Needed parts for mounting a TV85 scope to a astrotech voyager 2 mount?
6 replies to this topic
#1 sipster
sipster
  • Loc: Pa. U.S.A
Posted 19 July 2019 - 10:07 PM
Hello everyone.. it's been a while. I have a Televue 85 refractor scope that i have always had on an astroview eq mount. I have decided to lighten the load as my grab and go scope and ordered an Astro Tech voyager 2 mount for it. I have never had an altazimuth mount before. I obviously have clam shell rings for the eq mount. So.. i ordered the Tele Vue adapter that says it's universal to use a televue scope on a vixen style altazimuth or an eq mount. Was that a good idea? Is that all I need? No other dovetail or anything? Will that adapter allow me to attach the scope right to the mount head? I appreciate anyones insight.
#2 Astrolite
Astrolite
  • Loc: S. Central Pennsylvania
Posted 19 July 2019 - 11:33 PM
It's been so many years ago since I did this I can't remember exactly why I did this. I believe it had to do with a clearance issue, either the ring interfered with the saddle on the mount or the screws protruded to far through the Vixen dovetail and interfered with the saddle. but I had to add an aluminum plate between the TeleVue mounting ring and the Vixen dovetail.
Edit: I just re-read your post. If you already had your scope mounted to an EQ mount it should just mount to your new mount without any modifications. A picture of your scope would help.
Edited by Astrolite, 19 July 2019 - 11:37 PM.
  • sipster likes this
#3 Spikey131
Spikey131
Posted 20 July 2019 - 07:41 AM
If you ordered the TV AVT-1011 adapter, it will work just fine with that mount.
Edited by Spikey131, 20 July 2019 - 07:42 AM.
#4 Astrolite
Astrolite
Posted 20 July 2019 - 07:58 AM
But, if as the OP said, "that i have always had on an astroview eq mount", why would he need anything additional to mount it on a Astro Tech voyager 2 mount? Going to Alt Az doesn't require anything special if both mounts have Vixen saddles.
#5 sipster
sipster
  • Loc: Pa. U.S.A
Posted 20 July 2019 - 03:21 PM
Thank you for your response. I'm sure i will figure it out when the new mount arrives.
#6 sipster
sipster
  • Loc: Pa. U.S.A
Posted 20 July 2019 - 03:25 PM
Thank you very much. I would hate to have my thunder that night receiving my new equipment only to realize I needed to order something else to make it work.
#7 sipster
sipster
  • Loc: Pa. U.S.A
Posted 20 July 2019 - 03:47 PM
I don't want to sound like an astronomy greenhorn, but i'm just not sure. I got confused reading the available descriptions. I have never changed mounts before and I don't think the orion astroview eq mount uses a vixen style system. I have never used an altazimuth mount before and I'm just not sure how it mounts until I get it so.. want to make sure I have what I need to assemble it when it arrives. I appreciate your time and responses. Thank you.
