I've made a little bit of progress on the "coloured bands" issue. The breakthrough was finding the same artefacts in my PixInsight integration rejection maps.
Here is the stretched image alongside a rejection map which I processed to enhance the artefacts:
[click on image to see it full size]
If you don't know where to find them, I've highlighted the coloured bands in the image below:
There are two big swirls of red/blue marked by the red pen. These are the bands I first noticed in the image. In addition there are some yellow concentric rings marked by the blue pen. Knowing the position of the yellow rings I was able to find them in the image, though I hadn't noticed them previously.
These coloured bands do not exist in the calibration frames but only in the lights. However, knowing where to look I've gone back to my previous images and found the same coloured bands in the same place in the rejection maps and highly stretched integrations of 3 out 4 of the images I've taken so far. Each image was 60x 2min at ISO 800 giving 2 hours of integration time. In the 4th image the position of the bands had moved - the swirls and concentric rings were more widely spaced and fainter. The first 3 images were taken under more or less identical sky conditions (SQM around 20.8) with the back-of-camera histogram peak at the 1/5 to 1/4 position. The 4th image was taken nearer the horizon and had brighter light pollution background.
This 4th image might provide a clue. Moving the histogram peak further to the right in the back-of-camera histogram might overcome the issue. This was certainly the case when I encountered colour banding in my Sony A7S images. Before I can be certain, it will be necessary to set up some indoor test conditions where I can reliably reproduce these effects.
In general, with very faint artefacts such as these, they only begin to appear when stacking a large number of images because this reduces the noise level down to the point at which they are potentially visible with heavy stretching. Many users will never encounter them because they are not stacking large numbers of exposures and are not stretching images sufficiently to show, or instance, the colour in faint clouds of background dust.
Mark
The Sony A7R3 has a history of giving colored bands on certain lenses, even when shooting uncompressed raws with all lens compensation settings turned off. It's only obvious on certain lenses and even then only when the background is mostly white or black. The only solution I have found so far was to tape up the electrical contacts on the lens, as demonstrated in this post. I am assuming your camera makes no electrical contact with the optics (as you are using a telescope)?
Newton's rings?
From where?
