove.
I've had motorcycle parts powder coated, and if done properly it looks great. Big variety of colours and textures available these days.
Steve
  • sgorton99 likes this
#8 sgorton99
sgorton99
  • Loc: Wisconsin
Posted 18 July 2019 - 07:39 AM
Yep!
Sacrificial screws can also be helpful.
