C90 Maksutov collimation error
22 replies to this topic
#1 MikeTelescope
MikeTelescope
Posted 05 August 2019 - 03:00 PM
I bought a used C90.  Star testing at a 0.6mm exit pupil (138x) shows fairly good diffraction pattern.  Rings look concentric.  As it is brought to focus, when there are only one or two diffraction rings visible, the light collects at one point on one of the rings.  Bright spot on one ring gets brighter and brighter until it reaches focus.  Going through focus, the light stays collected at that point, and the diffraction rings open up again, away from that point of light.
Is this a collimation error, or a different aberration?  There are 6 collimation screws on the back mirror.
Planetary views at 138x are OK.  I can see the Cassini division and some cloud bands on Saturn, and several cloud bands on Jupiter.  Going up to 208x, the image significantly breaks down.  Images from an 8" Newtonian at the same time are fairly good, so it is not poor seeing.  I understand the resolution of a a 90mm Maksutov should be less than that of an 8" Newtonian, but I have read others get sharp views up to 200x and beyond on a C90, and wonder whether there is a collimation error that could be improved.
I have tried the star test without the diagonal and see something similar.
Assuming good seeing, what would be a reasonable maximum magnification for a 90mm Maksutov for planetary detail?
#2 Saturnalia
Saturnalia
  • Loc: England
Posted 05 August 2019 - 04:07 PM
Generally 50X per inch of aperture is a rule of thumb 'maximum' magnification so around 175x for your Mak.
Try somewhere between 150 to 180x and see if it helps. The quality (rigidity) of your mount will also play a big part in the image quality at high magnifications.
What eyepieces are you using...?
Edited by Saturnalia, 05 August 2019 - 04:07 PM.
  • MikeTelescope likes this
#3 MikeTelescope
MikeTelescope
Posted 05 August 2019 - 04:25 PM
Orion Expanse 9mm and 6mm.  Also tried Celestron Plossls at 13mm, 8mm, and 6mm.  Similar trend seen.  Mount is a fairly heavy Manfrotto that dampens quickly.
The diffraction rings look pretty good when far out of focus, and come in nicely, until the very end when the rings are very small just before focus, and the light concentrates on the edge of one of the rings, rather than equally around the ring to a single point at focus.  This is what makes me think there could be a small collimation error that could be cleaned up.
  • nicoledoula likes this
#4 kathyastro
kathyastro
  • Loc: Nova Scotia
Posted 05 August 2019 - 04:55 PM
Which C90 do you have?  The original orange tube C90 was f/11, and is a different item than the modern f/13 C90.
There was a problem with the orange tube C90s made in the 1980s.  Celestron was cranking them out in the lead-up to Comet Halley, and quality control suffered.  Poor collimation was common.  Unfortunately, collimation was permanently set at the factory and can not be adjusted: the mirror is glued in place.
I don't know the construction details of the modern C90s.  Perhaps they can be collimated.
It sounds like you may be pushing the magnification too hard.  On the old f/11 units, 11mm is the highest magnification eyepiece you should be using.  On the newer f/13 units, 13mm is the maximum magnification.  On my f/11 C90, quality deteriorates rapidly with eyepieces shorter than 11mm.  Even 9mm is too much.
Edited by kathyastro, 05 August 2019 - 04:57 PM.
#5 MikeTelescope
MikeTelescope
Posted 05 August 2019 - 05:27 PM
It is one of the modern f/13.8 C90's.  There are 6 collimation screws on the back plate.  I'm tempted to tweak them a bit to see if I can get that last bit of error out.  But I'm a little wary of making it worse too.
I have tried a 10mm Kellner and got good planetary detail, and a 9mm Expanse looked decent as well.  8mm Plossl started getting softer, and 6mm Plossl was unusable (as was the 6mm Expanse).
The above-described asymmetric diffraction ring brightening was more pronounced with the 6mm.
#6 Jim1804
Jim1804
  • Loc: Raleigh-Durham NC, USA
Posted 05 August 2019 - 08:04 PM
I collimated mine - I still might have a tweak or two to go, but it definitely helped. Just try REALLY small movements - lots of instructions in different posts on CN.
#7 Jim1804
Jim1804
Posted 05 August 2019 - 08:07 PM
See these instructions- https://www.cloudyni...0/#entry6217519
  • BFaucett and MikeTelescope like this
#8 MikeTelescope
MikeTelescope
Posted 12 August 2019 - 01:40 PM
Just to close this thread out.. I did follow the instructions in the link (thank you Jim), and the short story is that the C90 is now better collimated than before.  Star test on Polaris now shows a symmetric pattern, with almost no hint of head or tail.  Formerly, there was a pronounced head/tail at 139x, moreso at 208x.  The effect in the eyepiece is much sharper and more detailed views of Saturn and Jupiter all the way to 208x.  Moon detail at 208x is also increased.   Epsilon Lyrae split at 139x very cleanly (probably could split at a lower mag but didn't try.)  At 208x, the brightest ring of the Airy disk of each of the 4 components did not overlap with its neighbor's ring.
