Mounts for Astro Tech AT60ED
7 replies to this topic
#1 vidrazor
vidrazor
Posted 22 July 2019 - 12:34 AM
Hi folks, I recently picked up an Astro Tech AT60ED as my first scope and noticed the mounts on each side of the scope for spot/guide scope and other peripherals. There's two mounting screws on each side of the scope.
These mount holes are 20mm apart, is this a standard size, or do I need something proprietary to mount something on the scope? Astro Tech has one, but they're out of stock. I've been looking at LED sites and can't find anything to mount them with. Below is a shot of the mount. Thanks for any info on this.
#2 havasman
havasman
  • Loc: Dallas, Texas
Posted 22 July 2019 - 02:40 AM
If you're talking about a finder mount then it really only takes one screw if the underside of the fixture is curved to fit against the scope. The other screw is removed and stored. I mounted a bracket on an ST120 a week or so ago like that and it's solid as a rock. You certainly CAN use two screws but it's not req'd.
I used this base. It has 4 holes for flexibility when matched to the 2 holes on the focuser. https://agenaastro.c...-focusers.html
Good luck with your project.
#3 vidrazor
vidrazor
Posted 22 July 2019 - 12:04 PM
Thanks for your reply. Yeah I guess one screw will hold it, I figured using both screws would align it to the scope better. Your link did not work.
#4 Doug Culbertson
Doug Culbertson
  • Loc: N. Florida
Posted 22 July 2019 - 01:07 PM
This one at Amazon should work. I just bought one for my AT102ED, and your hole spacing looks the same. You can use those same screws. Be aware that if you torque the screws too tightly it will cause the dovetail base to flex inward and your finder base won’t slide in. Took me a few minutes to figure out what was going on there.
#5 havasman
havasman
Posted 22 July 2019 - 01:29 PM
Agena Synta / Vixen Style Dovetail Mounting Base / Shoe for Finders - M4 Screw for GSO Crayford Focuser # CFURB
Our #: OFIN-AG-CFURB            Mfg #: CFURB
That's the page heading for the mounting base at Agena Astro.
#6 vidrazor
vidrazor
Posted 22 July 2019 - 05:56 PM
That's the Bees Knees I think, thanks! The rounded bottoms are a nice touch too.
I think I'll just put some Locktite blue and give a mild tightening.
Edited by vidrazor, 23 July 2019 - 12:26 AM.
#7 OldManSky
OldManSky
  • Loc: Valley Center, CA USA
Posted 22 July 2019 - 07:20 PM
That one from Amazon *will* work.  Very well, in fact.  I have proof :)
WOZ61 Guidesceope Mounting
  • vidrazor likes this
#8 joseph07081
joseph07081
  • Loc: Chippewa, PA
Posted 22 July 2019 - 09:58 PM
I can also vouch for the one from Amazon. I just purchased one for my new AT102ED and it works fine.
