What makes a good binoviewing eyepiece?
44 replies to this topic
#1 Jethro777
Jethro777
  • Loc: Brisbane, Australia
Posted 22 July 2019 - 04:54 PM
Over time, what conclusions have you drawn about what makes a good binoviewing eyepiece?
Is whether it is a premium eyepieces one of them?
#2 Miranda2525
Miranda2525
Posted 22 July 2019 - 05:22 PM
Binoviewing eyepieces don't have to be premium at all. The FL when using binoviewers is a lot longer and more tolerable of edge correction when using cheap eyepieces, especially if using a barlow or barlow lens element.
Super cheap eyepieces shouldn't be used, (for obvious reasons), in case the on-axis views are really bad.
Three of my BV'ing eyepieces are Orion Expanse clones bought off Ebay. Basically, I get two for the  price of one just because it doesn't say "Orion" on the side. I have the 20mm, 15mm and 9mm pairs. They say 68° on the side, but they are really only 66° except for the 9mm which is really 70.1° as measured by one of the experts here on Cloudy Nights.
I also bought a pair of the 23mm Vite Aspheric pairs and they also work really well, but not quite as good as the other three pairs. Eye placement on those is a bit more tricky, but I made my own eyecups for them, making them easier to use.
Now to answer your question: "What makes a good binoviewing eyepiece?"
1. Easy eye placement: (Eyepieces that maybe difficult to use alone will be harder to use as a pair).
2. Light in weight: (eyepieces can get heavy when used in pairs).
3. Be able to produce sharp images across most of the field
4. Have a fairly wide AFOV. (At least 60°)
  • Shorty Barlow, erin, Cali and 1 other like this
#3 Jethro777
Jethro777
Posted 22 July 2019 - 05:57 PM
Thank you, how do you measure the magnification you will get with binoviewing? Is it the same math as when you calculate for a standard eyepiece? What magnification does your 20/15/9 eyepieces give you?
What sort of eyeplacement is best? For example, I am guessing short eye relief eyepieces are not fun?
  • Miranda2525 likes this
#4 doug mc
doug mc
  • Loc: Tamborine Mountain Australia
Posted 22 July 2019 - 06:50 PM
Eyepieces that don't have undercuts. Longer focal length eyepieces are much easier to merge the image than short. Best to use barlows or OCAs to gain higher magnification. Start with plossls and work your way up from there. Depends on your budget.
  • suburbanskies, Jethro777, Miranda2525 and 2 others like this
#5 Kutno
Kutno
Posted 22 July 2019 - 10:27 PM
One will generally pay more for better views; therefore, a pair of premium-priced eyepieces are preferred by this binoviewer.  While I do enjoy looking through eyepieces with narrower fields of view, I particularly enjoy viewing through eyepieces with 82° AFOVs.  Other preferences:  Eye relief:  minimum of 10mm;  Barrel diameter:  less than 2";  Weight:  no more than 9 oz. apiece.
  • CharlesStG and Oscar56 like this
#6 Jeff B
Jeff B
Posted 25 July 2019 - 11:00 AM
NO STINKING UNDERCUTS
Other than that, just about any eyepiece I find "comfortable" and easy to use in mono-vision, is/are, usually, even more comfortable in bino-vision.
Jeff
  • suburbanskies, EverlastingSky, 39.1N84.5W and 5 others like this
#7 denis0007dl
denis0007dl
    Binoviewers Expert
  • Loc: Umag, Croatia, Europe
Posted 25 July 2019 - 11:20 AM
I personally like most all Nagler line T5 and T6, LOAs 32mm both neutral and 3D, and Zeiss Adpherics orthos 25mm FL for low power.
I dont like fat eyepieces, and very very heavy ones, and after many years of trying all existed, I am finally done - nothing else stayed to be tried.
  • semej and REC like this
#8 CarlDD
CarlDD
  • Loc: Scottish more at home in Serbia
Posted 25 July 2019 - 02:50 PM
Hi Jethro
my experience is that premium results in a more comfortable experience than entry level.
A mechanical design that enables the optical centerline of the eyepiece to be aligned with the physical centerline of the eyepiece, followed by, quality control during manufacturing to ensure the optical and physical centerline are exactly the same for each eyepiece of that manufacturers model and focal length.
A design that that allows for comfortable nose relief, lastly and for my use, the ability to accept winged eyeguards although this is quite personal and some folk don’t like them.
