Combining OSC images with Mono images
astrophotography imaging
3 replies to this topic
#1 Brent Jaffa
Brent Jaffa
  • Loc: Utah
Posted 20 July 2019 - 12:20 PM
I have been imaging with a ASI1600  OSC cmos camera. I would like to branch out to a ASI1600 monochrome.
I know that some mono photographers will take Luminous x1 bin and RGB images with 2x2 bin (each).
I was wondering if a OSC camera (that has a bayer matrix) and shoots color with one set of images could be combined
and processed with the LUM images of the mono (say using pixinsight).?
Would they be comparable if the image was shot with Lum (binx1) and RGB (x2 bin) images?
There by require fewer total shots as the mon was combined with the OSC images.
I am new at imaging so this might be a dumb question. Any advice is appreciated.
Brent
#2 apophisOAS
apophisOAS
Posted 20 July 2019 - 12:31 PM
Yes that's completely possible with resizing and cropping say in Registar or similar then process as normal. I have combined DSLR and Mono just over a week apart! ie Pixinsight not needed, or wanted LOL
Capture Details
Stacked with Astroart 7.0 64bit
Registered , cropped and resized in Registar 1.09 64bit new Resolution 5414 x 3436
Processed in Photoshop CS2 v9
Astro Photography Tool
DSLR------------------------------------Canon 1000D modified
Resolution 3888 x 2592
40 Lights @ 300s 16oC - 20oC
Flat / Darks
24/07/2018
CMOS------------------------------------ZWO ASI183MM Monochrome 4/3 CMOS USB3.0 Deep Sky Imager Camera
Resolution 5496 x 3672
60 Luminance @60s -10oC
33 Red @60s -10oC
9 Green @60s -10oC
30 Blue @60s -10oC
Darks / Flats
16/07/2018
HTH,
Roger
Edited by apophisOAS, 20 July 2019 - 12:33 PM.
  • Brent Jaffa likes this
#3 Alex McConahay
Alex McConahay
  • Loc: Moreno Valley, CA
Posted 20 July 2019 - 12:42 PM
The way an L is combined with RGB, is just that.
Your brain is assuming the L, R, G, and B are combined at the same time. In fact, one produces an RGB image and then lays the Luminance over it. Your LRGB image is really an L image overlaying an RGB image.
So, after you get your RGB image, "Register" it to the Luminance frame. This will change its current pixels (which are no longer affected by the Bayer CFA) to the proper size and registration. Then layer your processed L image over it as if that RGB image had been generated with a combination of R, G, and B dedicated filter pictures.
In effect, you have an RGB image whose data comes from a regular Bayer processing while traditional LRGB images have an RGB image derived from the R, G, and B combination. The Luminance does not care where you got the color data, though.
Alex
#4 Brent Jaffa
Brent Jaffa
  • Loc: Utah
Posted 20 July 2019 - 12:52 PM
Thank you Roger & Alex for your response.
The M33 image is very nice!
Also tagged with one or more of these keywords: astrophotography, imaging
