Can't figure out how to mount the ZWO EAF (auto focuser) to my telescope
8 replies to this topic
#1 The_8_Bit_Zombie
The_8_Bit_Zombie
  • Loc: A pale blue dot
Posted 21 July 2019 - 11:49 PM
Hi everyone,
I just acquired a ZWO EAF auto focuser, and I can't figure out how to mount it to my telescope, the Stellarvue SV70T. The EAF requires a motor bracket to be attached to the telescope, which mounts like this: https://astronomy-im...ds/DSC_3655.jpg
However I cannot figure out where to attach the screws onto my telescope. As far as I can tell all of the available thread holes on the telescope are being used. The only two candidates that I see are these two:
But I'm pretty sure those are the tension screws for the telescope's focuser. And the other holes look empty, but they all have screws in them.
Is there something I'm missing? It's worth noting that I emailed ZWO before I bought the EAF, and asked if it's compatible with the SV70T. They told me that it is compatible, even though it's not on the compatibility list.
#2 ZL4PLM
ZL4PLM
    Vendor - ZWO Product Dev Team Member
  • Loc: Darfield, New Zealand
Posted 22 July 2019 - 01:57 AM
Here you go :)
remove the middle screw on the left its just a cover
cheers
Simon
SV70T & EAF
  • The_8_Bit_Zombie likes this
#3 The_8_Bit_Zombie
The_8_Bit_Zombie
Posted 22 July 2019 - 04:57 AM
cheers
Simon
Ah thank you so much! So to double check, these are the two screw holes I should use right?
Is the one on the right safe to use?
#4 ZL4PLM
ZL4PLM
Posted 22 July 2019 - 03:47 PM
yup thats the ones :)
#5 The_8_Bit_Zombie
The_8_Bit_Zombie
Posted 27 July 2019 - 02:44 PM
Thanks! I have one more question if that's okay. Should I screw the focus tightener back onto the OTA? (If I even can, not sure that it would fit)
(The one on the far right at the edge of the image)
Edited by The_8_Bit_Zombie, 27 July 2019 - 02:46 PM.
#6 ZL4PLM
ZL4PLM
Posted 27 July 2019 - 10:02 PM
nah its the lock and once EAF Is mounted it won't move anywhere unless powered and moved by the focus control software
#7 b.bill.p
b.bill.p
  • Loc: Orange Co, California. USA
Posted 20 November 2019 - 08:24 PM
I received my ZWO EAF and mounted it on an AstroTech AT80 using images from this forum and a few others.  Total time was about 1 hour plus finding a suitable DC cable.    DON”T forget to purchase a heavy duty 5.5/2.1 barrel connector and cable. Since the ZWO is rated to draw 1/2 amp or more at 12 volts use a good cable that won’t drop the power under surges.
  • psandelle likes this
#8 Ballyhoo
Ballyhoo
  • Loc: San Diego
Posted 20 November 2019 - 11:05 PM
is that cable and conductor you mention a on hand accessory?
Edited by Ballyhoo, 20 November 2019 - 11:05 PM.
#9 b.bill.p
b.bill.p
Posted 21 November 2019 - 01:51 AM
I cut the cable loose from a transformer in my junk box and soldered a new connector to a 12 volt battery. The cable looks like 16 gauge copper wire, more than adequate.
