I am starting a new thread for my Nikon Z6 testing.
It will take me a few weeks to run all the tests I need to perform and to write a proper review but I'll post some early findings here.
Meanwhile anyone interested in the Z6 should check out Alan Dyer's review because I don't intend to duplicate what he has already done:
https://amazingsky.n...trophotography/
Read Noise, Gain etc.
I also don't intend to reproduce Bill Claff's excellent work:
- Read Noise: http://www.photonsto...tm#Nikon Z 6_14
- Dynamic Range: http://www.photonsto...R.htm#Nikon Z 6
I have arbitrarily decided to perform most testing at ISO 800, which is where the sensor switches to HGC (high gain) mode. At ISO 800, I determined the read noise to be somewhere in the range 1.67 to 1.93e RMS. Bill reports 1.705e. My uncertainty is caused by the fact that successive bias frames often have histograms with gaps in different places. This odd behaviour affects the measured standard deviation and hence the implied read noise.
Quantum Efficiency (QE)
One of the things that really interested me about the Nikon Z6 was the quantum efficiency. Some time ago I developed a way of analysing the raw files that can be downloaded from DPReview's Studio scene to deduce camera gain (i.e. the conversion factor from pixel values to electrons) and hence the number of captured photons.
e.g. https://www.dpreview...656129343629345
To compare cameras using this analysis relies on several assumptions:
- the scene is always illuminated with identical brightness
- the focal ratio of the lens being used is accurate
- the reported shutter speed of the camera is accurate
The results suggested that the back side illuminated (BSI) sensor in the Nikon Z6 was capturing 14% more photons in the green channel than the existing low-light king, the Sony A7S. Single value QE figures typically use the green channel.
I have now tested the 2 cameras with the same fully manual lens i.e. the lens has a good old aperture ring. I get the same result - the Z6 is capturing 14% more green photons that the A7S. However, I am not an expert in sensor construction so I can't tell if 14% is a reasonable increase for BSI technology.
If it is correct that the Z6 has a higher QE then it means that the Nikon Z6 should outperform the renowned Sony A7S in situations where sky fog is the dominant source of noise i.e. typical long exposure astro-imaging.
However, for situations dominated by read noise (e.g. low-light video) the Sony A7S will be impossible to beat. The slowest frame rate on the Z6 is 25 frames/sec compared with 4 frames/sec on the A7S. So I can't do the trick of composing the scene by briefly switching to Movie mode at high ISO and low frame rate.
Mark
Edited by sharkmelley, 28 July 2019 - 06:38 AM.
