APM - LZOS Telescope Apo Refractor 152/1200 3.7"ZTA
No replies to this topic
#1 APM M.Ludes
APM M.Ludes
    Vendor (APM Telescopes, Lunt Solar Systems, Lunt Engineering)
  • Restricted Vendors
  • Loc: Germany
Posted 18 August 2019 - 10:33 AM
https://www.apm-tele....html?info=3193
APM-LZOS 3-Lenses SuperED with APM 3.7 inch Deluxe focuser - in a new design!
For many years, we have been producing and distributing high end refractors for science, research, public institutions and dedicated amateur astronomers worldwide.
The optics calculated by us be performed the highest quality standards. Likewise, the mechanical components, such as tubes, lens holders and focusers are manufactured with our claim to perfection.
To make APM's high-quality apochromats with the world-class 3-Lenses SuperED Apo optics more attractive, we have decided to offer an APM / LZOS-APO special edition at a  lower price. This is made possible by our new, built-in APM 3.7 Rack and Pinion Focuser.
This pays off not only for our demanding customers, but also for our authorized dealers!
Description:
Optics:
Our LZOS Super ED 3-Lenses are delivered with test protocol, Each optic is individually measured with a Zygo interferometer and logged with the serial number of the Opik.
    Maximum Strehl (as with the Zeiss APQ) is guaranteed at 95% or better
    Minimum optimized residual chromasie
    Temperature compensating lense - housing
The tube:
Well-known APM construction as fast cooling down aluminum tubes
APM 3.7" Rack and Pinion Deluxe Focuser:
The new 3,7" focuser is a Rack and Pinion type, with 1:10 focusing. It remains rigid under high loads making it suitable for imaging. The attention to detail extends to areas like the 2" and 1.25" eyepiece adapters. These use a new design of collar clamp, far superior to the common brass compression rings found on lesser designs. Also new is our 2" APM  Fast Lock adapter now .
    3.7" Focuser (1:10 Microfocusing)
    2"/1,25" del. adapter
    Shoe for Finderbracket
    Adapter M82 x 1 ID
    Adapter M82 x 1 OD to M68 x 1 ID
    Adapter M68 x 1 OD to M63 x 1 ID
    Adapter M63 x 1 OD to 2" APM Fast Lock
Matching the telescope, we recommend the Riccardi M82 0.75x Reducer and the Flattener 1.0x - Model 1. If you have any questions, please contact our customer service directly.
Delivery contains:
    Optical tube
    LZOS testreport
    APM 3.7" rotation focuser (ZTA)
    APM Fast Lock Adapter 2"/1.25"
    Set APM CNC tube rings
    APM 3" dovetail
    Dustcaps
    Viewfinder bracket
    Case
US $ 8,895.00
available from stock at APM-in Germany
  • RogerLaureys and petert913 like this
