Post a picture of your refractors (part 8)
1633 replies to this topic
#701 YAOG
YAOG
  • Loc: Southern California
Posted 20 January 2020 - 01:41 PM
Dual mounted my Apo's on my Atlas Pro cool.gif May try this out under the stars tonight
Be sure you let the SVA130 cool down long enough, you may be surprised at the eyepiece views when comparing them at high magnification until the SVA130 cools. Set them outside without any sunlight falling on them a few hours before sunset and the acclimation time will be shorter. My experience with medium size air spaced triplets is they need a good 30-120 minutes cooling time depending on the temperature difference between where they were stored and the observing time temperature. Also know that while you may not feel it any sun directly or indirectly hitting the tubes will warm them and the glass and cells. Keep them in the dark when placing scopes outside to speed waiting time for acclimation. Take notes and get back to us tomorrow!
  • Philipp and rkelley8493 like this
#702 rkelley8493
rkelley8493
  • Loc: Southeast USA
Posted 20 January 2020 - 01:54 PM
I usually set the scope in my back porch storage closet a few hours before setup. It stays pretty close to outdoor temperature this time of year. By the time I get everything setup, it's right at thermal-EQ.
Edited by rkelley8493, 20 January 2020 - 01:56 PM.
  • YAOG likes this
#703 Philipp
Philipp
Posted 20 January 2020 - 02:38 PM
there is a Baby Tak hiding somewhere in this mess!
  • Scott Beith, zjc26138, Jaimo! and 5 others like this
#704 John Huntley
John Huntley
  • Loc: SW England
Posted 20 January 2020 - 02:46 PM
My TMB/LZOS 130 F/9.2 triplet observing Venus this evening:
P1090416.JPG.9ed6bfad33b5b564965c125d8c7
  • Paul G, Scott Beith, zjc26138 and 27 others like this
#705 t-ara-fan
t-ara-fan
  • Loc: 50° 13' N
Posted 21 January 2020 - 01:52 AM
Nice monster.  Tame it.
  • Philipp likes this
#706 HydrogenAlpha
HydrogenAlpha
  • Loc: Singapore
Posted 21 January 2020 - 11:45 AM
A little size comparison between the APM LZOS 130 f/6 and a Tak FS60CB:
Interesting fact: both of these setups give similar pixel scales and FOV despite the huge physical size difference.
  • Scott Beith, zjc26138, doctordub and 20 others like this
#707 YAOG
YAOG
Posted 21 January 2020 - 12:54 PM
Hmm, not possible without using the extender on the FS-60CB or a big reducer/flattener on the 130 f/6 using the same camera. Changing the camera also fixes the poor pitch/resolution of the 60mm optic.
Edited by YAOG, 21 January 2020 - 12:56 PM.
  • doctordub likes this
#708 HydrogenAlpha
HydrogenAlpha
  • Loc: Singapore
Posted 21 January 2020 - 01:24 PM
Different camera indeed. Top one features the ASI183MM, bottom one features the Atik 16200. I'm running the 130 at f/4.5
#709 Philipp
Philipp
Posted 21 January 2020 - 01:57 PM
The short USB cables would help a bit (one of my USB-C cables was actually too short) but the dew heater cables and the temperature sensor cables are too long for this setup, and I do not want to cut and reconfigure them, as with other scopes I need them longer.
Phil
#710 mike17
mike17
  • Loc: Colfax, WI
Posted 22 January 2020 - 09:40 PM
Just got the new TEC 160 FL mounted.  Hoping for lots of clear nights
  • Scott Beith, Paul Hyndman, zjc26138 and 34 others like this
#711 bchandler
bchandler
  • Loc: The barycenter of clouds & kudzu: North-Central Alabama, NA
Posted 23 January 2020 - 01:47 AM
Zip ties try you must.
-Master Yoda
#712 desertlens
desertlens
  • Loc: 36°N 105°W
Posted 23 January 2020 - 03:05 PM
Fresh off the boat:
Sharpstar 76EDPH: 76mm, ƒ5.5, Triplet
  • Scott Beith, F.Meiresonne, zjc26138 and 24 others like this
#713 Tyson M
Tyson M
  • Loc: Canada
Posted 23 January 2020 - 11:05 PM
Fresh off the boat:
Cool scope, never saw one before.
