NOW AVAILABLE Pegasus Ultimate Powerbox v2
astrophotography imaging
17 replies to this topic
#1 evansg
evansg
    PegasusAstro
  • Loc: Athens, Greece
Posted 18 July 2019 - 02:44 PM
Pegasus Astro is pleased to announce the availability of the Ultimate Powerbox v2
Ultimate Powerbox v2 (UPBv2 in short) is the successor of our renowned Ultimate Powerbox. You asked for more features, we kept our promise:
A USB3.1 Hub has been added -you can switch on/off each USB port –, more power outputs, more dew heaters, α new stepper controller that can drive any stepper motor in the astronomy market as well as an expansion ports for future devices that will communicate with the UPBv2 Controller!
For detailed information: https://pegasusastro...te-powerbox-v2/
Ultimate Powerbox v2 quick glance:
4 x 12V Smart Outputs,
3 x PWM duty cycle channels for your Dew Heaters or Flatpanel / Fans
a USB3.1  SuperSpeed, 5 Gbit/s Industrial Grade Powered Hub that includes 4 x USB3.1 and 2 x USB2 available ports (6 USB ports in total)
a Unipolar / Bipolar Stepper Motor Controller
a Variable / Regulated Output of 3Amps
a 12V / always ON Output
Environmental & Power readings
In a compact size with plenty of features!
Edited by evansg, 18 July 2019 - 02:47 PM.
  • George N, Phil Cowell, psandelle and 6 others like this
#2 psandelle
psandelle
  • Loc: Los Angeles
Posted 19 July 2019 - 03:38 PM
Question (and this looks very cool): when you discuss the variable power plugs (which are the blue RCA-type plugs?) and flatpanels, I never attached my Flatmans/Flatmen to a variable power outlet in the past. Could I do that with this box and is that any different than plugging them into the non-variable outlet?
Paul
#3 evansg
evansg
    PegasusAstro
Posted 25 July 2019 - 09:51 AM
The RCA Outlets are the PWM Duty cycle % power outputs and you can control their power % by our software.
You can easily connect a flatbox or your telescope's fans there.
The variable port is a different port (named ADJ OUT)
Paul
  • psandelle likes this
#4 Phil Cowell
Phil Cowell
  • Loc: Southern Tier NY
Posted 27 July 2019 - 04:22 AM
Well done playing with mine it just arrived. Works really well as a compliment to an Intel Skull Canyon NUC.
#5 Kaydubbed
Kaydubbed
  • Loc: Kansas City, Missouri
Posted 29 July 2019 - 02:27 PM
Mine is arriving today. I was really hoping INDI drivers would have been ready by now, but I know how it goes. I've seen some stock photos of the device package [DC cables, proprietary power cord, temp dongle] showing one bracket being included, but I also see 'Items included' as not including the bracket. I'm hoping I get at least one little bracket!
I am looking forward to my biggest pre-capture time suck being eliminated...cable management.
#6 Kaydubbed
Kaydubbed
Posted 29 July 2019 - 09:48 PM
Sad to say that my first light with the UPBv2 resulted in a burning smell and a dead on arrival unit. I spent two hours recabling, plugged in my camera, Focuser, FW, and mount. It worked for a few minutes, disconnected, and died. I'm just happy my G11T wasn't switched on.
I probably won't be an early adopter of astro equipment in the future. I'll be getting an RMA because I really want this device, but needless to say I'm disappointed.
  • rgsalinger likes this
#7 Lead_Weight
Lead_Weight
  • Loc: Houston
Posted 07 September 2019 - 07:54 AM
Got any updates on your situation? I just ordered one as I'm looking forward to getting rid of several boxes (focus controller, dew controller, USB Hub) in favor of this one.
#8 deepanshu29
deepanshu29
Posted 07 September 2019 - 11:12 PM
Same thing just happened with me. I have my Intel NUC (model #NUC8i3BEK) mounted on my UPB v2 and I needed to update some of my software on NUC. I powered up UPB v2 with my LiFePO4 12Ah battery (it was around 13.8v) as usual, NUC was connected on always ON 12V port. Other 12V ports, USB ports were all disconnected on UPB v2. Environmental sensor was connected. I was just working on NUC, then I heard a pop sound from inside UPB v2, and thick smoke came out. I immediately unplugged the battery, but it was too late. UPB v2 is dead. I had purchased UPB v2 not only for cable management but also to optimize my rig in order to travel. I travel frequently to dark skies which are at least 2 hour drive away from my apartment.
Something like this happening in field can ruin the entire trip. I was also planning to go to a star party at end of this month but I don't get the replacement before that, I won't be able to go. It essentially became a $700 product which failed ($600 for the UPB, and about $90 for the mounting hardware). Extremely disappointed. Have reached out to Evans and waiting for his response.
  • leviathan likes this
#9 Kaydubbed
Kaydubbed
Posted 07 September 2019 - 11:57 PM
I got an RMA from AgenaAstro. Love those guys.
I haven't taken it out much since I'm running INDI now and the driver is still new. It works, but I can't get the focuser to work (Moonlite) but it is unclear if this is an INDI problem or a UPBv2 issue.
Very interesting that I wasn't the only one this happened to. I really thought my homemade DB9 to RJ45 cable I made from a Cisco console cable could have done it but I was told by Pegasus Astro this isn't possible.
  • leviathan and deepanshu29 like this
#10 Lead_Weight
Lead_Weight
  • Loc: Houston
Posted 08 September 2019 - 12:13 AM
Did you end up replacing the cable for your Moonlite? Pegasus makes a cable for it, so I got that, the power box and their A/C power adapter. Should be here Monday. I’ll be using it with INDI as well.