I mainly use 4 pairs of Takahashi eyepieces, with a pair of Zeiss and a pair of 19mm TV Panoptics.
Best Regards
Carl
#9 Oscar56
Oscar56
  • Loc: Summerland, BC
Posted 25 July 2019 - 06:32 PM
Denis:
You prefer the LOA 32 over the LOA 21?
#10 denis0007dl
denis0007dl
    Binoviewers Expert
Posted 25 July 2019 - 08:06 PM
Yes I do, but its thing of personal taste and need.
#11 39.1N84.5W
39.1N84.5W
    He asked for it
  • Loc: cincinnati
Posted 28 July 2019 - 09:55 AM
Eyepieces that Barlow well (for using in power slide BVs).
No undercuts.
Small outside barrel housing.
#12 slavicek
slavicek
  • Loc: Massachusetts
Posted 28 July 2019 - 03:20 PM
For cheap binoviewer (= one with small prisms) buy cheap eyepieces, For quality binoviewer, buy wide FOV eyepieces. I use Naglers with TV and Baader binoviewers and they work perfect...
#13 Lookitup
Lookitup
  • Loc: Florida
Posted 29 July 2019 - 12:40 AM
Currently use Pentax xf, Delite's, Vixen ssw and D14's in that order. Only D14 have smooth barrels, all are used mostly for planetary.
#14 Miranda2525
Miranda2525
Posted 31 July 2019 - 02:34 PM
I just time a star very close to zero degrees in declination and divide by four. Get a star on the right and let it drift across the field so that it goes as close as possible to crossing the center of the eyepiece until it goes all of the way to the left, and then divide by 4 to get the field in minutes of arc.
My focal length is 1200mm. A good example is my 20mm eyepieces. I get 155x from them. I can't remember how long it took, as I timed it a while back. I just messed with numbers to come up with close to a 3000mm FL when using my binoviewers.
Another answer to your questions: 20mm's I get 155x. 15mm's I get 200x. 9mm's, I get 320x. The 20mm's give me the best eye placement and eye relief followed by the 15mm's and then the 9mm's.
  • Jethro777 likes this
#15 Kunama
Kunama
    Aussie at large
  • Loc: Canberra, Australia
Posted 31 July 2019 - 08:26 PM
I use Tak LE 5,7.5, 12.5, 18 & 30 , Pentax XF8.5 & 12 and LOA21.
I really only binoview Moon, Planets, Globulars and the brighter Messiers.
#16 vpraghavan
vpraghavan
  • Loc: Southern California
Posted 01 August 2019 - 11:50 AM
The Hyperion Mark IV works well for me with a slight modification. I had to remove the covering around the outer part that is closest to the eye (photo shows this removed). It also does not have the undercut and has zoom in multiple steps.
V.P
#17 Eddgie
Eddgie
Posted 01 August 2019 - 02:21 PM
Yeah, a BV with a pair of heavy eyepieces (Baader Zooms) is very hard on focusers, and most standard Crayford focusers will not cope well with this kind of load.  The only kind of focuser I recommend for this kind of loading is the Feathertouch with the steel rails.  A binoviewer with heavy eyepieces will go though bearings much faster than most other loads.
That being said, I used the Baader zooms with my binoviewers exclusively for planets and really loved them.
No days, I am using a cheap Burgess binoviewer with a pair of Nikon zooms for my Lunt, but my Lunt 80 has the Feathertouch, so I would feel OK using the Baaders in it.   I don't need them, but I would not hesitate to use them.  (The Nikon 7-21s were bought off of Ebay for something like $20 each!  Some shop in Canada was liquidating stock.. Several people bought one.. I bought two.. LOL).
The BV as pictured weighs 240g less than the 31 Nagler behind it!
#18 Jeff B
Jeff B
Posted 01 August 2019 - 03:26 PM
Lately, I've been really enjoying the APM 10, 15, and 18mm Ultra Flats.  Nice and comfortable with good eye relief, barlow very well and a nice 65 degree AFOV, which is sharp to the edge with my slower refractors (F7 and slower), especially with my Denk power switch in place.  Very good solar system eyepieces too as well as very "reasonable" prices for a pair of this quality (both mechanical and optical).
The 24mm version is rather big and heavy but has found a home with out 8" F13 and 11" F12 achromats, serving up some spectacular viewing with those long, slow lenses.  In particular M11 via the 11" F12 from our dark site was stunning with the 24mm's as was M13 and other globs, like M5.