  • desertlens likes this
#714 desertlens
desertlens
  • Loc: 36°N 105°W
Posted 24 January 2020 - 12:31 AM
Yep, a very recent release. I just noticed it a couple of months ago. There's a nice 61mm doublet also, with the same basic design. Both are available with an FR/FF.
https://agenaastro.c.../sharpstar.html
Edited by desertlens, 24 January 2020 - 12:32 AM.
  • eros312 likes this
#715 mtminnesota
mtminnesota
  • Loc: St. Paul, Minnesota
Posted 26 January 2020 - 08:52 PM
New G11G HD, I just set it up today.
  • Scott Beith, zjc26138, 3 i Guy and 26 others like this
#716 Joe1950
Joe1950
Posted 26 January 2020 - 08:57 PM
ENJOY MIKE!
  • mtminnesota likes this
#717 Heywood
Heywood
Posted 26 January 2020 - 09:14 PM
Nice set up!!
Does your G11G have the G11 RA Extension Kit?  It looks like it does.
Thank you.
#718 mtminnesota
mtminnesota
Posted 26 January 2020 - 09:55 PM
Nice set up!!
Thank you.
It does, and it's a very worthwhile accessory for a G11 in my opinion.  I got the mount cases, tripod case, Polemaster, rubber tripod feet, tripod mounting knobs, clutch knobs, and have altitude knobs and lower tripod levers on the way, but the Extension Kit is the best.  I also like the lower tripod levers, which replace the big round knobs.  With all three knobs attached, the tripod won't fit into it's case, but the levers should allow that.
The tripod in its case, the mount in its cases, and my Starbound observing chair will stay in my car.  I only have to carry the OTA (in an Orion bag) and Pelican case of glass accessories back and forth to the car for observing sessions.  Now if only these skies would clear!
#719 ckwastro
ckwastro
  • Loc: Tempe, AZ
Posted 27 January 2020 - 08:26 AM
I can’t tell from the Losmandy website, but do you know if there is any protective foam or padding in the mount and tripod cases? I also have a G-11 with the RA extension, and have been looking for cases, at least for the head. From the website pics, there doesn’t appear to be much protection with those. Thanks.
#720 Rick Duering
Rick Duering
  • Loc: South Texas
Posted 27 January 2020 - 08:46 AM
My FC100DC observing the double cluster this evening.
  • Scott Beith, zjc26138, doctordub and 16 others like this
#721 Rick Duering
Rick Duering
  • Loc: South Texas
Posted 27 January 2020 - 08:53 AM
This is my grab & go version of it!
  • Scott Beith, zjc26138, doctordub and 14 others like this
#722 mtminnesota
mtminnesota
Posted 27 January 2020 - 01:44 PM
There is a layer of closed cell foam at the top and bottom of the tripod case.  The mount cases don't have any padding, but they don't seem to need it because the two mount components attach firmly to the bottom of the cases (when you have the RA extension kit).  Once attached, they don't come into contact with anything but the bottom.
Edited by mtminnesota, 27 January 2020 - 08:43 PM.
  • ckwastro likes this
#723 ckwastro
ckwastro
  • Loc: Tempe, AZ
Posted 27 January 2020 - 03:20 PM
There is a thin layer of closed cell foam at the bottom of the tripod case.  The mount cases don't have anything, but they don't seem to need it because the two mount components attach firmly to the bottom of the cases (when you have the RA extension kit).  Once attached, they don't come into contact with anything but the bottom.
Thank you!
#724 NVDW
NVDW
Posted 27 January 2020 - 03:56 PM
My second setup now... (not including my classics ofc :)) f6e3625fc0a5271bef03a9d0f2b39654.jpg
Verstuurd vanaf mijn MI 8 met Tapatalk
  • Scott Beith, zjc26138, doctordub and 8 others like this
#725 doctordub
doctordub
  • Loc: New Rochelle, New York
Posted 27 January 2020 - 04:17 PM
My babies, 2.5 lbs - 19.8 lbs!
CS
Jonathan
  • Scott Beith, zjc26138, stevew and 23 others like this
