Good tripod that doesn't break the bank for 25x100 monster binocs
binoculars tripod
12 replies to this topic
#1 marinaldi
marinaldi
  • Loc: San Francisco, CA
Posted 15 August 2019 - 01:13 AM
Hi guys,  I have the Celestron Skymaster 25x100 binoculars.  I'm looking for a tripod to hold this 10.1lb beast.  I'm hoping to not spend more than $200.  Obviously I'll be looking up to the stars so it should be tall enough (I'm 5'7" tall) and have a good altitude range.  Any suggestions?
Thanks, Mike
#2 DLuders
DLuders
  • Loc: Spokane, WA
Posted 15 August 2019 - 01:57 AM
Have you looked at the Cloudy Nights "Classifieds" offerings for tripods?   https://www.cloudyni...h&fromMainBar=1
  • marinaldi likes this
#3 Jon Isaacs
Posted 15 August 2019 - 02:07 AM
Mike:
I'd be looking at your local craigslist for an older heavy duty Bogen/Manfrotto tripod and head.  Numbers like 3035-3036, 3046, 3050-3051 are good, there are some even more substantial models, 3058 maybe.   If the 0 is replaced by a 2, 3246 for example, it just means the tripod is black.
  • Foss, marinaldi, sevenofnine and 1 other like this
#4 ButterFly
ButterFly
Posted 15 August 2019 - 03:21 AM
There are these from the Bay Area Craigslist (search Manfrotto or Bogen):
Photo / Video tripod Bogen and Tiltall - $60
BOGEN TRIPOD - $150
They both have geared center columns, which is rather essential.  They are photo tripods (which you want for the geared center column), but big binos like video heads for smooth panning, so replace those photo heads.  I have a 501HDV head listed here to replace the photo heads.  I would start with that $70 3051 in the first ad above if you want it now.  Check whether the height will be okay for you.  Extend the legs out and test the center column to its full extent and back down before putting your binos on it.  The leg angles can be adjusted to gain a little more height.  Big bino risers are available too, which are suposed to help when adjusting the IPD for close-eyed ones.
The Bogen 3036, 3046 became Manfrotto 475B, which are the ones I have.  Waiting for one of those shouldn't take too long in the Bay Area.  Video heads to wait around for are 501HDV and 503HDV.  Stay away from the plain 501 without the HDV; they will cause you trouble with stiction.
  • marinaldi and yukosteel like this
#5 marinaldi
marinaldi
Posted 15 August 2019 - 10:22 AM
Thanks for all the good useful tips and links!
#6 Rich V.
Rich V.
Posted 15 August 2019 - 01:04 PM
+1 in recommendation of these heads along with the geared column Bogen/Manfrotto tripods mentioned above.
These discontinued heads are good for 100mm binos and are reasonably priced used.  Perhaps better than the heads that replaced them until the N8 and N12 heads were introduced.
The 501HDV is rated for 13.2# with a single 5.5# counterbalance spring setting option.  The 503HDV is rated for 17.6# and has three CB spring settings you can select; 2.9#, 5.7# and 8.6#.
The 503HDV will work well enough with 100mm BTs, also, if you eventually upgrade.
https://web.archive....V/_/501HDV_Head
https://web.archive....ith_501PL_Plate
Rich
  • Sleestax likes this
#7 Jitou
Jitou
  • Loc: France
Posted 15 August 2019 - 02:00 PM
You can't beat this to my opinion :
https://www.amazon.c...WLQS/ref=sr_1_9
#8 hallelujah
hallelujah
  • Loc: North Star over Colorado
Posted 15 August 2019 - 02:32 PM
Not tall enough.
  • Jon Isaacs and Rich V. like this
#9 Rich V.
Rich V.
Posted 15 August 2019 - 03:00 PM
I've had good experiences with Manfrotto 26# rated geared column tripods over many years; 3036 (x2), 475, and 028.  Also several of their ball heads and 3063 (x2), 501HDV, 503HDV and now N12 video heads.  All a good value with solid quality and dependable enough to recommend to anybody.
I just gave my son and his wife a very useful binocular setup for their new home with dark skies and a spectacular view as well-  a nice Manfrotto 028B with 501HDV head and Fujinon 16x70s.   It should give them a good start... wink.gif
Rich
  • Jon Isaacs, hallelujah, WALL.E and 1 other like this
#10 Jon Isaacs
Posted 15 August 2019 - 08:48 PM
Not tall enough.
It's also lacking a spreader. For heavier loads, I consider a spreader a necessity..
  • hallelujah likes this
#11 n5ama
n5ama
  • Loc: Home: Cypress, TX Observatory: Pie Town, NM
Posted 12 December 2019 - 10:22 PM
The binocrane is a great design that can be adapted to fit about whatever ridiculous binoculars you want to hang on it. It must be made from available materials but has the advantage of being as large and robust as needed or small to fit smaller instruments. The designer has a web site with a great deal of great information and even has a materials source list if you don’t have a well stocked junk box.
Another advantage to this design is you can use it in a reclining chair without the tripod getting in the way.
Check it out at   binocrane.com
#12 sjc327
sjc327
Posted 15 December 2019 - 11:10 AM
I'm very happy with this one:
https://www.bhphotov...ASABEgLMufD_BwE
  • j.gardavsky likes this
#13 j.gardavsky
j.gardavsky
  • Loc: Germany
Posted 15 December 2019 - 02:13 PM
I have 2 big light weight Linhof with central column and very good tangetial alt/az heads,
and the heavy duty Cullmann Titan CT 200 with the geared central column and with another good Cullmann Alpha 9000 tangential alt/az head.
The new to me Cullmann Titan CT 300 is now for my 6" F/5 refractor, replacing the older CT 200.
Best,
JG
Also tagged with one or more of these keywords: binoculars, tripod
