Focuser position don't change (RCX400 12")
8 replies to this topic
#1 smitty0
smitty0
  • Loc: Republic of Moldova, Chisinau
Posted 15 August 2019 - 03:45 AM
Hi!
Recenly i bought used RCX400 12", with dead motherboard, but i found (from astroboot.eu) new motherboard, and now everiting is worked, only focuser don't show data (freeze at 0.00mm).
All cables checked, everything seems to be fine, but focuser show 0.00mm position. Motors work fine. Restore to default collimation work fine. Calibrate wocus work fine.
I attach screenshot from MyScope with focuser data. Version of Autostar II updated to 2.2I
Hope someone can help me ;)
Oleg
#2 OzAndrewJ
OzAndrewJ
Posted 15 August 2019 - 04:11 AM
Gday Oleg
I havent seen data like that from an RCX in over 10 years :-)
Based on it being 2.2I ( ie patched ) it should return data.
Soooo, do the focus motors actually work???
If so, i will probably need to see a log file to see whats going on
as i have done lots of changes over the last 10 years but cant test
if any have affected the RCX bits in my app.
  • smitty0 likes this
#3 smitty0
smitty0
Posted 15 August 2019 - 05:08 AM
Gday Oleg
Hi Andrew!
Yes, focus motors work fine. A small video: https://youtu.be/PndCSJsqXqU
Log file attached (hope is what you need...).
#4 OzAndrewJ
OzAndrewJ
Posted 15 August 2019 - 05:34 AM
Gday Oleg
The data in that log makes no sense at all :-)
I have never seen anything like it
I see the text "bluetooth" in there but nothing matches the expected data
How are you connecting???
#5 smitty0
smitty0
Posted 15 August 2019 - 06:26 AM
Hi Andrew,
Attached fresh log. I connect through USB port from mount base (COM 16).
BTW, don't know why, but USB periodically reconnect.
Thank you!
Edited by smitty0, 15 August 2019 - 09:32 AM.
#6 OzAndrewJ
OzAndrewJ
Posted 15 August 2019 - 07:14 AM
Gday Oleg
The second log looks more normal but has a date of 2004 ????
Have you actually got a gps fix or entered a date/time on booting???
Also, can you do a connect and then run the rcx focusser diagnostic tab
and then save the log so i can see what comes back.
The firmware version you have loaded is correct for the diagnostics tab
so something should come back.
#7 smitty0
smitty0
Posted 15 August 2019 - 07:56 AM
Hi Andrew,
After factory reset didn't enter current date :)
Attached log files.
Thank you for help!
Oleg
#8 OzAndrewJ
OzAndrewJ
Posted 15 August 2019 - 04:54 PM
Gday Oleg
OK, the GPS is getting the correct data but isnt fixing
The focusser log doesnt help as such
what i wanted was the raw commands log, to see what got sent.
The tabsheet for focusser doesnt do any polling, you have to do snapshots as required.
ie boot the mount, connect my app
go to the RCX focus tab
hit the "recalculate" button and it should populate with the current data.
grab a dump for yourself
now use the handbox to adjust the focus
hit the "recalculate" button it should populate with the "new" current data
Now save the master logging tab log and send it to me and i can see whats changed and what commands got sent.
You can also simply compare the before and after dumps to see what changed
#9 smitty0
smitty0
Posted 16 August 2019 - 12:03 AM
Hi Andrew,
I made other cable, for connect to RS232 port on scope, now USB connection work perfect.
I attach logs (hope is what you need).
Oleg
Edited by smitty0, 16 August 2019 - 12:55 AM.
