Sigma Art 105mm F1.4 Full Frame Sample
astrophotography dslr imaging lens making optics
22 replies to this topic
#1 Jerry Lodriguss
Jerry Lodriguss
    Vendor
  • Loc: Voorhees, NJ
Posted 15 August 2019 - 02:30 AM
Check out the corners at 100% and decide if you can live with them at f/1.4... cool.gif
Cassiopeia Full-Frame 8-Bit TIFF on Google Drive 57mb File
Sigma Art 105mm f/1.4 working at f/1.4
  • 150 x 15 seconds (37.5 minutes total exposure)
  • ISO 100
  • Mag 18 skies
  • Mount: Unguided iOptron CEMP25P
  • ASCOM Dither every 10 frames via BackYardEOS
Camera
  • Canon 6D (stock, unmodified)
  • Sensor: 35.8mm x 23.9mm, 5472 x 3648 pixels, each 6.5 microns
  • Overlay: Nikon APS-C (because Nikon at 1.5 is a wider FOV than Canon's 1.6x crop factor)
Field of View and Image Scale
  • Canon 6D: 19.90 x 13.35 degrees,  Image scale: 13.1454"/px
  • Nikon D5300:  13.12 x 8.77 degrees, Image scale: 7.90932"/px
Processing: DeepSkyStacker
  • 151 Raw light files calibrated with 64 flats and 64 bias
  • Use Camera WB
  • No Cosmetic repairs
  • Kappa-Sigma Average combine (2.50/5)
  • Adaptive Heterogeneity-Directed (AHD) Interpolation
  • Per Channel Background Calibration
  • RGB Channels Align
  • 2x Drizzle then downsample back to original size
Processing:  Photoshop
  • Assign sRGB color space
  • Non-linear curve
  • Sky background neutralized
  • Sky background flattened with GradientExTerminator
  • Levels stretch
  • Star colors enhanced
  • Black point adjusted
  • No lens correction profiles used at all
What do y'all think?
Edited by Jerry Lodriguss, 15 August 2019 - 03:09 AM.
  • Chris Cook, Jim Waters, rainycityastro and 6 others like this
#2 rockstarbill
rockstarbill
  • Loc: Snohomish, WA
Posted 15 August 2019 - 02:42 AM
CA - no.
Stars otherwise - fine.
#3 sharkmelley
sharkmelley
Posted 15 August 2019 - 03:27 AM
Wow, that really is the ultimate test and it's a very impressive result for a lens used wide open - especially at f/1.4 !
Stretching the image further (as you will want to do for imaging faint dust and nebulosity) you can see the stars towards the corners beginning to turn into crosses and develop blue "wings".  But I could certainly live with that for f/1.4
Mark
Edited by sharkmelley, 15 August 2019 - 03:27 AM.
#4 calypsob
calypsob
Posted 15 August 2019 - 08:03 AM
That is outstanding for F1.4
There is a slight reflective halo on the bright star in the center and on FF it seems the top left bottom left and top right have astigmatism, but the lower left is perfect for some reason.
Honestly though I could live with that little amount of astigmatism if it meant I could shoot f1.4
And on APS-C, stars are corrected perfect to the edges.
CA seems pretty well controlled IMO, even if yous saturated the heck out of this it could easily be dialed back to nothing in camera raw.  Definitely a killer lens.
Edited by calypsob, 15 August 2019 - 08:04 AM.
#5 AtmosFearIC
AtmosFearIC
  • Loc: Melbourne
Posted 15 August 2019 - 08:21 AM
That's pretty amazing performance wide open, probably some of the best I've seen.
#6 2ghouls
2ghouls
Posted 15 August 2019 - 10:43 AM
Very nice, and thanks for posting this sample. I plan to rent the lens at the end of the month to see if I like it enough to purchase.
How did you mount it? Did you use the included arca-swiss foot?
Edited by 2ghouls, 15 August 2019 - 10:43 AM.
#7 kingjamez
kingjamez
  • Loc: Fairfax, VA
Posted 15 August 2019 - 10:56 AM
Looks very useable at F/1.4 with an APS-C sensor, and probably very good with a full frame sensor at F/2. Impressive.
-Jim
#8 Jerry Lodriguss
Jerry Lodriguss
    Vendor
  • Loc: Voorhees, NJ
Posted 15 August 2019 - 03:03 PM
I thought about it using the arca-swiss foot, but I just don't trust the female clamp part because the one I have is made in China and I'm not risking a $1,600 lens on a $15 Chinese part, so I put it on a short Vixen dovetail into an ADM Vixen female clamp.
If I had had a really good arca-swiss clamp, I probably would have used it.
Jerry
Edited by Jerry Lodriguss, 15 August 2019 - 03:04 PM.
#9 Jerry Lodriguss
Jerry Lodriguss
    Vendor
  • Loc: Voorhees, NJ
Posted 15 August 2019 - 03:10 PM
Yes, it does have uneven corners. These lenses seem prone to that. I guess the tolerances of that much glass being perfectly collimated and aligned at f/1.4 is hard to attain. But I can live with what it is.
It does have reflections on bright stars that you have to deal with if you push the frame really hard to reveal faint stuff.
Jerry
#10 Coconuts
Coconuts
Posted 15 August 2019 - 04:31 PM
I must be missing something... there seem to be far fewer stars than I would expect with a 75 mm aperture and 37.5 minutes of exposure.  I can't recognize Cassiopeia.  What am I doing wrong?