Long story is that I had to do the opposite of what the link said.  I did have a mirror diagonal in place, as mentioned in the link.  When I followed the instructions, the situation got worse.  So I swapped counterclockwise and clockwise, and I had it collimated in about 15 minutes.
As Jim mentioned, use small movements and check after each one.  It was worth the 15 minutes of work to get noticeably better high-magnification views from this scope.
  • Asbytec, Jim1804 and BFaucett like this
#9 Asbytec
Asbytec
    Guy in a furry hat
  • Loc: Pampanga, PI
Posted 12 August 2019 - 06:17 PM
Sorry I am late to the party reading your thread. It does sound like collimation as you seem to have figured out. Two things come to mind. First, you have to be a little wary of making it worse before you can make it better. In other words, you have to collimate it and figure out which way to turn the knobs. Second, if you can make it worse by adjusting collimation, that's a good thing. It means you can likely make it better by collimating the other way. You did exactly that, well done. Now, get it 'perfect' at high power close to focus, then you're on it.
#10 MikeTelescope
MikeTelescope
Posted 13 August 2019 - 05:10 PM
I have a knack for taking things that are at 85% and making them 75%.  I use almost exclusively second-hand Craigslist gear, to keep costs down and so when I break things, it doesn't hurt as much.  I like to make all my mistakes on inexpensive used things first and learn in the process!
  • Asbytec likes this
#11 Jim1804
Jim1804
Posted 14 August 2019 - 12:03 AM
Mike - glad it worked out - those instructions by Eric63 are really clear.
And I hear you - when I first tried to collimate mine, I used the instructions on the Orion site for their Mak (also a Synta identical to the C90). They recommend collimating from the back during the day - you stick a collimating eyepiece in the visual back, and just get everything lined up and concentric. I got so turned around with the hall of mirrors, that I made it much, much worse. I ended up having to loosen all the screws, which reset the primary to more or less the right position. From there it wasn’t too bad to collimate on a star - but man was that a frustrating experience. My kids heard some new words that afternoon!
I haven’t had mine over 150x or so (8mm EP). I’ll have to go higher and see how it looks. I suspect I have a small turn or two to make on a couple of screws, but the seeing is so bad here it’s hard to get Polaris stable enough to check!
#12 MikeTelescope
MikeTelescope
Posted 14 August 2019 - 01:04 PM
Jim, thanks again for sharing the instructions.  I printed them out and had them in hand while collimating in Polaris.  I got lucky and had a night with good seeing.  The good seeing also allowed me to enjoy some fruits of the labor by viewing a crisp Saturn at 208x and resolving Epsilon Lyrae following the collimation.
I'm still confused why I had to swap clockwise and counterclockwise.  I did have a mirror diagonal in place, as the directions specified.  Could be that the C90 screw orientation is different from the 127mm Mak for which the instructions were written.  In any case, it was easy to detect that I had gone the wrong way and then change course.  I think I practiced some of those words at that moment as well.
I think I'm about 90-95% there and still want to get it to that elusive 100%.  This little scope seems to be able to be pushed to 60x per inch with good seeing, or perhaps a bit beyond that.  Great for grab-and-go planetary and moon viewing and double star resolving.
#13 Euripides
Euripides
  • Loc: Thessaloniki - Greece
Posted 13 October 2019 - 05:21 PM
I've found that my SkyMax 90 has also this issue (2months old). I've created an "artificial star" with my headlight and the procedure went really well.
But my concern is that the star, rings, etc have to be aligned exactly at the center. If it is a little off, you will see the rings as out of collimation. And I'm not 100% sure that I've achieved that.
@Jim1804
Do you mean something like this
#14 Sky Muse
Sky Muse
  • Loc: Mid-South, U.S.
Posted 13 October 2019 - 06:19 PM
@Jim1804
Yes, that would work.  You may not need or want the cross-hairs when collimating a refractor or Maksutov.  If they do present a problem, they appear to be removable.  A penlight is used to illuminate the scene...
#15 Euripides
Euripides
Posted 14 October 2019 - 12:18 AM
Thanks, Sky Muse!
I am a little confused. You said that "You may not need or want the cross-hairs when collimating a refractor or Maksutov".
