M8, M20 Hypered Arista EDU 100
No replies to this topic
#1 Todd N
Todd N
Posted 03 August 2019 - 10:35 AM
https://www.flickr.c...eposted-public/
Another iteration in my astrophotography pursuit that didn't pan out as well as anticipated; Better than the last time though. Arista 100 has been among the best responses to hypering in my testing.  It's a traditional style film that had a bit of minor grain in test shots; No big deal from my point of view but, as you can see it looks more like an ISO 400 film. I've had the same outcome with hypered Tri-X. My supposition is these modern film formulations are using a combination of large and small halide crystals where the smaller ones of coarse giving a finer overall grain appearance. Modern Tri-X is incredibly fine grained for an ISO 400 film that rivals an ISO 100 film. But, I think the "low light" conditions aren't activating the smaller halides and are left with the bigger crystals only coming into play hence grainy picture. I suspect this hypered film would best be employed with longer focal lengths and brighter deepsky objects.
Arista EDU 100
Hypered H2 6psi 52hrs @30C *
Preceded by overnight vacuum
HC-110 1/63 dilution
Canon Rebel 2000
200mm 1.4x: 280mm f.l. @f4.5
Single 20min. exp.
* In my testing with many films(Namely Kodak and Arista) higher heat(40C) is negatively effecting the films producing low contrast. Lowering the temp eliminated this issue. I now have standardize on on temps 30C to 33C.
Todd
  • Eric P, Joe F Gafford and ngc7319_20 like this