Jeff
#19 25585
25585
Posted 02 August 2019 - 09:15 AM
Long eye relief and easy exit pupil access - even more important than for mono use.
Light weight and thin enough for some i.p.d. variance
On binoculars, I prefer smaller diameter eye lenses than for mono viewing.
#20 sonny.barile
sonny.barile
  • Loc: In the glow.....somewhere between the city and the stadiums.
Posted 03 August 2019 - 07:52 AM
I’m old fashioned and like less glass. RKE and erfle types. Convienently light, small, inexpensive, middle sized fields. Perfect for a long focal length scope in an urban light polluted environment.
Edited by sonny.barile, 03 August 2019 - 07:55 AM.
#21 Ed D
Ed D
  • Loc: Sunny South Florida
Posted 05 August 2019 - 07:43 AM
No safety grooves or undercuts.  I like using good quality Plossls, not necessarily super expensive, but not cheap.  I find longer focal length eyepieces are easier to merge, so I usually use 17mm and longer along with a 2x or 3x Barlow.  YMMV
Ed D
#22 BrightEyes
BrightEyes
  • Loc: Chicago-area
Posted 06 September 2019 - 11:52 PM
Bino ZOOM
I happen to like my Celestron Bino-viewer and bought nearly a twin set of X-Cel LX eyepieces to populate it (9mm, 12mm, 18mm, 25mm) and the 8-24mm ZOOM (pictured above). It just seems easier to coordinate with one manufacturer, truth be told. I use the 2" Diagonal-Mirror, also, to provide more clearance.
Edited by BrightEyes, 07 September 2019 - 12:09 AM.
  • Ohmless likes this
#23 REC
REC
  • Loc: NC
Posted 07 September 2019 - 10:43 AM
I have some Meade Super Plossl's that are under $30 used and work well in my BV. For premium, a pair of Brandon 16mm that are very lightweight, no undercuts and fit the barrel like a glove! Hardly have to use the set screws on them. For some reason, they are amazing on the moon!
  • John Gauvreau likes this
#24 noisejammer
noisejammer
    Fish Slapper
  • Loc: The Uncanny Valley
Posted 20 September 2019 - 12:46 PM
Let's assume you're not asking about 2" eyepieces and your name's not Tycho Brahe.. Look for eyepieces that will allow your nose to fit between them.
Even with my big Tak, Mk V binoviewers and ZOA II eyepieces, my experience is that the exit pupil needs to be 0.6-0.7 mm or the adjustment of the binoviewer spacing becomes trying. Since the scope's aperture is 150mm, I get that the maximum usable magnification is about 150/.6 = 250x.
So what works?
1. You probably can't develop binocular vision over a field that's larger than 65 degrees. An apparent field that's larger than this isn't going to be visible in both eyes.
2. Undercuts can be an issue but this depends on the binoviewer - Baader ClickLocks don't have a problem with any of my eyepieces. From personal experience, I know that Denk II's have an issue with large eyepieces.
3. The weight of the diagonal, binoviewer and two eyepieces adds up. It can cause flex which is not good - so think about mechanical stiffness.
4. Can the eyepiece come to focus? This is only an issue for some eyepieces with deeply recessed field stops like the Masuyama 35mm & its derivatives.
5. How much clear aperture does the binoviewer have? Eyepieces with 27mm entrance pupils will be vignetted by binoviewers with smaller apertures.
6. How much eye relief do you need? Can you use the Dioptrx to correct astigmatism?
7. Batwing eyeguards help enormously as does an observing hood.
My set includes eyepieces from the Delos, Nagler (types 5 & 6), Pentax XW, Takahashi LE, Vixen LVW & ZAO II series. I've also used a friend's Astro-Physics SPL pairs. All of these work really well with my Mk V binoviewers.
I've tried the Svbony offerings but on a tight budget, I'd recommend Meade series 4000 Super-Plossls instead, especially the ubiquitous 26mm.
  • daquad and 25585 like this
#25 Lookitup
Lookitup
  • Loc: Florida
Posted 22 September 2019 - 12:35 AM
Binotron's are not to heavy for balancing on smaller scopes and pretty easy to adjust. To avoid EP's with undercuts, my favorites are Pentax XF and Denkmeier D14's.
