Voyager question #2
10 replies to this topic
#1 bobzeq25
bobzeq25
Posted 23 July 2019 - 09:13 PM
Got everything setup, then hit connect.  Everything connects and is green (including the Celestron motor focuser), except Autofocus-Robofire sends a red error message:
"Object reference not set to instance of an object"
Anyone been there, can explain and/or provide a solution?
Edited by bobzeq25, 23 July 2019 - 09:14 PM.
#2 rockstarbill
rockstarbill
  • Loc: Snohomish, WA
Posted 23 July 2019 - 09:35 PM
Did you install the latest driver for the Celestron Focus Motor? Did you go into the ASCOM config at least one time as well?
#3 bobzeq25
bobzeq25
Posted 23 July 2019 - 10:47 PM
Yes and yes (more than once).  The focuser connects, it moves, I even recalibrated it.
#4 bobzeq25
bobzeq25
Posted 24 July 2019 - 12:48 AM
It suddenly started working.  Going to have to do some serious reading on Voyager, it's not intuitive.  Imagine that.  <smile>
  • ChrisWhite likes this
#5 kathyastro
kathyastro
  • Loc: Nova Scotia
Posted 24 July 2019 - 07:37 AM
That is an indication of defective software.  No application should ever give that message to a user.  The message is for the software developer, telling him that he screwed up and needs to do more testing.
  • rgsalinger likes this
#6 Leonardo70
Leonardo70
    Vendor (Starkeeper Software)
  • Loc: Turin - Italy
Posted 24 July 2019 - 08:47 AM
Yes kathyastro ... Voyager is really a terrible software !
Thanks, i'll do more testing.
#7 Leonardo70
Leonardo70
Posted 24 July 2019 - 08:57 AM
Select an ASCOM Focuser for RoboFire is requested when you select this kind of AutoFocus. A field selector will appear (and only for this kind of control) under primary control. If you leave to "None" the selection field you receive this error. I'll add a better error message.
Thanks for your interest in Voyager, i'm not reading everytime this forum.
All the best
LO
#8 bobzeq25
bobzeq25
Posted 24 July 2019 - 09:34 AM
Thanks for your interest in Voyager, i'm not reading everytime this forum. If need more help please join our community or write direct to support, link about in the Voyager Resource menĂ¹.
All the best
LO
Thanks.  Just, for your information, as you look at this issue.  I had already selected ASCOM focuser for Robofire, and had clicked the ASCOM button, and connected to and set up the focuser in ASCOM.  During my initial setup.  And was still getting the message.  I restarted Voyager several times.
I honestly have no idea why it started working.
Where is your community located?  Is there a forum?
I did successfully shoot my first sequence (just a test) last night.
The English wiki was very helpful.  I think this will be a good program for me, once I learn about it.  Robofocus did work well, generated a nice looking curve in a short time.  I experimented with a number of Robofocus options.  I need to figure out which Robofocus option will be best for me, and how to configure it.
You've produced some fine software.  Thanks again.
Edited by bobzeq25, 24 July 2019 - 09:41 AM.
#9 Eric Horton
Eric Horton
Posted 24 July 2019 - 09:46 AM
These should help:
There is a public forum dedicated to Voyager :
https://forum.starkeeper.it/
There is also a joint Facebook group:
https://www.facebook.com/voyagersw/
A videotutorial channel  here:
https://www.voyagerastro.com/videos/
A video introduction to Voyager from Diego Colonnello here:
https://forum.starke...out-voyager/250
A new wiki unofficial from USA users found here:
https://voyager.tour...title=Main_Page
  • bobzeq25 likes this
#10 Leonardo70
Leonardo70
Posted 24 July 2019 - 09:48 AM
Probably you had setting up ASCOM but click cancel button in ASCOM form, in this case the ASCOM driver string name will be cleared and for Voyager is equal to no driver choosed.
RoboFire have an internal AI automa, usually the default setting are good for all at 99% . You can decide if use focus on a single star or with a field and for field if you want to use all field or a reduced part in %. This depends on your instrument type and on flat field correction.
All the best
LO
Edited by nmoushon, 02 September 2019 - 09:01 PM.
#11 bobzeq25
bobzeq25
Posted 24 July 2019 - 10:08 AM
Possible, but not "probable".  I've been doing this for 4+ years, have a _lot_ of computer experience here and elsewhere.  Went through the ASCOM process a few times.  I'd have had to make the mistake (an obvious one) more than once.
It's possible.
Thanks for the links.  I'll be asking my questions on that forum in the future.
Edited by bobzeq25, 24 July 2019 - 10:14 AM.