The stars look pretty good, but there is a bright one in the upper right with distinct oblique sagittal spherical aberration and astigmatism.  So it might be worth stopping "all the way down" to f/2.0.  I am still waiting as some gear trickles in, but hope to get some images with this lens soon.  The tripod mount ring is solid, and allow easy full rotation for framing.  the base of the foot is quite flat, so I have simply bolted it to a Vixen dovetail.
All the best,
Kevin
#11 Jerry Lodriguss
Jerry Lodriguss
    Vendor
  • Loc: Voorhees, NJ
Posted 15 August 2019 - 06:09 PM
Hi Kevin,
You're probably just used to seeing enhanced images pushed for deepsky objects where bright stars get enormous.
This is the way stars are recorded with a DSLR. It happened with film too, that's why Akira Fuji used to use a fog filter, and why I use softare so you can see the bright stars in wide fields... see:
Gamma Persei.
Jerry
Edited by Jerry Lodriguss, 15 August 2019 - 06:11 PM.
#12 maxmir
maxmir
Posted 17 August 2019 - 08:47 AM
That's a keeper !  What a nice lens.
I have a 50mm Sigma. Not near as good until you stop down to F3-4.
Max
#13 gunny01
gunny01
Posted 17 August 2019 - 09:33 AM
  Jerry,
  I'm curious as to whether you have tried the sigma f1.4 in 20 and 24mm?    Is one any better for astigmatism/coma over the other?  Thanks for any insights.
#14 Jerry Lodriguss
Jerry Lodriguss
    Vendor
  • Loc: Voorhees, NJ
Posted 17 August 2019 - 04:12 PM
No, sorry I have not tried those.
Unfortunately I don't have an unlimited budget. :-)
Jerry
#15 dugpatrick
dugpatrick
  • Loc: Round Rock, TX
Posted 18 August 2019 - 08:58 AM
Perhaps Sigma (and others) should give/loan lenses to you for astro testing. :-)
Your images will certainly sell the product.  I just picked up a Sigma 135, and these things are not cheap!
Doug
Jerry
#16 Coconuts
Coconuts
Posted 18 August 2019 - 03:19 PM
gunny01: Both the Sigma Art 20 mm and 24 mm have corner issues.  Their 40 mm f/1.4 is amazing, though.  Here is a look at the three:
https://www.lenstip...._and_bokeh.html
All the best,
Kevin
#17 gunny01
gunny01
Posted 19 August 2019 - 06:46 AM
  Excellent articles Kevin.  The reason I asked for this information is that I have the 20mm f1.4 Sigma and I imaged the MW for the first time a few weeks ago.  Sure enough, what these articles describe is what I was seeing with my image. I was not sure of myself on these issues and I didn't want to shoot my mouth off without more information.
Maybe I should post the image?
  The lens has been good for indoor work though.  Outdoors it can show great distortion on the edges of an image.  Thought about trading it in, but it has done well for video.  Thanks.
Edited by gunny01, 19 August 2019 - 06:47 AM.
#18 Chris Cook
Chris Cook
  • Loc: Harwich, MA
Posted 27 August 2019 - 06:58 PM
I chuckle at the pixel peepers now days.  They know not what they speak... lol.gif ! ... they've never had the joy of shooting with a Nikkor 20mm f/2.8 Ai-s wide open on 35mm film....  try it some time and you'll see this lens is an astrophotographers dream.  Very nice Jerry.  I can see you are pleased with your purchase.
Edited by Chris Cook, 27 August 2019 - 07:01 PM.
#19 ChristopherBeere
ChristopherBeere
  • Loc: London UK
Posted 30 August 2019 - 07:15 AM
Could not resist the temptation any longer and pulled the trigger on one this morning !!
It will join my 14mm f1.8, 35mm f1.4 and 50mm f1.4 Sigma Art primes on my trip to Namibia in just over 3 weeks time.
Will be shooting with a modded 60D and a modded 6D MkII tracked on an Astrotrac and a Fornax.
I will whack some pics from the 105 up when i get back from the trip.
  • caseyfinn likes this
#20 Coconuts
Coconuts
Posted 30 August 2019 - 11:28 AM
Wow... Namibia... that sounds awesome!  I just received a Fornax LighTrack II, with the counterbalance kit coming on Tuesday.  It is a gorgeous and very accurate piece of gear.
All the best,
Kevin
#21 ChristopherBeere
ChristopherBeere
  • Loc: London UK
Posted 30 August 2019 - 11:42 AM
Yeah the Fornax II is a cracking bit of design and engineering. The polar wedge in particular is a lovely bit of machining.
You know its top kit when you get proper quality assurance in the form of a periodic error log graph !!!
#22 Coconuts
Coconuts
Posted 30 August 2019 - 11:53 AM
Yeah; according to the plot that came with my LighTrack II, the periodic error over eight minutes is an astounding +/- 0.5 arc-seconds!  Report attached.
I am taking advantage of this to make it the heart of a lightweight, very portable astrophotography rig with several cool features.  One arm lift, no laptop or heavy batteries required.  I will post details and photos of this once the counterweight kit arrives.
All the best,
Kevin
#23 ChristopherBeere
ChristopherBeere
  • Loc: London UK
Posted 30 August 2019 - 12:18 PM
Yeah the beauty of the Arts is the large aperture.
You can do away with a ton of gear when you only need to shoot short subs and its much less hassle.
Also tagged with one or more of these keywords: astrophotography, dslr, imaging, lens making, optics