#11 deepanshu29
deepanshu29
Posted 08 September 2019 - 01:03 AM
Evans responded in 20 minutes, that's the quickest response I have ever gotten from a vendor/product developer. Hopefully will get a replacement unit soon and can still go to the star party! Will post back once sorted out.
#12 Kaydubbed
Kaydubbed
Posted 08 September 2019 - 11:51 AM
Yes I use the Moonlite/RoboFocus cable offered from PA.
#13 Lead_Weight
Lead_Weight
  • Loc: Houston
Posted 08 September 2019 - 09:59 PM
Did you record and submit any logs for the developers over on the INDI forum to take a look? That might be one way to tell what the issue is. Assuming the pinout on the cable is correct, it would have to be a driver issue, unless the hardware is bad.
#14 Kaydubbed
Kaydubbed
Posted 09 September 2019 - 09:55 AM
I haven't had time to personally submit logs, but there are a few known issues and a few possible hardware issues. You can follow it here.
#15 MarkSBaker1
MarkSBaker1
  • Loc: Bristow, Virginia USA
Posted 21 December 2019 - 04:14 AM
This is a questionably "short thread" I stumbled onto while looking for EMfocuser set up information using the Pegasus Astro Ultimate Powerbox v2.  After reading the thread though I wanted to offer a few things I 've learned since purchasing the UPBv2 in August.  Cable management is in my mind the key selling point.  I Love this thing!  I have attached this to two different OTAs: an ES 127mm and a Edge 11" SCT.  Both OTAs were attached to my iOptron CEM60 mount.  I've used both the 12-13.8v DC with my 12V Marine Battery and the 12V On connected via a 20 amp AC/DC power cord. I have two different EMFocusers: a Moonlite CFL 2.5" & High Resolution Stepper Motor on the refractor and a Feather Touch with Focus Boss II on the SCT.  I use the UPBv2 software to run both the focusers without additional software using cables with the industry standard pinout (so I am told) for both cables: a DB9 Serial RS232 Port-RJ45 for the Moonlite and a standard CAT5 RJ45-RJ45 for the Feather Touch. I purchased a 3' DB9-RJ45 cable from Amazon: HDE 9-Pin DB9 Serial RS232 Port to RJ45 Cat5 Ethernet LAN Rollover Console Cable Switch Line (Single) for less the $10 US and the other RJ45-RJ45 for a few $ US from my favorite Astro vendor; marketed for a specific brand not Feather Touch to test the "standard pin out"  information i was given and they both work great!
In addition connected to the UPBv2 are: the mounts power connection, 3 dew heater straps with the RCA type plugs, a Imaging, Guide, and Polar cameras using USB 2.0 and 3.0 as required and a cooling fan power connection.  A single USB 3.0 15' cable goes to my laptop; the only other cable leaving the mount set up besides the power. The temperature and humidity sensor works great but be careful how you mount it; veins down or at least at a 45 degree angle to help keep moisture out.
Over the years I've made some very bad purchases!  Money down the toilet and in this hobby where; more money, more money, more money is the montra, this tool is everything it claims to be and worth every penny I spent purchasing it!  When I think of all the cables, controllers and power sources I uses to need to have an enjoyable night imaging........, well no more!!!!!.  I will be purchasing a mini computer as soon as I have some extra cash to spend; I now have a bunch of very expensive controllers I can now get ride of!  anybody.......? :-)
Reading this thread I didn't learn a thing about "properly" setting up my focusers for uses with UPBv2 and so far I haven't found any offers on the internet.  I am able to achieve and maintain focus for my acquisitions but..... if anyone knows where that information is I'd greatly appreciate the assistance.
Clear Skies!
  • Lead_Weight likes this
#16 Lead_Weight
Lead_Weight
  • Loc: Houston
Posted 23 December 2019 - 08:22 AM
Thanks for reviving this post. I spent a few days going back and forth between Pegasus and the INDI developers and now the driver works perfectly on the Mac and Linux. I've been happily using this device for a few months now. It's massively cleaned up my cable act and made setup so much easier. In fact, I went the extra length to put dovetails on all my scopes and got a dovetail saddle that I flipped upside down and used some command velcro strips on the underside of the Pegasus to fix it to the dovetail saddle. I can now easily move it from scope to scope without issue. I wrote about it on my site in detail before I came up with the saddle idea.
Here's the new approach:
  • MarkSBaker1 and Der_Pit like this
#17 Ruediger
Ruediger
Posted 14 January 2020 - 12:55 PM
Just to add... Also my first UPBv2 went up in smoke, a plop and the "smell of free electrons" last summer lol.gif
Also got replacement which works now for 6 months without any problems.
I got the feedback that there could be some problems when switching power on with inductive over current. They had modified the electronics to solve the problem.
Edited by Ruediger, 14 January 2020 - 12:56 PM.
  • MarkSBaker1 likes this
#18 MarkSBaker1
MarkSBaker1
Posted 16 January 2020 - 11:20 AM
Spuntik; I saw some folks had troubles when the UPBv2 was released initially.  I, fortunately have not suffered the same problems.   Update to my earlier post:  I spoke a bit to soon!  I moved my UPBv2 too my 11" Edge HD with a Starlight Instrument's MSM 20 focuser.  I used the pin out information for that focuser from the attached link.  The link provides an overview of the attributes of the UPBv2 and Pin Out information for several of the other common focuser's:   https://pegasusastro...-powerbox-v2/
Edited by MarkSBaker1, 16 January 2020 - 11:30 AM.
Also tagged with one or more of these keywords: astrophotography, imaging
