#1
Posted 20 July 2019 - 11:13 PM
- Eddgie, DesertRat, Jim Waters and 14 others like this
#2
Posted 21 July 2019 - 12:01 AM
Real nice image gustavo_sanchez.
EDIT - Nice website..!
Edited by Jim Waters, 21 July 2019 - 12:02 AM.
- gustavo_sanchez likes this
#3
Posted 21 July 2019 - 12:16 AM
Beautiful full disk gustavo.
#4
Posted 21 July 2019 - 12:25 AM
Gustavo,
Nice image! Do you do mosaics or you use a reducer to get a full disk image?
#5
Posted 21 July 2019 - 06:16 AM
Gustavo,
With the LS50 and the 120MM-S, the full disk can be imaged with a single frame, with just about a small patch of black sky to frame it. I don't know if it's worth mentioning, but the blocking filter is the B600.
That being said, while the tilter solved the NR problem, it threw out of whack the spacing and now I don't have enough "intra-focus" to use my 1.3x Barlow solution. Only thing left to shorten the imaging train is to replace the blocking filter nosepiece with a female-female t-thread connection to the helical focuser. Not sure if it will work.
#6
Posted 21 July 2019 - 06:48 AM
If you stick a Barlow in the imaging train, you have to rack out the focuser, so you need an extension actually...
#7
Posted 21 July 2019 - 06:52 AM
Completely true, the focus sits a bit further back with a Barlow. Still, I have to account for the nosepiece holder, which adds too much backfocus. Thus, I have to find a way to move the system forward again. As of now, the Barlow lens screws at the end of the camera nosepiece. I'm still scratching my head around this...I have the LS60 incoming. In my case the ASI120 won’t cut it then.... probably the ASI178 for me....
#8
Posted 21 July 2019 - 06:58 AM
#9
Posted 21 July 2019 - 07:05 AM
#10
Posted 22 July 2019 - 01:19 PM
Very nice FD Gustavo.
#11
Posted 25 July 2019 - 12:28 PM
fantastic image!
#12
Posted 29 July 2019 - 09:51 AM
Just found (and ordered) this "Ultra Short" 1.25" nosepiece holder from Baader; this could be exactly what I need to cancel out the length of the tilter and be able to focus with my 1.3x Barlow. It's about 15mm shorter than the standard Lunt visual back. Fingers crossed.No room for more infocus unless you change the focuser to something shorter. There are shorter helical focusers and an adapter to the Lunt is cheap from RAF Camera
- nicknacknock likes this
#13
Posted 29 July 2019 - 12:01 PM
#14
Posted 01 August 2019 - 10:02 PM
- rigel123 likes this
#15
Posted 06 August 2019 - 12:53 PM
Hi there,
I am about to purchase the Lunt 50mm (same setup as yours, except I'm thinking of going for the feathertouch focuser), and I also own a ZWO ASI120MM Mini. I really like your full disk images and would like to re-create your setup since you seem to have it figured out!
Can you recommend a parts list?
#16
Posted 06 August 2019 - 09:10 PM
#17
Posted 06 August 2019 - 11:05 PM
Hey Ninja, the parts I have added are the ZWO T2 tilter (screw the tilter directly to the blocking filter and the camera directly to the tilter to get full disk images) and the Baader short 1.25" nosepiece holder (if you want to use the lens section of the Baader Q-Barlow screwed directly to the camera nosepiece to get 1.3x magnification instead of the nominal 2.25x from the Q-Barlow).
Perfect, thanks for the advice!
I think I'm about to pull the trigger on the 50.
Is there anything else I should know, since you've had such success with it? You don't find the default helical focuser to be problematic at all for imaging?
#18
Posted 07 August 2019 - 06:04 AM
The focuser is not FT, but it's far from useless. I have no problem getting it to focus correctly in a couple of seconds.Perfect, thanks for the advice!
#19
Posted 07 August 2019 - 10:16 AM
Right on, I'll plan on going for that, then. Thanks for the advice and for the inspiration
#20
Posted 28 October 2019 - 07:09 PM
How did you go about focusing? I have a similar setup and cannot focus and tune for my life if there's no sunspots or proms
Edited by matt_baker, 28 October 2019 - 07:10 PM.
#21
Posted 28 October 2019 - 07:22 PM
Hi Matt,How did you go about focusing? I have a similar setup and cannot focus and tune for my life if there's no sunspots or proms
I have swapped a few things around to try out different setups, but I have always been able to reach focus. Can you please details all the components in your setup? Even better, share an image of your setup? I'm sure I could help you identify the issue.
- matt_baker likes this
#22
Posted 29 October 2019 - 03:18 AM
Matt
Also tagged with one or more of these keywords: accessories
Equipment Discussions →
Mounts →
LX-90 8" Mount won't slew right!Started by redballoon , Today, 07:57 AM ![]() |
Equipment →
LX-90 8" Mount won't slew rightStarted by redballoon , Today, 07:21 AM ![]() |
Classic Telescopes →
Vintage Celestron AccuTrac Drive CorrectorStarted by woodsman , Yesterday, 09:22 PM ![]() |
Mounts →
Heq5 power questionStarted by Teddythefinger , Yesterday, 05:51 PM ![]() |
CN Feedback and Vendor Announcements →
Vendor and Group Announcements →
FREE - nPAE 2020 Astro Calendar and booklet now available - FREEStarted by nPAE , Yesterday, 01:51 PM ![]() |