Is this not the feature we are looking for on this product? The crosshair so we can center the out of collimation view or am I getting it wrong?
If I look through this, is this the view I could get?
#16 Sky Muse
Sky Muse
Posted 14 October 2019 - 02:56 AM
Thanks, Sky Muse!
I can see right there that the collimation is a bit out, on that one.  I have a 127mm Maksutov, an Explore Scientific, and it arrived spot-on.  I haven't had to touch it...
That being an out-of-focus pattern of Polaris, the North Star, and through said Maksutov.
But a relation has a C90, here in the household, but I'm the only who has used it at night...
It, too, is in need of collimation, but I haven't attempted it yet.
The modern Cheshires combine a Cheshire with a sight-tube.  I have a sight-tube for Newtonians, and a Cheshire for refractors, separately...
That Cheshire does not contain cross-hairs, and as the sight-tube does.  Being that a Maksutov is a reflector, and with a secondary-obstruction, then perhaps the cross-hairs will help.
  • Euripides likes this
#17 Asbytec
Asbytec
    Guy in a furry hat
  • Loc: Pampanga, PI
Posted 14 October 2019 - 08:24 AM
Thanks, Sky Muse!
The cross hairs may help you find the (very near) center of the FOV where you evaluate collimation. From the image above, the star image should move in the direction of the wider rings (Gosh, I hope I remember that correctly. Been a while). Then recenter on the cross hairs and look again.  (If not, go the other direction, then recenter and check again). In other words, use the cross hairs to help you place the defocused star in the field center. That should work. Then collimate as normal to eliminate the coma on axis both out of focus and in focus.
#18 Jim1804
Jim1804
Posted 14 October 2019 - 11:03 AM
@Jim1804
Do you mean something like this?
This is what I mean -
https://agenaastro.c...t-eyepiece.html
But like I said, I didn’t have much luck trying to collimate this way, but no doubt more experienced folks might have different results.
#19 Euripides
Euripides
Posted 05 November 2019 - 04:07 PM
I would like to update for anyone is interested on that.
I have purchased this to help me with the crosshair. I couldn't trust myself about the center...
Also I found this pdf file while googling. Attached File  MAKSUTOV COLLIMATION.pdf   36.54KB   29 downloads
The file is not mine but I can't recall where I found it, so if anyone knows the author, please be my guest to inform me to provide the original link.
As you can see on the 2nd picture, I had to fill in to the down right side so I had to start with the marked screw first (pic 3).
​This pdf file help me a lot! so, take a closer look and I think you will not have any issue.
#20 Asbytec
Asbytec
    Guy in a furry hat
  • Loc: Pampanga, PI
Posted 17 November 2019 - 05:32 AM
Wow, I have never collimated a MCT like that. Lost of curiosity about how well it works. Were you able to "fill in" down and to the right by using the primary adjustment screws? Without adjusting the secondary by shifting the meniscus? I am just not familiar with the axial alignments from this perspective, I always use a star (hence my post above). Interesting. How accurate was the collimation when testing on a star? Do you have a pic of the final collimation?
Edited by Asbytec, 17 November 2019 - 05:40 AM.
#21 Euripides
Euripides
Posted 17 November 2019 - 07:38 AM
In my case, probably I was lucky, because those screws at the right corner were a little bit loosen. So, I've tighten them up and I believe that I got it. But even if I had to go further than this, I would go with trial & error with those screws. Just small adjustments to find out how it works.
Sadly I do not have an internal pic after the process but here is before pic or here and here after. You can easily see double rims on the craters.
I haven't tested it after that with a star, we have a lot of clouds now, but I am feeling much more confident about my focus in all of my close up lunar sessions.
#22 Asbytec
Asbytec
    Guy in a furry hat
  • Loc: Pampanga, PI
Posted 17 November 2019 - 08:39 AM
Ok, thank you. I may try that method just to see how it works. I also learned something about the adjustment screws, I've been doing it the hard way.
#23 SloMoe
SloMoe
  • Loc: Washington State
Posted 17 November 2019 - 09:39 AM
I'm not sure what to think here cause things are getting pretty weird,,,,,,
Just recently I purchased a new Celestron 90mm Mak Spotting scope, never thought I would own one but that's not the point, the point is now that one's coming my way a topic pop's up here all about how to collimate it, shocked.gif
Just recently finished an endeavor in short tube refractors,,,,,, now onto a new learning path. waytogo.gif
One thing I've learned about any of these scopes, if it isn't broken or out of collimation don't try to fix it anyway. cool.gif
The two links for collimation are really going to help me if need be,
